Old 08-24-2009, 12:27 AM   #1 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (78)
Default How-To: Make/Install Resistor Box for Low Impedance (ohm) Injectors
How to make a resistor box for low impedance (ohm) injectors.
I got most of this info from Google searches and trial and error.
If you blow up your shit attempting this its not my problem.
If you can’t figure it out its not my problem.
If you need help filling in the blanks you should not be attempting this.
Basic/Much Over simplified reason you need resistors (or a driver box which I am not talking about here): Stock injectors and many injectors (about 950cc and less) are high ohm (high impedance), higher resistance require less current to operate and so the amp draw is much less (less heat), with no need for a resistor/s on the stock system. However, because Low Impedance injectors, have a lower resistance, they draw more amps. More amps equals more heat which our PCM’s drivers are not designed for. I recommend doing some research on the differences between Saturated and Peak and Hold Injectors and the differences / advantages / disadvantages of a resistor box versus a injector driver box.
Typical High Impedance= 13.5-14ohm
Typical Low Impedance= 2-3ohm
We tested the stock battery voltage on Kyle’s car and came up with 13.2 volts (so our system will put out a constant 13.2 volts while the car is running (+or- 0.8 volts or so).
Stock high impedance (ohm) injector example:
13.2v power / 13.3 ohm injector = 0.99 Amps draw (stock current).
Low Impedance (ohm) injector (this is from the test of the 1550 cc ones I have), if plugged into a high impedance harness without a resistor box:
13.2v/ 2.7 ohm injector = 4.89 Amps draw
This extra current (amps) creates HEAT and this is why if you hook up low impedance (Ohm) injectors into a stock harness without a resistor pack it will melt the PCM’s low side (ground controlled) drivers pretty damn fast (only fix once melted / blown is a new PCM).
Note: You should contact your Retailer, or Manufacture of your injectors to figure out the right AMP value for your injector to operate at. You should also know the Resistance of the injector (ask or test with a multi meter, testing is better as the manufactures specs is not the exact spec of your injectors because of tolerances within the manufacturing process).
Note: You probably don’t want to put more then a about a 1.2-1.6amp draw on the stock PCM (just guessing here) because the heat from extra current (stock is 1 amp) will affect the longevity of the PCM drivers,. Try to go with the lowest amp setup you can with the injectors working correctly.
Example I found my 2.7 ohm injectors (tested the ohm with a multi meter) needed a minimum of 1.19 amps to open/fire correctly. Generally the smaller low ohm injectors 1200 cc for example (mine are 1550 cc) will work with less current / amps (so something like a 10ohm resistor).
13.2v/(X+2.7ohm)=1.19AMP
13.2v/(X+2.7ohm)-1.19AMP = 0
X=8.4
13.4v/11.1ohm=1.19 Amp
Notice that in my first example 2.7 ohm injectors on a stock harness would have equaled 4.89 Amps and a fried/melted my stock PCM injector drivers. Once I added the resistors inline I get nice safe 1.19 Amps.
Supplies I used:
18 gauge wire
Radio Shack: Four 20watt (they can safely dissipate up to 20 watts) 8 ohm ceramic resistors (use the above calc to figure out what ohm resistor you should go with!) with a tolerance of 5%, when measured with a multi meter they were all 8.4 - 8.6 ohms. If you can find a lower tolerance (1%) that would be better as they will all be dead on the rated ohm’s. DON’T use a high tolerance then 5% though.
Water proof shrink wrap tubing
Zip Ties
Double sided 3m tape
Solder (get the nice thin, high lead 60/40% stuff)
Flux
Quality 3m Electrical Tape
Radio Shack Project Box
Wire loom (various sizes)
I also used a Mopar Harness repair kit but its not needed
Tools (I used more but this is all I can remember):
Screw Driver/s
Dikes
Wire Strippers
Soldering Iron
Heat Gun
Multi Meter
Drill
Drill Bits (I used a big one LOL)
FIRST: Test the Ohm’s of your resistors with your multi meter, I bought 5 and picked the 4 with the closest tolerances.
SECOND: SHUT OFF THE BATTARY (not needed but a good idea)
Picture of everything laid out:
Picture of project box wrapper:
Resistors I used (use the calculations to figure out what you will need):
Picture of were to set the multi meter to test the resistors before the wiring and after:
Project How To:
1. Measure can cut about 8 lengths of the 18 gage wire, I used four lengths x 2ft each.
2. Drill a hole big enough hole for 4 wires plus some extra room for some shrink wrap.
3. I lined up all 4 resistors and wires then trimmed some of the resistor wires, stripped the wires, added the flux (use lots of flux it helps the solder wick), crimped, soldered and then shrink wrapped first:
Crimped with flux and ready for solder:
Water proof shrink wrap:
4. Repeat step 3 for the other side of the resistors.
5. Install into box. Be careful with this step NOT to twist the metal from the resistors back and forth as it will weaken and SNAP and you will have to get a new resistor. I drilled the holes in the end of the box big enough to fit a little of the wider shrink wrap in there.
6. Test each resistor for good conductivity and the correct ohm (do this before and after they are soldered in):
7. Put the lid on the box (mine did not quite fit tight but it worked good anyway):
8. Open up the harness and find the four injector wires they are a switched 12v wire (green with orange strip). Join the side coming from up the harness (battery/fuse box) all together and flux/solder/add shrink tubing to the four wires going to the resistor box (also twisted together).
Note info about the green wire with orange strip: It does not matter what wire goes to what injectors because the all get constant power. The Injectors are switched on/off (controlled) by the PCM low side (GROUND) driver. Furthermore this wire if traced back of though the harness is actually a single wire that splits into 6 wires that power the coil, noise suppresser and all four injectors. You want to splice into it where it is four wires that are going directly to the injectors.
Here is were I spliced into the green/orange strip injector power wires:
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 08-24-2009, 12:27 AM   #2 (permalink)
Trader Rating: (78)
9. Now solder/flux/add shrink tubing each of the wires coming out of the resistor box (separate from each other this time) to each individual wire going up the harness to the injectors (remember order does not matter but they must all be independent).
Note: If you chose you can have a longer harness on the resistor box and run the wires directly to the injector pigtails (this is what I did because my stock harness was hacked up).
Picture I wired my right to the injectors pigtails:
NOTE: Before you clean up and button up the harness TEST IT! Try and start the car, if it doesn’t start….. Start testing shit for the correct OHM, enough voltage and good conductivity. If everything checks out you might not have enough current/draw and have used resistors that have too much impedance (not enough current/amps) to open/fire your injectors, this is why its important to contact your injector manufacturer (not the vendor who sold them).
11. Cleaned up and finishedc the harness:
I chose to hide the wires under the intake manifold:
12. Mount the box using the double sided 3m tape (away from heat/wet).
Here is were I mounted my box:
All cleaned up and running:
Thanks and good luck,
Drew…
Old 08-24-2009, 10:20 PM   #3 (permalink)
Trader Rating: (78)
Pictures added
Old 08-25-2009, 03:39 AM   #4 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
very nice man.
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 08-25-2009, 03:57 PM   #5 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
I was gonna do one after tonight, nice write up.
Old 08-27-2009, 10:14 PM   #6 (permalink)
3chord's Avatar
Member Number: 70323
Trader Rating: (12)
I am a geek. But what would be really sweet would be to use some 12v LED lights instead of the resistors, then you could have a fuel injected lightshow under the hood
Not sure what type of dwell it would add though
Props for a cool DIY, looks like you got a nice setup under the hood
3chord is offline   Reply With Quote
Old 09-07-2009, 05:15 PM   #7 (permalink)
Jagok1's Avatar
Member Number: 14366
Trader Rating: (18)
If it ever goes bad, you'd know which one it is.
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Old 09-28-2009, 12:12 AM   #8 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
sick write up. THANKS!!!!!!!!
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 09-28-2009, 01:25 AM   #9 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
sweet dipstick
Old 09-28-2009, 01:39 AM   #10 (permalink)
mole''s Avatar
Quote: Originally Posted by nutz View Post
sweet dipstick
my 1680cc injectors came in.
Old 09-28-2009, 02:57 AM   #11 (permalink)
ticaaal70's Avatar
Member Number: 64715
Trader Rating: (24)
ticaaal70 is offline   Reply With Quote
Old 09-28-2009, 09:54 AM   #12 (permalink)
Trader Rating: (78)
Nice! E85?
Page generated in 0.23945 seconds with 13 queries
