HOW-TO: Install AEM UEGO Wideband - Page 20 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 07-12-2011, 10:31 AM   #286 (permalink)
Member Number: 83060
This is to hard for me to do. I may need someone to do this for me.
omar92337 is offline   Reply With Quote
Old 08-08-2011, 02:08 PM   #287 (permalink)
Member Number: 85795
not sure if anyone told you but the blocks should be the other direction for load bearing.. used to work a block plant just dont want anyone to get dead.. 3000+psi with holes up and down
Jrob81 is offline   Reply With Quote
Old 08-08-2011, 06:00 PM   #288 (permalink)
STEELEBOOSTIN's Avatar
Member Number: 81335
Quote: Originally Posted by RUgoinUp View Post
Breaker bar.
update, i had no room for leverage with the breaker bar, and nothing else seemed to be working, so I torched the crap out of the bung! it loosened up and all i needed was a small normal ratchet. Torch FTW!
dsp tuned, AEM wideband, FM wastegate and lots of other shiz.
STEELEBOOSTIN is offline   Reply With Quote
Old 08-09-2011, 03:28 PM   #289 (permalink)
RUgoinUp's Avatar
Member Number: 181
I didn't have much room either, but I still got it...along with a busted knuckle when it came free.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, use God's name in vain? Those are only 4 of the 10 Commandments. Breaking 1 condemns U 2 Hell. Claiming 2 be a good person won't work in court or when U stand before God. If U want Heaven, admit you're guilty, then ask God 2 forgive U solely on Jesus' death on a cross as payment 4 your sins. Then love God with all your heart and people 2.
RUgoinUp is offline   Reply With Quote
Old 08-09-2011, 03:58 PM   #290 (permalink)
Member Number: 85851
great info. mine came with a aem installed, but ive done a few before, great writeup to follow!
z28eater is offline   Reply With Quote
Old 08-26-2011, 05:17 PM   #291 (permalink)
Member Number: 85918
Great post it is very helpful.
SoonerSRT-4 is offline   Reply With Quote
Old 09-25-2011, 07:13 AM   #292 (permalink)
Whiteout2011's Avatar
Member Number: 85405
So is the blue wiper wire the safest? And does the wire just pull right out?
Tuned by Nigel@BST
Whiteout2011 is online now   Reply With Quote
Old 10-09-2011, 07:12 PM   #293 (permalink)
DeeSRT4's Avatar
Member Number: 79972
well im bout to install my wideband this week. and im placing mine beside my stock boost gauge.
04 SRT-4
"STOCK TURBO" , Mopar Stage 2, AEM CAI, Godspeed Bfmic, Needswings 3" cutout/catted, DSP handheld tuner, Boomba solid mounts, Mopar short shifter, Granettli wires and Iriduim plugs
12.96 @106 1.8 60'
UNTUNED
8.18 @ 86 1.8 60'
DeeSRT4 is offline   Reply With Quote
Old 10-27-2011, 06:31 PM   #294 (permalink)
SRT505A's Avatar
Member Number: 64838
please becareful putting the wires through the boot. did mine last night and everything was fine till i made a U-turn and it ripped my wires off the sensor. my battery died so i had to recharge it at autozone and ordered new wires on modernperformance.
easy install! but im gonna go through the fire wall next time
annnnnd i used the "add a fuse" at autozone for $5 just so i dont have to split through wires
good luck everyone
SRT505A is offline   Reply With Quote
Old 10-27-2011, 06:32 PM   #295 (permalink)
SRT505A's Avatar
i just put a "add a fuse" instead of cutting the blue wires. easier faster and safer
Old 10-27-2011, 06:33 PM   #296 (permalink)
SRT505A's Avatar
where in cali are you located?
Old 11-02-2011, 08:10 PM   #297 (permalink)
slo_04's Avatar
Member Number: 77383
just did this today split the blue wire and went thru the boot. ive had the ugeo for over a year had to put it on. looks clean but i need to go thru the fire wall so gonna redo it tomarrow
slo_04 is offline   Reply With Quote
Old 12-23-2011, 07:11 AM   #298 (permalink)
Member Number: 43353
If you use the blue wires for the wipers does the wideband shut off when you actually use the wipers??
DavidSRT-4 is offline   Reply With Quote
Old 01-30-2012, 09:15 PM   #299 (permalink)
zman17's Avatar
Member Number: 87469
spool bus
MODS: garret 60-1 trim kit Tial wastegate ATP o2 and manifold ,boost box,return line, AEM CAI, wally 255, innovative motor sports wideband, dusters injectors, Godspeed BFMIC, tuned by duster360 for gas and e-85
zman17 is offline   Reply With Quote
Old 02-06-2012, 12:24 PM   #300 (permalink)
If you can find the how-to on the e-cutout install there is a great place to drill a small hole under the center console. I already had mine so i just wired my wideband right through through there and bam! really easy
