Old 05-27-2008, 09:39 PM   #16 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
marked for later
AGP S256 FS
Old 06-03-2008, 10:44 PM   #17 (permalink)
lyncoo's Avatar
Trader Rating: (92)
how can i just remove the oil cooler
Old 06-04-2008, 08:52 PM   #18 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
What do you mean just remove the oil cooler? That's what this mod does. You use a hex socket and break free that middle piece that the oil transfers through and throw that AND the cooler away. Then the new filter simply mates to the oil filter adapter without the cooler between the two. You will need the gaskets or PTP's aluminum spacer to move the adapter farther away from the block for a bigger filter to fit.
Pensi?
Old 06-05-2008, 02:10 AM   #19 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (32)
Quote: Originally Posted by beyondspexj View Post
how do you open up the stock dumptube restriction rasp? thanx!
04 NSRT-4 - DBB 50T Daily Driver
87 Mustang GT - New project..working on getting a big snail..
Old 06-05-2008, 06:28 AM   #20 (permalink)
rasp's Avatar
Trader Rating: (21)
The stock dumptube restriction? What the hell is that, lol?
Old 06-05-2008, 06:38 AM   #21 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (168)
he means oil pick up tube ...
you want to cut it open, like this:
Old 06-05-2008, 11:24 AM   #22 (permalink)
Trader Rating: (32)
lmao yea i ment pick up tube my fault!
thanks nate!
Old 06-05-2008, 01:11 PM   #23 (permalink)
lyncoo's Avatar
Trader Rating: (92)
i dont want to run a bigger oil filter just remove the cooler
Old 06-05-2008, 05:45 PM   #24 (permalink)
rasp's Avatar
Trader Rating: (21)
Then you can get off just removing the cooler and not placing any additional gaskets or anything between the pan and the adapter. Either way, removing the oil cooler is what will give the added benefit, not the filter itself; that's just a perk with the vendors' kits.
Old 06-05-2008, 05:46 PM   #25 (permalink)
rasp's Avatar
Trader Rating: (21)
Uncommon = picture king!
Old 06-05-2008, 05:47 PM   #26 (permalink)
lyncoo's Avatar
Trader Rating: (92)
thanks so i do just like the how to but no gaskets and filter
Old 06-05-2008, 06:05 PM   #27 (permalink)
rasp's Avatar
Trader Rating: (21)
Bro the gaskets are cheap as hell. I may have extras here I can send you for free; honestly...lol.
Old 06-05-2008, 06:06 PM   #28 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
I'll be doing this tomorrow & I can take some pictures ... I'm not sure I understand exactly what I'm taking apart, but I'm sure I'll understand once it's in my hand
anyone have any idea what the threads are for the oil pan? I need to go pick up some studs/bolts for it
Old 06-05-2008, 06:38 PM   #29 (permalink)
joshiepoogoose's Avatar
Member Number: 53439
Trader Rating: (21)
3 M6 x 1.00 x 30mm
joshiepoogoose is offline   Reply With Quote
Old 06-05-2008, 08:32 PM   #30 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
I meant for the ones that bolt the oil cooler/filter to the pan ... or whatever you want to call it
there's 3 of them total
Page generated in 0.15112 seconds with 13 queries
