03-07-2008, 07:34 PM
#31 (permalink )
Member Number: 54160
could i get the settings to put it at zero
03-08-2008, 02:43 PM
#32 (permalink )
Member Number: 58212
I followed these instructions this past Wednesday night and it didn't work for my Neo.
The red AND the red/white wires need to be connected on the Neo harness , and then extend THAT combination of wires down to the PCM.
Otherwise these are very good instructions, but for them to be complete this information has to be added.
To the topic starter and everybody that's contributed information and pictures, THANK YOU!
03-08-2008, 09:26 PM
#33 (permalink )
Member Number: 36456
Quote: Originally Posted by
Nick S
What year is your car? The instructions are different for some 05 pcm's
Ryan
KY, IN, OH Safc 2 and Safc NEO install.
03-08-2008, 09:27 PM
#34 (permalink )
jwren
Sorry I have not got back with you sooner. I just found out why I was not able to post. I will send you a pm tomorrow.
Ryan
03-08-2008, 10:21 PM
#35 (permalink )
rbenkemeadow
Ryan
I have a 2004 but I don't think that matters since the problem was related to the Neo and not my car.
The Neo unit will not power on unless both the red and the red/white wires are connected to the dark blue/red PCM wire.
03-08-2008, 10:56 PM
#36 (permalink )
Nick S
Yes it does matter because like I said some pcms wiring have different colors.
I'll wait and see if anyone else runs into the same problem and edit the first post with the a trouble shoot.
03-09-2008, 09:05 PM
#37 (permalink )
The PCM wiring matched up just fine with your instructions, the missing wire was in the Neo harness.
03-09-2008, 09:40 PM
#38 (permalink )
Nick S
Oh. Was the neo used?
03-09-2008, 09:43 PM
#39 (permalink )
quick question. i put all the setting like the othere thread said and im getting a p108 code? whats the cause of that? safc2 by the way. and cant rev past 4k
03-10-2008, 09:10 AM
#40 (permalink )
Nick S
Honestly sounds like your NEO is one of a kind. I put one in last night with no problems. So It has nothing to do with anything other than your neo.
03-10-2008, 09:14 AM
#41 (permalink )
jwren
Jwren,
******Updating the original post with the settings.******
As for your code, pull the negative battery wait, put it back on then put the settings to 0.
03-10-2008, 12:00 PM
#42 (permalink )
i still get the code
03-10-2008, 06:31 PM
#43 (permalink )
jwren
Did you put the settings to zero 10 in and 10 out?
The only thing I can think of is to swap out map sensors or re-check the wiring to the SAFC.
03-24-2008, 03:34 PM
#44 (permalink )
How is everything jwren
03-24-2008, 11:53 PM
#45 (permalink )
havent tried it since i gave up im waiting to fix my tranny so im just taking a break
Linear Mode
» Site Navigation
> Other Vehicles
» Buyers Guide
» Network Links
