Old 09-05-2009, 09:13 AM   #226 (permalink)
Ude Lose's Avatar
Member Number: 4562
Trader Rating: (31)
""Select 2.- Then 4 "NE-Point".- Set in order- 1000, 1600, 2200, 2800, 3400, 3800, 4200, 4600,
5000, 5400, 5800, 6200 """""
I have a regular safc and i can only adjust the settings in incriments of 500.
Example= 1000, 1500, 2000
I cant get to 1600 or 2200. what should i do?
Ude Lose is offline   Reply With Quote
Old 09-05-2009, 09:15 AM   #227 (permalink)
Ude Lose's Avatar
Member Number: 4562
Trader Rating: (31)
Quote: Originally Posted by RaiedZ View Post
Need help all. I followed instructions to a T and it seems that when car is off im getting a crazy reading for Throttle! Its jumping everwhere!
I had this problem as well. When te car was off the throttle was jumping around at near 57% and fluctuating. Then when i drive the car i can be at 3/4 throttle and it will tell me im at 100%. Or i can be barely even giving it gas and it won't read any throttle at all.
Old 09-07-2009, 11:27 PM   #228 (permalink)
rbenkemeadow's Avatar
Member Number: 36456
Try looking at the wire connections to your tach driver and coil pack. It's possible the tach driver is going bad.
KY, IN, OH Safc 2 and Safc NEO install.
rbenkemeadow is offline   Reply With Quote
Old 11-05-2009, 01:04 PM   #229 (permalink)
Member Number: 59695
heres my question. if i want to mount the neo beside my boost guage how are you guys doing that>? the stand you can buy for them looks to big to fit there.
Brandon100887 is offline   Reply With Quote
Old 11-06-2009, 11:26 PM   #230 (permalink)
You can wedge it under the dash. If you look in some of the pics on pages 1-5 I think I have a pic of how mine was kept.
Old 11-07-2009, 12:16 AM   #231 (permalink)
Sceanzo's Avatar
Member Number: 65430
How come your "factory settings" are different from the ones in the AFC discussion thread?
You say 20% low 90% high
the other thread says 10% low 40% high
Sceanzo is offline   Reply With Quote
Old 11-08-2009, 02:05 PM   #232 (permalink)
Becasue that pic was taken after I tested it out and started tuning. The pics I took in this thread say this is where I placed mine, not this is what yours should read with factory settings. I wasn't about to make this how to if it didn't work.
Old 11-08-2009, 10:06 PM   #233 (permalink)
i gots a problem. i dont have a dark green with red stripe wire on the orange pcm plugin. all i have is 2 light green with orange stripe wires.and a light green with white stripe i think. also another problem is when i did hook this up i went and set my settings on the neo. i turn off car cuz it was idling like a cammed out monster truck turn it back on and none of my setting are saved, any reason why? i dont have a msd thingy yet but its otw. i was jus gonne hook up what i could then finish it up. or can i not do that.im frustrated lol my car is a 2004 btw. thanks for any infoalso when i hooked it up i just cut where the dark green with red stripe wire was but the map sensor and ran it ttemp that way to see how everything was. nothin was working on neo is that cuz no coil signal due to me not having msd tach driver? all neo does when i goto dual monitor it flashes buttons on and off along with the bat symbol
Old 11-13-2009, 07:39 PM   #234 (permalink)
Member Number: 69713
Are there any pics on this?
Gabby is offline   Reply With Quote
Page generated in 0.13670 seconds with 13 queries
