Old 06-09-2009, 04:33 PM   #1 (permalink)
05_ACR_SRT4's Avatar
Member Number: 61818
Default How-To: DCR Oil Flow Modifier
First off you start with the basic tools you will need.
(1) socket wrench
(1) socket extension
(1) 10mm socket
(1) 8mm socket
(1) torque wrench
(1) Latex Gloves
(1) Razor blade
(1) High Temp Sealant
(1) A cool engine (dont want to get burned)
1) First step, unplug the PCV system as shown below
2) Next, unplug spark plug wires and use 10mm socket to remove the four bolts that hold the coil pack as shown below
3) Remove the coil pack.
4) Next, you want to get your 8mm socket and remove all (9) valve cover bolts as shown below
MODERATOR EDIT:See post #2 for proper VC removal/Reinstall
5) Now that the bolts are removed, gently lift and remove valve cover without ripping gasket (we will be reusing the same one to put it back on)
6) You will see in the picture below, (3) bolts holding the cam shaft (next the the cam position sensor) Remove the (2) 10mm bolts and the (1) 8mm bolt, also you want to take the 8mm rear bolt from the cam sensor off. Once this piece is off, you want to get the razor blade and start scraping off the sealant...keep in mind where the sealant is, because we will be reapplying new sealant.
7) Next install the DCR Oil Flow Modifier in the oil journal location circled in red, gently slide in down with the cross drilled end facing down as shown below.
8) And there you have your DCR oil flow modifier installed! Next is to put that piece that you removed back on with a very thin layer of sealant(thin layer because we don't want any sealant going to where the oil flow modifier was installed). Torque the (2) 10mm bolts to 200 in/tq, and the (1) 8mm bolt to 125 in/tq. Next you want to install the bolt from the cam sensor back on. Once you are done with that we can now reinstall the valve cover, torque the (9) 8mm Valve cover bolts to 120 in/tq. Reinstall the coil pack and plug wires, next install the PCV system again. Once everything is connected and installed, turn car on and let it run until it reaches operating temperature, once that is completed you can drive away or turn off the vehicle. YOU DONE!
I hope the Write-up will help some of you out there! and if i missed something please let me know! THANKS!
- Dinesh
05 ACR Srt-4, RC 650's, N2MB WOT box/ 2step, AEM WB, Stock WGA w/PTP spring, AEM CAI, MPX 3" o2 Housing, AGP (3) Mounts, CHQ 3" catless DP, AGP hardpipe w/HKS bov, DS Predator with custom PTP tune, 3 Bar map/tip sensors, CBD CF eyelids, CBD CF C-pillars, DCR oil flow modifier, 180 T-Stat, CBD CF Chin spoiler, PTP fuel pump rewire, walbro 255lph pump,PTP Meth kit, PTP Intimidator Mani, PTP S3K @ 26psi(with meth)
05_ACR_SRT4 is offline   Reply With Quote
Old 06-09-2009, 06:25 PM   #2 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
This should be helpful:
CYLINDER HEAD COVER INSTALLATION
CAUTION: Do not allow oil or solvents to contact
the timing belt as they can deteriorate the rubber
and cause tooth skipping.
(1) Clean cylinder head cover sealing surface.
(2) Install new cylinder head cover gasket and spark plug well seals.
(3) Apply Mopart Engine RTV GEN II at the
camshaft cap corners and at the top edges of the 1/2
round seal (Fig. 41).
NOTE: Inspect cylinder head cover fastener seal
washers. Replace as necessary.
(4) Install cylinder head cover assembly to cylinder
head. Install all fasteners, ensuring the double
ended studs are in their proper location. Tighten fasteners
in sequence shown in (Fig. 42).
Using a 3 step
torque method as follows:
(a) Tighten all bolts to 4.5 N?m (40 in. lbs.).
(b) Tighten all bolts to 9.0 N?m (80 in. lbs.).
(c) Tighten all bolts to 12 N?m (105 in. lbs.).
(5) Install nut securing coolant return line bracket
to cylinder head cover stud (Fig. 38).
(6) Clip wiring harness to cylinder head cover
studs (Fig. 37).
(7) Install ignition coil and connect spark plug
wires. Tighten ignition coil fasteners to 12 N?m (105
in. lbs.) (Fig. 37).
(8) Connect ignition coil connector.
(9) If the PCV valve was removed from cylinder
head cover, apply Mopart Thread Sealant with Teflon
to threads and install valve to cylinder head cover.
Tighten PCV valve to 8 N?m (70 in. lbs.).
(10) Connect PCV and make-up air hoses to cylinder
head cover (Fig. 37).
(11) Connect negative battery cable.
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 06-09-2009, 06:37 PM   #3 (permalink)
gargoile's Avatar
Member Number: 931
Very nice writeup guys. Well gone. The photos will help a lot of people here.
+ 2008 One Lap of Atlanta
Stage 2 #2 1st one with Toys
How many of our country's problems could be solved – and solved quickly – if politicians were more worried about what is good for our country rather than how to protect their positions of power?
gargoile is offline   Reply With Quote
Old 06-09-2009, 07:46 PM   #4 (permalink)
Awesome! Thanks for the help!
MODERATOR EDIT: You're welcome.
Old 07-12-2009, 05:19 PM   #5 (permalink)
Member Number: 50616
Are one of these oil modifiers really needed??
98R/T is offline   Reply With Quote
Old 07-12-2009, 09:36 PM   #6 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
Needed? No.
Old 07-13-2009, 04:06 PM   #7 (permalink)
so whats the REAL purpose???
Old 07-14-2009, 08:19 AM   #8 (permalink)
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (33)
DCR Top end modifier
This is the original thread on it. I would go to that forum Darrell Cox Racing - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum and ask those who used it if the manufacturer's performance claims were gained.
Old 07-15-2009, 01:57 PM   #9 (permalink)
Member Number: 18939
I have had mine for a while and do notice the car pulls from 5500 to 6200 a little smoother than it did stock and doesn't feel like the power drops off above 6000rpm.
2004 Flame Red SRT-4 - 14.298 @ 95.5 - Stock
K&N Filter, DCR Oil Mod, Chargepipe Mod, DIY Hotside Pipe, In-Car Bleed Valve, 180º T-Stat, Prothane MM Inserts.
PM me if you are in the market for Guitars, Drums, Recording equipment, Etc for the SRTForums discount!
Fast420A is offline   Reply With Quote
Page generated in 0.19335 seconds with 13 queries
