Old 04-12-2008, 05:35 PM   #1 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (27)
Default How-To: Eliminate Stock Solenoids
If you are tired of those annoying solenoids taking up space in your engine bay, making it all cluttered, this is for you.
First things first, you must have the following mods to do this:
Aftermarket wastegate actuator
*EDIT: after some speculation with a fellow i have removed the aftermarket bov requirement as it is not totally necessary.*
Or a big turbo kit, that will take care of it too.
The total cost of this mod is a whopping $1 (for the resistors)
Materials needed:
Electrical tape
(3) 33 ohm 1/2 watt resistors
Vacuum line
Zip ties
Tools needed:
Knife (to cut vac line)
Zip tie tightening tool (a must have, period)
Now with the procedure.
Go to RadioShack, and get a pack of 33 ohm 1/2 watt resistors, be sure that they are NOT 33k ohm. If they don't have them there, find a local electrical supply shop and get them there, or they are all over the place on the internet. See pic below.
Then go to the car, take out the blue, black, white, red, pink, green vac lines out if they are still there. Refer to one of the many vac line diagrams to see where everything should go. Run your new vac lines, zip tie them, and then tighten the zip ties with the much needed tightener. For the people wondering about taking out the red and white lines for the tip sensor, they are not needed, with it not on a vac line, you wont get PTB codes anymore, and it will not cause any adverse effects, its only purpose is to make sure theres a pressure difference between before and after the tb. Then unplug all the solenoids and box them up. Then take one resistor, bend it up so that it fits into the plug that was on the solenoid tightly. See pic below.
Repeat for the other solenoids.
Now, all you need to do is wrap up the plugs and tuck them away. Be sure not to let either side of the remaining wires on the resistors to touch, this will fry your pcm and battery. Put a generous helping of tape on there just to be safe. See pic below.
Now, just tuck them away, i put mine in the little slot behind the driver's side headlight, out of sight, out of mind.
Here's the vac line diagram you want to use for this mod: (ignore the white line on the right side, that can be removed too)
Now you have cleaned up the engine bay a bit, and best of all, NO CODES!
Just for reference, heres a pic of my engine bay, as you can see, i have some other crap where the solenoids used to be.
For the guys that want to know how this works, its simple. The solenoid has a certain resistance between the two pins on its connection. You can confirm this with a standard multimeter set on ohms(resistance) and put the two electrodes on the two pins. This resistance is 33 ohms. So when you put the resistor in the plug, it simulates to the pcm that the solenoid is plugged in, thus no codes.
SkittlePower is offline   Reply With Quote
Old 04-12-2008, 05:36 PM   #2 (permalink)
Trader Rating: (27)
somebody please sticky this, i get questions about it and have to explain it all the time. and if anyone has anything to add, please do, i will edit the first post accordingly.
Old 04-12-2008, 05:48 PM   #3 (permalink)
TSRT4's Avatar
Member Number: 22812
Trader Rating: (26)
Interesting, so since the pink line is gone will I need to cap the surge valve nipple?
TSRT4 is offline   Reply With Quote
Old 04-12-2008, 06:02 PM   #4 (permalink)
Trader Rating: (27)
if you are running the stock surge valve, you need the PTP upgraded spring for it, and run a vac line from the tb to the surge valve.
Old 04-13-2008, 11:22 AM   #5 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (46)
I just kept mine connected,ditched all the vacuum lines,stuck a ziplock bag over the solenoids and ziptied it to the upper driverside wheel well.Lol,works great!Nice write up though man,later.
-Frazier
WTB : BORG WARNER S256 TURBO - PM ME CASH IN HAND!!!
FraziersSRT is offline   Reply With Quote
Old 04-13-2008, 11:28 AM   #6 (permalink)
RedlineRacer4's Avatar
Member Number: 40182
i have to consider this i hate those damn solenoids they look like shit
K&N POS CAI,Mopar Stage 1,Mopar STS,DC F/R strut tower bars,AGP Solid MM,$20 catch can, PTP CV,PTP BOP, PTP Hard pipes w/HKS SSQ
13.27 @104.86 mph on street tires
RedlineRacer4 is offline   Reply With Quote
Old 04-13-2008, 02:58 PM   #7 (permalink)
Toofpaste39's Avatar
Member Number: 17599
Trader Rating: (23)
Snap a picture of your engine bay.
Toofpaste39 is offline   Reply With Quote
Old 04-13-2008, 05:50 PM   #8 (permalink)
Trader Rating: (27)
^^first post edited to include a pic of my engine bay.
Old 04-13-2008, 07:07 PM   #9 (permalink)
TSRT4's Avatar
Trader Rating: (26)
Whats that huge hose on the intake?
Old 04-13-2008, 07:22 PM   #10 (permalink)
Trader Rating: (27)
its a recirculation line going from my greddy type s bov to rerouted to the intake. its in preparation of my home-made super stock turbo that im making, so that i can save the thrust bearing. see, i have the bov set to be open all the time except in boost, this way, i get NO turbo flutter, and its the fastest acting bov you will ever see, and thus saves the thrust bearing, which i havent figured out how to make stronger like the sst's, but i have gotten some help with the journal bearings.
Old 04-18-2008, 10:11 AM   #11 (permalink)
Trader Rating: (27)
bumpity
Old 04-19-2008, 04:00 PM   #12 (permalink)
rbenkemeadow's Avatar
Member Number: 36456
Trader Rating: (15)
Nice write up!! Might try this.
KY, IN, OH Safc 2 and Safc NEO install. Send me pm for more information.
rbenkemeadow is offline   Reply With Quote
Old 04-19-2008, 04:03 PM   #13 (permalink)
Trader Rating: (27)
thanks man. its cheap, easy, fast, and makes the engine bay much cleaner and frees up a lot of space.
Old 04-19-2008, 05:10 PM   #14 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (26)
bump subscribed!
Sponsored by
Ragin_SRT is offline   Reply With Quote
Old 04-25-2008, 04:37 PM   #15 (permalink)
Member Number: 31650
did you have any issue with the 1/2 W
because if you check the power should be around 4.5W (5W)
sure those solenoide are not 100% on, all the time so 4.5W is probably a bit on the safe side
Not stock anymore
