Old 01-27-2009, 09:11 PM   #1 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (39)
Default How-To: Home Depot Radiator Pipe
Well first big thanks goes to SRToad4 for coming up or at least posting the idea.
1. Go to Home Depot and in the plumbing section, in the sink repair pieces you'll see a 1 1/2 diameter and 15" long metal pipe(long L shaped) part number H2138C-2, buy that and also buy two or four worm clamps while you're at home depot.
2. Next you'll need to trim the head after the bend. If you have some heavy duty scissors you'll be able to cut it or you can use a grinder to trim it. Be careful not to alter the roundness of the pipe.
3. Now you'll need to sand the rough part, so you dont rip or damage the rubber which it'll attach to.
4.At this point you have to decide if you want a polished look or painted. I hate the polished look in everything so i took the painted way.
5. If you decide to polish it take out some mothers polish and start polishing it.
6.If you decide to paint it take out a sand paper(preferably 350 or larger) and wet sand it.
7. Next use some liquor thinner and make sure no dust is left on the pipe.
8.Now you'll be priming the pipe. I highly suggest you use hi heat primer so it wont start peeling after a few heat cycles.
9.Wait until the primer is dry and apply the paint of your choice. Again make sure to use hi heat paint.
10.Next is optional, you could clear coat it to give it some protection and little shine to the paint so thats up to you.
11.Wait a day for the paint to cure before touching the pipe.
12.After the pipe is dry follow the how to drain coolant how to to drain your coolant.
13. Next take out the clamps which hold the rubber radiator pipe to the thermostat housing and the radiator.
14.At this point before cutting the rubber make sure to put the metal pipe over the rubber to see the fitment. I prefer to have it more similar to the stock and jmb's rather then what SRToad4's look so i will be cutting it further down so this is up to you to decide how you want to angle the pipe.
15.After you cut the rubber pipe, stick the metal pipe in it. It might me a tight fit but it'll go in after a few wigglings(sp?). You could also use some type of a grease, WD-40, etc.
16.After its in, use the worm clamps you bought earlier and clamp the rubber to the metal pipe.
17. Put the piping back into the radiaotr outlet and the thermostat housing.
18. Refill the coolant, and after you start the car make sure you have no leaks. Drive around for awhile and check again to determine no leaks.
19. Use some rubber shine on the rubber section of the piping and enjoy your latest ghetto mod.
CJsStocker is online now   Reply With Quote
Old 01-27-2009, 09:13 PM   #2 (permalink)
CJsStocker's Avatar
Trader Rating: (39)
Will upload the rest of the pics once i have some more free time.
Old 01-27-2009, 09:40 PM   #3 (permalink)
Member Number: 59422
Trader Rating: (35)
Nice find how much did the pipe run you? Nice little piece to accent the bay without spending a lot of money.
04Eblue is offline   Reply With Quote
Old 01-27-2009, 09:45 PM   #4 (permalink)
BrandynSRT's Avatar
Member Number: 63412
Trader Rating: (25)
yeah it is.. better than spending $85
BrandynSRT is online now   Reply With Quote
Old 01-27-2009, 09:50 PM   #5 (permalink)
CJsStocker's Avatar
Trader Rating: (39)
well there was a home depot on way to school so it costed me 9 with tax and i had clamps laying around at home so they were free.
and yes its better to spend 9 then 10x more to the jmb one but that has a really good quality powdercoat and the bend is a little longer which makes it look more legit.
Old 01-27-2009, 10:19 PM   #6 (permalink)
Senior Moderator
kritical's Avatar
Member Number: 49262
Trader Rating: (138)
great write up!
stock
kritical is offline   Reply With Quote
Old 01-28-2009, 06:21 AM   #7 (permalink)
SRToad4's Avatar
Member Number: 61889
Thanks guys, I want to see everyone rocking the HDR Hard Pipe for the year 2009! It's legit, and $9 is so much > $90....
Let's see more of your HDR Pipes!!!! (HDR = Home Depot Racing )
Tuned by Tony @ UMS Tuning
390whp/380tq @ 21.5psi / 91 + Meth
SRToad4 is offline   Reply With Quote
Old 01-28-2009, 06:05 PM   #8 (permalink)
SRT-4runner's Avatar
Member Number: 68134
Trader Rating: (36)
Pics of the finished product!
Vtec Slayer
SRT-4runner is online now   Reply With Quote
Old 01-28-2009, 08:26 PM   #9 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
mine's is the polished finish
Crane 14's
Ragin_SRT is online now   Reply With Quote
Old 01-28-2009, 09:49 PM   #10 (permalink)
Senior Moderator
kritical's Avatar
came out real good! ^^
Old 01-28-2009, 09:54 PM   #11 (permalink)
hmrn4gater15's Avatar
Member Number: 56581
Trader Rating: (37)
did everyone empty coolant? cuz i know Toad didnt.
hmrn4gater15 is offline   Reply With Quote
Old 01-28-2009, 10:09 PM   #12 (permalink)
smctoy's Avatar
Member Number: 62758
great write up!!
smctoy is offline   Reply With Quote
Old 01-29-2009, 05:42 AM   #13 (permalink)
SRToad4's Avatar
Yeah, I just simply drained the coolant out of the pipe section by using a funnel into a large container
Old 02-02-2009, 07:35 PM   #14 (permalink)
keefssrt4's Avatar
Member Number: 55737
Trader Rating: (24)
Post
great idea its call a 15" waste arm for sink drain get a copper tubing cutter to cut that pipe without bending or damaging it not to crash the thread but lil bit info to help u out on the how to great job on it
keefssrt4 is online now   Reply With Quote
Old 02-02-2009, 08:13 PM   #15 (permalink)
srtmatty's Avatar
Member Number: 65788
nice, i might do this during the weekend
MOPAR MADNESS
srtmatty is offline   Reply With Quote
Page generated in 0.19692 seconds with 13 queries
