Old 05-23-2007, 05:41 PM   #1 (permalink)
uncommonŠ's Avatar
Member Number: 39843
Trader Rating: (129)
Default How-To: Install Solid LCA Bushings
i used the Energy suspension lower control arm bushings that i purchased from jegs... seen here:
Energy Suspension LCA Bushings
i went into this "blindly" and just did it ... honestly, i thought it was going to be much harder than it was .... i'd say on a scale of how hard this is to do i'd give it a 2 out of 10 ... only thing that is even close to "hard" is having the patience to allow the fire/flames to melt off the stock bushings, besides that it's just simple stuff
Tools needed:
Sockets
Torch
Hammer
Flat head screw driver or something to use to pop out the "insert" in the vertical bushing
Patience
step 1:
Jack up the car & use jack stands. Then remove the wheels.
Step 2:
Remove the bolt that holds in the VERTICAL BUSHING using a 15/16" socket
Step 3:
Remove the bolt that holds in the HORIZONTAL BUSHING using a 21mm socket
Step 4:
Remove the bolt & nut for the ball joint (where it connects to the knuckle) using an 18mm socket for the nut and a 15mm on the bolt. After removing this bolt the LCA will no longer be bolted to the car and should be removed.
Step 5:
Using a hammer, gentily hit the VERTICAL bushing out of the LCA.
Step 6:
Using a torch, light the VERTICAL bushing on fire. Mine took about 10 minutes of being in flames to remove ALL of the rubber from the metal "insert"
Step 7:
Using a torch, heat up the HORIZONTAL bushing. Then using a hammer and a small socket or screw driver, gentily bang out the metal "insert" from the bushing. Then the actual bushing should push right out of the LCA.
Step 8:
Grease the inside and the outside of the (2) halves of the HORIZONTAL bushing. Then install the (2) peices into the LCA. Now, install the metal "insert" into the bushings.
Step 9:
Grease the inside and outside of the (3) peices that make the VERTICAL bushing. Slide the metal "insert" into the largest of the 3 peices, so that the top of the insert is flush with the bushing. Then install teh smallest of the the peices onto that "insert". Now slide what you have just put together, into the LCA so that the bushing pops in & fits snug (there's no way to put it upside down, it only fits right one way). Now take the last peice out of the 3 and pop that into the LCA, completing the VERTICAL bushing.
Step 10:
Install the LCA back into postion on the car. The vertical bushing is going to want to pop out of place, install that portion of the LCA first to insure that it doesn't pop-out/fall-apart.
Step 11:
Re-install the VERTICAL bushing bolt using a 15/16" socket.
Step 12:
Re-install the HORIZONTAL bushing bolt using a 21mm socket.
Step 13:
Re-install the nut & bolt that holds the ball join to the knuckle, using an 18mm socket for the nut and a 15mm on the bolt.
**PASSENGER SIDE requires that you remove the motor mount in order to access the HORIZONTAL bushing bolt**
- remove the 2 bolts that hold the bracket to the motor mount bolt
- remove the motor mount bolt that's located behind that bracket
- remove the motor mount bolt that bolts to the motor
- reverse steps for install
12.4 @ 126 mph on street tires
uncommonŠ is offline   Reply With Quote
Old 05-23-2007, 05:42 PM   #2 (permalink)
uncommonŠ's Avatar
1. Horizontal bushing bolt (top) and vertical bushing bolt (bottom):
2. Bolt & nut for ball joint/knuckle:
3. Stock lower control arms with stock bushings:
4. Stock lower control arms with stock bushings, 2nd pic:
5. LCA with stock vertical bushing (removed):
6. Vertical bushing in flames... i had fun doing this part:
7. Horizontal bushing in flames:
8. Horizontal bushing with metal "insert":
9. LCA with the horizontal bushing removed:
10. LCA with solid bushings laid out for install:
Old 05-23-2007, 05:43 PM   #3 (permalink)
uncommonŠ's Avatar
11. Solid vertical bushing prior to install:
12. Solid vertical bushing installed:
13. LCA with all solid bushings installed:
14. Motor mount bolts & bracket bolts:
Old 05-23-2007, 05:54 PM   #4 (permalink)
nightmare_rebuilt's Avatar
Member Number: 42066
Trader Rating: (39)
where the pics at?
edit: never mind
FloridaSRTOwnersClub.
FS: BUILT SRT4 motor! 3k takes it, needs to go, buying a 68 mustang FL locals only pm me for specs on the motor!
nightmare_rebuilt is offline   Reply With Quote
Old 05-23-2007, 05:57 PM   #5 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (20)
dude you just have time on your hands huh?
DJOrtiz is online now   Reply With Quote
Old 05-23-2007, 06:00 PM   #6 (permalink)
uncommonŠ's Avatar
time .... and grease
damn grease wont come off my hands
Old 05-23-2007, 06:08 PM   #7 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (28)
i'm doing this right now. my ball joints we bent and bushings were smashed. hopefully i will have the car back running before the weekend. i got the same bushing kit too. they don't feel as strong as the stock bushings.
JnR Performance=envied by many in norcal
Sponsored by DCR
for sale:
mopar cat delete 80 shipped obo
s2 w/toys pcm 260 shipped
iceman 60mm tb $130 obo shipped
s2 injectors 180shipped
reed32 is offline   Reply With Quote
Old 05-23-2007, 06:11 PM   #8 (permalink)
td1042k's Avatar
Member Number: 17637
Trader Rating: (12)
i think you got the vertical bushing upside down? isnt the piece with the "skirt" supposed to be on top? thats the way i installed mine...
td1042k is offline   Reply With Quote
Old 05-23-2007, 06:14 PM   #9 (permalink)
uncommonŠ's Avatar
honestly, that's what i was thinking when i was putting it in, but the bushing wouldn't fit in the LCA right if i did it the other way ...... it didn't push together bc the LCA hole for the bushing is larger on one side than it is the other... the way i did it it fit perfectly
if i have to i'll just re-do it again and take more pics but i dont see how it'd fit the other way ... it just wouldn't go back together
Old 05-23-2007, 06:24 PM   #10 (permalink)
uncommonŠ's Avatar
also, i dont have a front swaybar on the car right now, so i didn't have to remove the endlinks.... i'll be adding some pics and adding that to the step's listed above within the next few days
Old 05-24-2007, 01:02 AM   #11 (permalink)
Trader Rating: (39)
do this on my car!! i have had those bushings in my room for a year now.
i will pay you with beer
Old 11-20-2007, 10:35 PM   #12 (permalink)
Member Number: 55997
Default Lca Bushings
Very Very good and helpfull how to, i just did mines today and it was so easy with this thread but i got mine in with the skirt on top like it said in the instructions that came with the bushings. but this is a very good how to and i save like $400. thanks
truekid is offline   Reply With Quote
Old 11-20-2007, 10:45 PM   #13 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (64)
The vertical bushings are installed upside down in your picture. Bushing 3406 should be on top.
Should look like this (not my picture):
EDIT: I just noticed how old this thread is......
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 11-23-2007, 10:35 PM   #14 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (33)
Yes you have them in backwards. Even the instructions for ES shows them the opposite of what you have in that pic.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 12-16-2007, 07:05 PM   #15 (permalink)
gq4life's Avatar
Member Number: 10297
so this doesnt help wheel hop..
rage metal bushing still the best?
2004 Dodge SRT-4
AGP 50trim Turbo
ť Wheel & Tire Center
