Old 04-05-2008, 06:03 PM   #61 (permalink)
madman42's Avatar
Member Number: 55124
Quote: Originally Posted by rbenkemeadow View Post
Leave those behind. Think I cut them back when I started to extend the others. I think those are for V tech and something else.
Thanks, I forgot all about this one also being a Vtech controler.
madman42 is offline   Reply With Quote
Old 04-05-2008, 07:11 PM   #62 (permalink)
rbenkemeadow's Avatar
Member Number: 36456
No problem
KY, IN, OH Safc 2 and Safc NEO install.
rbenkemeadow is offline   Reply With Quote
Old 04-06-2008, 11:45 AM   #63 (permalink)
Member Number: 58308
If you think about it since the NEO is not reading rpms it will throw alot of things off. Do you have the settings set to 0 like I have in the instructions? Also when I test drove my friends I never got past 25 mph and it was for a short distance.
I checked the wires for the from the tach driver and everything is in order but im still having the same problems. i've gone over the wiring atleast 4 or 5 times. Does the location of where u tap into the coil wire matter? cause i tapped into it right next to the pcm. Could it just be a bad tach driver?
matt40282 is offline   Reply With Quote
Old 04-07-2008, 05:42 AM   #64 (permalink)
I might have one. I put a neo in for a friend and when I was done I started the car up and took for a spin. When I looked at the rpm's they were not moving. I took it back and figured it could 2 things. The tach driver is bad (seen it once), or the wiring. I looked at the wiring from the coil and since it was upside down I put the wires from the tach driver to the coil the wrong way. OOPS!!
The wire thats cut on the coil is the first place to look.
Also on line 4 of the main instructions will tell you where to solder in the wires. If you put the driver on the batter tray then look where the wires are located to the coil. Mark the spot then feed the wires down.
Old 04-16-2008, 11:23 AM   #65 (permalink)
Member Number: 56991
Just to let everyone know THAT I TAKE NO RESPONSIBILITY FOR YOUR RESULTS AND YOUR ABILITY.
REMEMBER TO HEAT SHRINK IF YOU CAN ALL CONNECTIONS OR USE ELECTRICAL TAPE.
SETTINGS: These are a little different for the NEO but in the same menu topic.
1. At the main menu select 3. - Followed by 1 Sensor Type.- 3 Pressure- Set "In" to 10 and "out" to
10. Return to the main menu
2. Select 3.- then 2 car select.- Set CYL to 4.- Set "Thr" to the arrow going strait up and to the
right. Return to main menu.
3. Select 2.- Then 3 "TH-Point".- Set low throttle to 20% and high throttle to 90%. Return to main
menu.
4. Select 2.- Then 4 "NE-Point".- Set in order- 1000, 1600, 2200, 2800, 3400, 3800, 4200, 4600,
5000, 5400, 5800, 6200.
That's it!! Settings are now at zero. Now you need a wideband and you can start adding and subtracting fuel
I was want to make sure that these settings are going to set everything to Zero because im on stock Fuel for now I want to wire this kit up.
99.9% Stock!
RaiedZ is offline   Reply With Quote
Old 04-16-2008, 04:41 PM   #66 (permalink)
Need help all. I followed instructions to a T and it seems that when car is off im getting a crazy reading for Throttle! Its jumping everwhere!
Old 04-16-2008, 07:42 PM   #67 (permalink)
While the car and timer is off? The safc is working while the car is off?
Old 04-16-2008, 09:26 PM   #68 (permalink)
Well what its was was that when you run the White/Gray wire into the same wire that is going to the PCM it is getting two different Signals(Throttle and Map) So you actually have to run a seperate wire to the Throttle Cable in the PCM which is a orange with a dark blue stripe in the middle of it. Once I did that everything worked great!
Old 04-17-2008, 04:10 AM   #69 (permalink)
Sounds interesting.
Old 04-18-2008, 03:27 AM   #70 (permalink)
Hemicross's Avatar
Member Number: 60251
do i need to buy an msd tach driver to hook up the SAFC neo or will it work fine without it
Hemicross is offline   Reply With Quote
Old 04-18-2008, 07:13 AM   #71 (permalink)
You have to have a Tac. Our cars do not read RPM's so that is where the Tach will send the signal to the SAFC/NEO for the RPM's. You can find them on here for 40ish or new for 60ish.
Old 04-18-2008, 04:18 PM   #72 (permalink)
The signal from the crank is not strong enough for the SAFC to read. A tach driver amplifies the signal so the SAFC can read your crank turns.
Old 04-20-2008, 02:09 PM   #73 (permalink)
Hemicross's Avatar
ooohhh gotcha, thanks alot, so all i really need is the tach driver, the safc neo and a wideband and i should be good to go on installing everything
Old 04-20-2008, 05:09 PM   #74 (permalink)
For the install yes.
Old 04-22-2008, 02:17 AM   #75 (permalink)
Hemicross's Avatar
ok, i am a little confused on the hook up of the wires for the AFC neo. i understand about the red/white and the red along with the black and the brown running them together since they go to the same place, but the other wires, the white wire is the input signal and the yellow wire is the modified output signal, but you want me to connect the white input signal wire along with the gray wire which is the throttle position signal, i don't understand how that works
Page generated in 0.15910 seconds with 13 queries
