How-To: Install a Foward Motion E1 Turbo - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 04-11-2007, 07:07 PM   #16 (permalink)
srt4_riceater's Avatar
Member Number: 22900
YES!!! This is what I was looking for! I'm installing the E1 w/ Aarons Race Manifold from Realtune. I didn't want to have to follow 50 trim install by AGP.
Good lookn' out bro. Nice job.
s2 w/out toys, E1, Realtune mani w/ Turbonetics external gate/dump. DCR 500WHP bottom-end (.20 over), Wiseco pistons, and oil pump and big filter kit. AGP Race FMIC, JMB PP's, DSP, JMB CC, Port/Polish Intake and Lorenzo 55mm TB w/ spacer, Dog Bones, MaxFab full 3" side exit, CoolingMist water/meth injc, IPP coilovers, AEM UEGO, Autometer Pyrometer EGT, Greddy Type RS BOV, K&N Gen II Air Intake Kit, stock solenoid bc, Walbro pump, Lorenzo 55mm TB.
srt4_riceater is offline   Reply With Quote
Old 04-11-2007, 07:13 PM   #17 (permalink)
icebomb's Avatar
Member Number: 27487
Quote: Originally Posted by TurboMoparGod
Quote: Originally Posted by icebomb
Is it me or did his instructions say to reuse the non-reusable crush washers for the oil and coolant feed lines?
I've reused mine with no problems.
Hey, it's just me but I'd rather replace the $0.50 washers than chance it. Oh well, what do I know right?
2008 SUZUKI GSXR1000000
icebomb is offline   Reply With Quote
Old 04-11-2007, 07:18 PM   #18 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
If I had new ones I would have installed them.
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's untuned
E1 Turbo 12.48@115mph DR's slipping stock clutch untuned
E3 47lb Turbo 1/8 7.92@93.67 1.95 60' 235/60/15 DR's untuned
TurboMoparGod is offline   Reply With Quote
Old 04-11-2007, 07:20 PM   #19 (permalink)
so.. now that it's installed, what do you think of your new turbo? let us know? are you running the stock manifold? i'd be worried about restriction.
Old 04-11-2007, 07:31 PM   #20 (permalink)
Are you talkin to me?
Old 04-11-2007, 07:38 PM   #21 (permalink)
Member Number: 14149
Good luck finding the oil feed washers.
I had to purchase the oil feed line assembly,(thanks S&P)
to get the correct washers, this is after I've waited 3 weeks for the
dealer to try to find the right ones.
Good thing the assembly was only $10.
04 SRT-4
86 GLHT- 13.17@ 95.85
keito is offline   Reply With Quote
Old 04-12-2007, 02:19 PM   #22 (permalink)
no. srt88. the person that did the how to?
how do you like your new E1?
Old 01-27-2008, 11:14 PM   #23 (permalink)
Scammer
Member Number: 46111
You better reuse the crushers because they are the hardest part to find for the car. I lost mine and i was burning oil for one day runnin to 3 different dealershipes that either didnt have it or was the wrong size. Lucky i found my old washer on the floor. LUCK! Yea i got quoted 300 for a e1 install by a shop. WTF. Screw that do it yourself with some mecanical inclined.
BoostinByeU is offline   Reply With Quote
Old 11-03-2008, 03:02 AM   #24 (permalink)
JSLsSRT4's Avatar
Member Number: 59702
i dont know about you guys but i am about halfway getting my turbo off (had to go to work) and I just undid the rubber hoses going to the coolant return lines... i never broke the bolts loose in the back of the turbo and it seems like i can get it out just as easy that way... ive heard this tip before
Orange Blast 05 - New Hotness
AGP S3 D44 turbo kit, STAGE 2 w/o toys! SAFC2, AGP 3" CAI, MPx 3" exhaust no Cat/4"tips, BFMIC, HKS BOV + Cold Side Pipe, Vacuum Line retrofit, Walboro HF Pump, FFP ported Intake MF, AEM Eugo WB, Eibach Anti-Roll Kit, DC Sports front and rear Strut Bars, Tons of Visual Mods,
fuel mods - highflow pump, SAFC2, RC 650 Injectors injectors, AGP fuel return line, AGP fuel pump re-wire
JSLsSRT4 is offline   Reply With Quote
Old 09-24-2009, 06:33 PM   #25 (permalink)
Member Number: 72831
This helped me so much...Thank you very much!
bigboostinsrt is offline   Reply With Quote
Old 10-08-2009, 11:46 AM   #26 (permalink)
jeffjohnson's Avatar
Member Number: 58519
if you lower the charge pipe it makes life so much easier and all it is, is 2 nuts on the bottom of the car. i promise it will cut off 15 minutes of fighting with the charge pipe puttin the turbo back on.
jeffjohnson is offline   Reply With Quote
Old 10-11-2009, 11:21 PM   #27 (permalink)
Member Number: 3578
Agreed. This is worthwhile.
I took mine off with that in mind, but also to make sure I didn't lose one of the oil drain bolts down it.
Sure enough it was in there.
**Scammed by Resin8** NEX coilover groupbuy
2004 SRT-4 Black
1998 Neon R/T Turbo Black
Trinity injector/3 bar rescale by Turbo666
98rt_canadian is offline   Reply With Quote
Old 01-14-2010, 09:40 PM   #28 (permalink)
CptNemo's Avatar
Member Number: 50454
Default E1......
So........ do you like it? Was there a generous increase in power? Was a tune necessary? Im interested in getting one and cant make up my mind between the foward motion and a delta 44.
Yes officer, I know why you pulled me over. you want my autograph.
CptNemo is offline   Reply With Quote
Old 02-22-2010, 06:23 PM   #29 (permalink)
CptNemo's Avatar
Bump. Is there anyone who has the e2? Just ordered mine and wanted to hear what everybodys experiances have been.
Old 02-23-2010, 11:22 AM   #30 (permalink)
SRT of the Month
Black Beast's Avatar
Member Number: 51114
to the OP and everyone else, why fight the charge pipe? Just loosen the bolts that hold it up under the motor then put the turbo on the pipe will slide rite on after that
Black Beast is offline   Reply With Quote
