Old 10-12-2008, 12:51 AM   #1 (permalink)
wiggy's Avatar
Member Number: 58107
Trader Rating: (58)
Default How-To: Molded PVO/AVS Spoiler/ Shaved Lock/3rd Brake Light
I want to preface this how-to with a warning: This is extremely time consuming and shouldn't be attempted unless you have a fair knowledge of how materials like fiberglass, fiberglass resin, and Bondo work.
Supplies needed:
1 - 2000-2005 Dodge/Plymouth/Chrysler Neon decklid
1 - PVO/AVS spoiler
1 - 3/4" dowel rod (only if your decklid isn't already wingless)
1 - medium sized "C" clamp (again, only if you aren't already wingless)
1 - gallon of lacquer thinner (if you want to remove the paint for maximum adhesion)
1 - Quart of Bondo
1 - Tube of glazing/spot putty
1 - Quart of fiberglass resin
1 - sheet of woven fiberglass cloth, approximately 10 square feet (DO NOT buy the sheets of blown fiberglass. What you buy should look like a piece of woven fabric)
At least 3 sheets each of 60 grit, 120 grit, 220-320 grit, and 400-600 grit sandpaper.
A couple of Durablocks (I recommend a 12"x1.5" block and another one of the same width cut down to 4-6")
a bucket that you can fill with soapy water (for wet sanding)
2 - syringes of quick set, 2 part epoxy (I prefer the 3-5 minute setup stuff versus the 1 minute so you have some time to work with it)
2-3 cans of automotive spray primer
A LOT of time and patience
If your deck lid is already wingless then you can skip this first step.
Cut the dowel rod so that when inserted into the bottom of the lid it fits flush with the surface. Apply 2-part epoxy, insert and clamp down until it sets up.
You don't need to shave the lock tumbler or the 3rd brake light. I did it because it looks better that way to me. Skip this part if you don't want to bother.
Remove the tumbler and third brake light. Add 2-part epoxy to the areas that make contact with the decklid and re-install. This will help insure that these two part stay put, forever.
Apply a coat of Bondo
Sand Bondo using Durablock whenever possible. Start with a 60-100 grit paper and work up to a 120-220 grit. (later we'll go back and finish up with some higher grit when prepping for paint)
Ta-Da! You can haz no clutter on your trunk!
I bought the CBD PVO-style spoiler in fiberglass. I would recommend getting the carbon fiber instead as the FG one is made of a single layer of blown fiber. It's quite flimsy and I had to fill it with some expanding foam to give it some rigidity. In addition to the two sided 3M adhesive strips that came on the wing, I added a thick bead of 2-part epoxy to affix it to the decklid. This is where having a slower cure time helps, as it takes a few minutes just to get a bead all around the spoiler.
Now you can either rough up the wing and decklid with sandpaper before applying a sheet of fiberglass, or you can use the thinner to strip the paint completely. The thinner is the best way to go, but it's time consuming and messy as hell. I just roughed the surface up really good with some 60 grit and went ahead and applied the fiberglass sheet. This step will help to ensure that the spoiler doesn't ever pull away from the decklid.
Add Bondo and sand to a smooth finish with a Durablock.
Again, ta-da!
You can repeat this process on the rear of the decklid, but you must be careful as to avoid mucking up the character line that runs through the middle of it. I didn't bother.
Now's the time when you want to check to make sure that you've created nice smooth surfaces. Sand, prime, and wet sand to check your surfaces. Make sure you have either sunlight or really bright direct indoor lighting to check your reflections to make sure that your surfaces are true.
Sand, Bondo, spot putty, prime and wet sand as necessary in order to perfect the surfaces that you've created. Finally prime the whole thing then wet sand with a 400-600 grit to clean it up and paint!
Voila!
Good luck!
wiggy is offline   Reply With Quote
Old 10-12-2008, 12:59 AM   #2 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
that looks amazin!! i have a cf trunk and a cf pvo and would love to do that... good jobs
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is offline   Reply With Quote
Old 10-12-2008, 07:19 AM   #3 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (73)
Do you have more pics of the finished product?
Looks good.
CJsStocker is offline   Reply With Quote
Old 10-12-2008, 08:19 AM   #4 (permalink)
wiggy's Avatar
Trader Rating: (58)
I've only got a couple. I'll take some more later this week. I had to take it off to fix a boo-boo that I made.
Old 10-12-2008, 08:45 AM   #5 (permalink)
Super Moderator
SRT of the Month
Member Number: 39843
Trader Rating: (183)
Looks good. Now make those tails a brighter red & it will look perfect.
Old 10-12-2008, 09:23 AM   #6 (permalink)
elvatoloco's Avatar
Member Number: 51797
Trader Rating: (47)
so how much you gonna charge me for labor to do this for me lol
elvatoloco is offline   Reply With Quote
Old 10-12-2008, 11:08 AM   #7 (permalink)
wiggy's Avatar
Trader Rating: (58)
^^^ 1 billion dollars. LOL
I don't think I'm gonna be doing this again for a long time. It's pretty much a huge PITA.
Old 10-12-2008, 11:11 AM   #8 (permalink)
elvatoloco's Avatar
Trader Rating: (47)
yeah i'm wondering how much is it gonna cost me to have mine done, shaved everything and molded avs and even fill in the spoiler holes.
Old 10-12-2008, 11:14 AM   #9 (permalink)
Spyder1727's Avatar
Member Number: 56434
damn...well, now i dont have any excuses to do it now...im gona shave the 3rd light and lock now cuz it looks amazing.
best write up ive ever seen btw. great job bro
12.91@109.7 stock turbo
Spyder1727 is offline   Reply With Quote
Old 10-12-2008, 11:18 AM   #10 (permalink)
Spyder1727's Avatar
it'll be around 400ish. thats what i got quoted on. thats only plug the spoiler holes, mold the lip and paint. probably closer to 500 to do it all(3rd lite + lock), unless u know someone good w/body work capabilities, then he might just charge you for a case of beer, supplies, and paint. so closer to 150. i'd still rather do it myself for the satisfaction...which i will now
Old 10-12-2008, 12:02 PM   #11 (permalink)
elvatoloco's Avatar
Trader Rating: (47)
^^^yeah i couldn't bondo and paint to save my life lol
Old 10-12-2008, 01:20 PM   #12 (permalink)
wiggy's Avatar
Trader Rating: (58)
Yeah, I even added a proper third brake light form an old Infiniti Q45. I think it looks like it belongs there personally.
Old 10-12-2008, 02:53 PM   #13 (permalink)
gotbst05's Avatar
Member Number: 37403
Trader Rating: (10)
freakin nice! i've already got mine mounted to my trunk and wanna do this so bad, but i just don't have the experience with body work. i wouldn't mind doing it myself, but i think i may be taking it to a pro. awesome job tho boss!
gotbst05 is offline   Reply With Quote
Old 10-12-2008, 03:41 PM   #14 (permalink)
mattyice's Avatar
Member Number: 10738
wiggy i say we charge people like we talked about haha
1986 Jetta GLI - completing VR6 swap
2008 Caliber SRT4 - awaiting trade in from 2010 GTI
EuroVagens - NE Ohio's premier Euro auto enthusiast group
mattyice is offline   Reply With Quote
Old 10-12-2008, 04:05 PM   #15 (permalink)
wiggy's Avatar
Trader Rating: (58)
^^^ I dunno man. I'd be scared to death to ship one of these, not to mention the cost. Which, last time I checked, was in the neighborhood of $150.
