Old 10-31-2007, 02:49 PM   #1 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (65)
HOW-TO: Non Fouler Mod
This mod will clear some or all of the No Cat Codes that the engine throws for not having a Cat.
*This was first done by forum member: jmihalchik
Here is his How To: HOW-TO: Trick Comp For No Cat Code - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
*I am not responsible for any mishaps due to you doing this mod...If you are not mechanicly inclined. Please get help when doing this.
*Hope this helps a lot of people...Any questions...feel free to post but no pms, please...I get enough already
Parts Needed:
18mm Spark Plug Non-Fouler (come in 2 per pack) and are available at any local auto store ($5)
7/16th drill bit ($5)
Compressed Air Can / Air Compressor ($5 for can)
7/8th Wrench
Drill (Bosch > Craftsman)
How To:
-Disconnect Negative Battery Terminal
-Find 2nd o2 Sensor Harness and disconnect it.
-Take 7/8th wrench and remove sensor (lefty loosy, righty tighty)
-Take non fouler out of package and secure with a vice grip (Preferably a big vice grip)
-Insert Drill Bit in Drill (DO NOT HAVE THE DRILL PLUGED IN WHEN DOING THIS)
-Support the Vice Grip with your feet or any other heavy object, soo when the drill is going, it doesnt shoot out flying.
-Do not penetrate the tip of the Fouler...you will just be drilling to open up the inside of it.
-After you have drilled some of the inside off...Clean the metal shavings off with the bottle or air compressor...try to insert the O2 Sensor in and tighten. (Try drilling little by little until the O2 Sensor screws in) I left the vice grip on the Fouler and just tightened the O2 Sensor with the 7/8s Wrench...much easier and faster.
-Fouler and O2 Sensor should look like this...(If it doesnt, please stop and get someone with more "mechanical skills")
-Insert Fouler into Downpipe
-Tighten up the Fouler (not the O2) into the Downpipe
-Plug in O2 Sensor harness back (Make sure you hear a "clicking" sound)
And you done...
Quote: Originally Posted by kortERHorse_281 View Post
If jesus were alive he would freak flop in your mouth....
....right in your mouth dude. he would freak flop in it.
carlos nice
Netou is offline   Reply With Quote
Old 10-31-2007, 02:53 PM   #2 (permalink)
s4acr3's Avatar
Member Number: 53848
Trader Rating: (13)
What was the point of this mod?
s4acr3 is offline   Reply With Quote
Old 10-31-2007, 02:54 PM   #3 (permalink)
Netou's Avatar
Trader Rating: (65)
Read first part of post...
Old 10-31-2007, 06:31 PM   #4 (permalink)
s4acr3's Avatar
Trader Rating: (13)
Old 10-31-2007, 07:13 PM   #5 (permalink)
Netou's Avatar
Trader Rating: (65)
Old 02-05-2008, 08:14 PM   #6 (permalink)
marshall_634's Avatar
Member Number: 46515
Trader Rating: (10)
anyone have pics of what the fouler should look like after the drilling
Having NOS is like knowing a hot girl with an STD...You KNOW you wanna hit it, your just afraid of the outcome
marshall_634 is offline   Reply With Quote
Old 02-14-2008, 03:21 PM   #7 (permalink)
sm00thk0zz's Avatar
Member Number: 51476
Ya lets get those pics back up
sm00thk0zz is offline   Reply With Quote
Old 02-25-2008, 07:22 PM   #8 (permalink)
Overboosted's Avatar
Member Number: 46759
if your stage 1, you dont have to worry about this do you???
Overboosted is offline   Reply With Quote
Old 02-27-2008, 05:34 AM   #9 (permalink)
woltegsrt4's Avatar
Member Number: 10193
Trader Rating: (47)
You are absolutely right my friend.
woltegsrt4 is offline   Reply With Quote
Old 03-04-2008, 02:06 AM   #10 (permalink)
Netou's Avatar
Trader Rating: (65)
Yea Netou...
Get those pics back up...!!!
Old 06-03-2008, 11:01 AM   #11 (permalink)
OP's_srt's Avatar
Member Number: 45508
i did this mod and i get a cel p2096 post cat lean condition all the time.. Only mod is 3" dp on 05 srt
OP's_srt is offline   Reply With Quote
Old 06-03-2008, 11:04 AM   #12 (permalink)
OP's_srt's Avatar
does that mean in need to drill out more for it to se more exhaust???
Old 06-11-2008, 08:36 AM   #13 (permalink)
OP's_srt's Avatar
Old 06-11-2008, 09:09 AM   #14 (permalink)
OP's_srt's Avatar
OK I have done this mod in ever way posable.. I tried drilling it just enough so the o2 sensor is tight i get p2096 post cat lean condition... I tried drilling it all the way through thinking it needed to see more exhaust and still P2096.. Then i took out the non fouler and got p0420 cat insufficient... Finally i found a how to guide on a different forum that said to drill all the way through one non fouler and screw it in to the other non fouler (not drilling the second one at all) and the putting it on the downpipe, and then the cel P2096. So what else is there to do... I have a 2005 srt with hks ssq and 3'' dp thats it.. Can someone help me out?? Thanks..
Old 06-11-2008, 02:08 PM   #15 (permalink)
OP's_srt's Avatar
Can some one give me any info.. That helps! Thanks
Page generated in 0.16299 seconds with 13 queries
