Old 03-27-2008, 11:08 PM   #46 (permalink)
Member Number: 56991
SAFC Neo SHipped out today So I'll be trying this next week. Now I do have an 05 SRT and I will be running Stage 1 PCM anything I should be worried about or aware of?
99.9% Stock!
RaiedZ is offline   Reply With Quote
Old 03-28-2008, 08:54 AM   #47 (permalink)
thanks just PM me or Reply
Old 03-28-2008, 12:19 PM   #48 (permalink)
rbenkemeadow's Avatar
Member Number: 36456
The only thing you have to worry about is sometimes 05's wiring to the pcm might have different color wires. The pcm is not an issue. If for some reason you start the install and you notice the wires are different colors than my instructions, STOP!!!
KY, IN, OH Safc 2 and Safc NEO install.
rbenkemeadow is offline   Reply With Quote
Old 04-02-2008, 08:34 PM   #49 (permalink)
Neo came in today hopefully shoot for install tomorrow. If colors dont match any one know of a diagram of the PCM wires of what wires are what??
Old 04-03-2008, 09:12 AM   #50 (permalink)
Think AGP might have to correct instructions. Would not worry about it to much. It's a long shot for that to happen.
Old 04-03-2008, 09:54 PM   #51 (permalink)
Well good news and Bad news. Wiring harness matches up great to your instructions I didn't actually get a chance to WIRE it yet due to my dumb ass self braking a clip on the White PCM. I broke the clip that holds on the the PCM itself! I didn't pull the Red Release tab up all the way thought I did. Any solutions on how to fix this ??
Old 04-04-2008, 09:22 AM   #52 (permalink)
Member Number: 58308
i just installed my safc neo last night and im not getting a throttle signal or a tach signal. i double checked all my wiring and it seams to be correct what could be causing these problems?
matt40282 is offline   Reply With Quote
Old 04-04-2008, 01:07 PM   #53 (permalink)
So the red clip that you push back to get the plug off broke?
Old 04-04-2008, 01:11 PM   #54 (permalink)
I might have one. I put a neo in for a friend and when I was done I started the car up and took for a spin. When I looked at the rpm's they were not moving. I took it back and figured it could 2 things. The tach driver is bad (seen it once), or the wiring. I looked at the wiring from the coil and since it was upside down I put the wires from the tach driver to the coil the wrong way. OOPS!!
The wire thats cut on the coil is the first place to look.
Old 04-04-2008, 02:40 PM   #55 (permalink)
Its the Black small clip in between the red clip that holds the whole wire thing to the PCM itself.
Old 04-04-2008, 03:40 PM   #56 (permalink)
I guess try push the plug in and then lock it with the red clip. If not you might have to purchase a new plug and run the wires.
Old 04-04-2008, 09:48 PM   #57 (permalink)
i'll check that out tomorrow morning, but i was driving today and whenever i get positive turbo pressure the car starts to sputter. I dont know if its a fuel problem or what cause im not gettin a throttle signal either.
Old 04-05-2008, 08:31 AM   #58 (permalink)
If you think about it since the NEO is not reading rpms it will throw alot of things off. Do you have the settings set to 0 like I have in the instructions? Also when I test drove my friends I never got past 25 mph and it was for a short distance.
Old 04-05-2008, 02:14 PM   #59 (permalink)
madman42's Avatar
Member Number: 55124
Default Wires
Ok I have 4 wires that are not talked about in the how to. What do you do with the orange, blue, pink and purple wires?
madman42 is offline   Reply With Quote
Old 04-05-2008, 05:19 PM   #60 (permalink)
Leave those behind. Think I cut them back when I started to extend the others. I think those are for V tech and something else.
Page generated in 0.15438 seconds with 13 queries
