Old 06-05-2008, 10:02 PM   #31 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (32)
then the one he listed are what you need.
04 NSRT-4 - DBB 50T Daily Driver
87 Mustang GT - New project..working on getting a big snail..
Old 06-10-2008, 10:41 PM   #32 (permalink)
SoCalHybrid's Avatar
Member Number: 52814
Thumbs up
I just did this, a few things I would add:
- Get some M6 washers as the stock bolt has a flange, and you want to use a washer so the bolt head doesn't dig up the oil filter mount when you tighten it down.
- The middle oil drain screw is pretty difficult to remove. You need to have a very large hex bit, I would have to guess 3/8 or 7/16. What I did was find a bolt that had a head that fit inside the oil drain screw, then using vice grips, clamped down on the bolt and actually had to hold the cooler in a vice and put a breaker bar on the vice grips (Yes mine were on that hard). Because I didn't read the instructions all the way I didn't know that you threw out the oil screw, so hindsight 20/20, I offer this advice, go ahead and put the vice grips right on the oil drain threads as it doesn't matter when you wreck them because you are justy going to throw it out anyway. But yeah, if you have a hex bit that large, that's the best way.
- Plan on doing a coolant flush. When you pull the coolant hoses, you'll loose about 1.5 gallons of coolant. You can use vice grips like suggested, but when you yank one off to connect the other, it's going to be a mess. So, get yourself some distilled water and Zeres G05 HOAT (or Factory) coolant.
- Both factory rubber lines are molded to wrap around the intermediate axle. I suggest when you connect them, you do as I did and flip the hose around so that it bends towards the oil pan instead of the spinning intermediate axle.
- The torque rating on the 3 bolts are 105 in/lbs according to the shop manual.
Overall a great how-to!
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking 1 condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
SoCalHybrid is offline   Reply With Quote
Old 06-11-2008, 08:34 AM   #33 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
I bent the tubing then used some automotive zip-ties to "tie" it off to the brace next to the intermediate shaft, ensuring there was no crease in the hose to prevent coolant flow down there. Worked like a charm
Pensi?
Old 06-13-2008, 02:19 AM   #34 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (78)
I did the install today,I took some pictures for the people on here that dont have plugs for there coolant lines and want to just do the loop with the hose.What I did was bought a foot of heater hose from bennet auto supply,it was $1.16 total.
I did this because yes you can still use one of the hoses that came off the lines,but they are already shaped and its kind of hard to get them to bend the way you want them to.Mine had a kink in it and it wouldnt get straight no matter what so I just bought some new hose,a couple bucks and you have a new hose and a nice,clean install.
Heres the 2 lines that you connect to each other,I circled the ends of them in Yellow.This is a picture of the rubber hoses already pulled off of the metal coolant lines.
Now get your new hose and use it to connect both lines together,like this.
VOILA! Now you dont have to worry about your plugs coming out.Hopefully this helps a few people with there install!
-Frazier
400whp SRT - Sold.
New Whip - Evo 9.
Stage 2 Injectors for sale - $230 shipped - PM ME!!
WTB : Stage 1 PCM - PM ME!!!
FraziersSRT is offline   Reply With Quote
Old 06-13-2008, 02:22 AM   #35 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
-Frazier
thanks man for the post
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 06-13-2008, 01:33 PM   #36 (permalink)
Trader Rating: (78)
No prob mang! ^^^ Glad I could help.
Old 06-16-2008, 08:59 PM   #37 (permalink)
KeoSRT4sho's Avatar
Member Number: 48664
can someone just take a picture of the oil filter??
JDM USDM SRT4
KeoSRT4sho is offline   Reply With Quote
Old 06-16-2008, 11:22 PM   #38 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (168)
Old 06-16-2008, 11:25 PM   #39 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
what parts would i need to buy to just remove the oil cooler.
AGP S256 FS
Old 06-16-2008, 11:33 PM   #40 (permalink)
Trader Rating: (32)
lmao!!
you would need to use a vice and that hex bit listed on the first page.
Old 06-17-2008, 08:42 PM   #41 (permalink)
KeoSRT4sho's Avatar
i didnt get this at first but i saw another how to on the ptp. looks pretty easy. i hate coolant tho. burns!>!>>!>
Old 06-19-2008, 05:06 PM   #42 (permalink)
KeoSRT4sho's Avatar
this actually costs me about 15 bucks... now i just need to install it... great write up
Old 06-19-2008, 06:49 PM   #43 (permalink)
Pizza Boy's Avatar
Member Number: 49788
Trader Rating: (64)
Lmao@ uncommons pic...fucking hillarious
Quote: Originally Posted by JPG View Post
My boyfriend wanted a hand-job but i couldn't get a good grip because he had a chode.
Pizza Boy is offline   Reply With Quote
Old 06-19-2008, 07:55 PM   #44 (permalink)
sphipps's Avatar
Member Number: 19187
ditto
JPG
Quote: Originally Posted by Illegal Machine View Post
I'd like to see Steve's craigslist ad.
"Like new. Comes with 4 jack stands."
sphipps is offline   Reply With Quote
Old 06-19-2008, 09:43 PM   #45 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (33)
Quote: Originally Posted by sphipps View Post
ditto
ditto
ANTI-SWEETS CLUB MEMBER # 6
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Page generated in 0.15407 seconds with 13 queries
