Old 05-20-2008, 11:18 PM   #1 (permalink)
e_freeman85's Avatar
Member Number: 13554
Trader Rating: (13)
Default How-To: Make Big Oil Filter Kit (for 25$)
First off this is not a how to install this is a how to make a big filter kit just like the ones sold for nearly double the price.
1st you need to get the gaskets to space the filter away from the oil pan
I just went down to my local stealership and picked 2 up for 11$. They will vary from 5$ to 7$ a peice depenting how much your dealer sells them for.
part number 04884000AAA
Next you need a filter just go to your car parts store of choice and pick up
one of these filters
i just got a mobil one because i use mobil 1 oil for my trans and engine oil
the part number is M1-301
the filter in most kits is a K&N HP-3001
the rest of these are the same size just a cross referenced part numbers
Manufacturer Part Number
AC HD222
AC PF2
AC PF2149
AC PF2217
AC PF41010
AC PFAFL1A
AC PFL1A
AC PFW1120
AC X61
CHAMPION LAB. HP1
CHAMPION LAB. PH2815
CHAMPION LAB. PH8A
FRAM HP1
FRAM P8427
FRAM PH2815
FRAM PH2879
FRAM PH3381
FRAM PH3569
FRAM PH4854
FRAM PH7650
FRAM PH8A
MOBIL1 M1301
MOTORCRAFT AFL1
MOTORCRAFT FL1A
MOTORCRAFT FL1HP
MOTORCRAFT FL281
ONAN 122P193
PURO L30001
PURO L30119
PURO L30257
PURO L30341
PURO L37673
PURO L38257
PURO L39001
PURO L40316
WIX 41515
WIX 51515
WIX 51525
WIX 51545
WIX 51622
WIX 51775
and 3 M6x1.00x30mm bolts you can pick them up at any parts store for about 2-3$
and there you have it
2 gaskets for around 11$
1 filter max 13$
a couple bolts for 2.50$
and there you have it all you need to make a big filter kit now all you have to do is use the search button and look up a big filter kit install and there ya go.
i claim no responseablity for engine damage due to improper installation, negligence, or pure stupidity
e_freeman85 is offline   Reply With Quote
Old 05-21-2008, 06:08 AM   #2 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
Use the 2 factory gaskets, then an additional gasket to bring the count up to 3. Remove oil cooler using a vice and a hex socket and throw both the middle part and the cooler away. Then install the 3 gaskets, with the above bolts/studs and torque down.
To "block off" coolant, just take the line coming IN to the cooler and bend it around so it goes into the line returning the coolant back to the block. Both are right next to each other.
I love turbo lag, it gives you a second to reflect about the poor decision you have just made.
rasp is online now   Reply With Quote
Old 05-21-2008, 04:18 PM   #3 (permalink)
Trader Rating: (13)
thank you rasp for the install it wasn't hard to do but I'm horrible with directions so I didnt try to write one up thank you again
Old 05-21-2008, 04:22 PM   #4 (permalink)
Pizza Boy's Avatar
Member Number: 49788
Trader Rating: (58)
Ttiwwop...
Quote: Originally Posted by raven View Post
i'm 23 and live in my parents basement.
i could land a much better looking dude than you.
Pizza Boy is offline   Reply With Quote
Old 05-21-2008, 04:31 PM   #5 (permalink)
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (129)
subscribed for pics
12.4 @ 126 mph on street tires
Old 05-21-2008, 07:21 PM   #6 (permalink)
Trader Rating: (13)
I can get ya pics of the gasket but mines already installed so I dont have the ability to take any pics of the install
Old 05-21-2008, 08:36 PM   #7 (permalink)
rasp's Avatar
Trader Rating: (15)
What do you guys want pics of? The gaskets are pretty self explanatory; what else do you want to see?
Old 05-22-2008, 08:37 AM   #8 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
wow DIY ftw!! i just might have to do it this weekend..
Old 05-27-2008, 12:15 PM   #9 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (44)
Interesting,pretty much all your doing is getting the same spacer the stock one uses,doubling it up,getting longer bolts obviously since the filter will stick out farther now,and then just buy the bigger filter.What are the benefits of doing this anways?I mean...exactly HOW is this going to help my car?
-Frazier
FS : Stage 3 PCM w/toys,RC 650's,Mopar CAI!! PM ME!!
http://www.srtforums.com/forums/f27/...intake-463771/
FraziersSRT is offline   Reply With Quote
Old 05-27-2008, 12:33 PM   #10 (permalink)
rasp's Avatar
Trader Rating: (15)
-Frazier
Bro this has been discussed a hundred times. The factory oil cooler is a fairly large restriction on the oil system. By removing it, and allowing oil to be transported easier, you're lessening the load on your oil pump which is something you want to lengthen the longevity of obviously.
Old 05-27-2008, 01:22 PM   #11 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (28)
Can you post a picture of the gasket that is needed to go between the stock gaskets? If you just use 3 stock oil gaskets it will leak. Ptp uses a metal gasket to put in between so a leak doesn't occur.
JnR Performance=envied by many in norcal
Sponsored by DCR
for sale:
mopar cat delete 80 shipped obo
s2 w/toys pcm 260 shipped
iceman 60mm tb $130 obo shipped
s2 injectors 180shipped
reed32 is offline   Reply With Quote
Old 05-27-2008, 02:55 PM   #12 (permalink)
rasp's Avatar
Trader Rating: (15)
DCR uses 3 stock oil gaskets. PTP's is an actual spacer, not a gasket. It's about a half-an-inch of aluminum with 2 holes in it. Not much to see, but it does its job.
Old 05-27-2008, 06:30 PM   #13 (permalink)
Trader Rating: (44)
I just did some research...looks like I should do this since ill be in 400WHP land here sometime soon.Ill do anything to put less strain on the oil pump.
Old 05-27-2008, 06:52 PM   #14 (permalink)
rasp's Avatar
Trader Rating: (15)
If you're in the 400hp department, I'd also remove the balance shafts, add a windage tray and a good pickup tube (or remove the restriction from the stock one) for some added "ease" for the oil pump.
Old 05-27-2008, 08:35 PM   #15 (permalink)
Trader Rating: (30)
how do you open up the stock dumptube restriction rasp? thanx!
