Old 04-18-2005, 04:20 PM   #1 (permalink)
plastick's Avatar
Member Number: 19889
HOW-TO: A'PEXi AVC-R EBC & MSD Tach Driver Install
A'PEXi AVC-R EBC & MSD DIS-2 Tach Driver: Step-by-step Install
Note: I have included the DIS-Tach Driver in this how-to, simply because most people have to buy one with the AVC-R (or any other EBC that uses specific RPM functions) in order to get a clear RPM signal from the coil.
Here goes!
The AVC-R is pretty challenging and long to install, but if you do it right and take your time, the final result is rewarding. So let's start, shall we?
Tools you will need:
-Zipties
-Full socket set
-Large set of male and female electrical crimp connectors
-Philips head screwdriver
-Flathead screwdriver
-Standard & needlenose pliers
-A bunch of electrical tape
-Scissors
-Wire stripper/cutter, or if you're like me, you can use your teeth + fingernails
-TIME
-Patience!
Highly reccomended:
-Soldering iron w/ any gauge core solder
-Garage service lamp
-Xacto knife
Let's start with the easy part: The MSD Tach Driver.
==BEGIN INSTALL==
The first thing you'll need to do is remove your intake airbox and tubing to gain some free space, as well as your battery. Behind the battery (directly below the terminals on the battery tray) is a single 13mm bolt that holds the battery down against the tray. Use a couple of socket adapters to reach it, torque it out (it may be rusted in, don't be affraid to push hard) and remove it. Place it in a safe spot so you don't lose it.
Reach behind the battery and remove the metal piece that was clamped down by the bolt. Put this in a safe place as well.
Next, use a set of pliers to unscrew the nut on the NEGATIVE battery terminal. Remove the nut completely and set it asside. The reason you are completely removing the nut is so you may later attach the ground wire from the DIS-2 to the negative battery cable.
Now unclip the connected wire on the sleeve that is around the battery, remove the sleeve and set it asside. Also, remove the battery.
You should now have quite a bit of room to easily work. Now you need to locate the wire running off of the coil pack (on top of the valve cover where your spark plug wires are connected). Remove wires 3 and 4 from the coil pack to give yourself more room, then unclip the wire from the coil pack to make it easier.
Next, you should see a spot where the coil pack wire harness runs down along the side of the engine (driver's side). There will be a spot where it merges with another set of wires and wrapped in tape. Remove the tape and aluminum mesh wire sheathing to access the wires. There are three wires, but you'll only be dealing with one.
Next, get your set of wire cutters and CUT the GREEN WIRE WITH BROWN STRIPE (from the coil pack wiring harness) in half. Use your wire strippers to remove a section of insulation off of each seperated end, exposing the bare copper wire within.
Now, connect the RED WIRE WITH GREEN STRIPE FROM YOUR TACH ADAPTER to the newly-cut green wire with brown stripe going TOWARDS the coil pack on top of the valve cover. Twist them together and solder them properly. Attach the SOLID RED WIRE FROM YOUR TACH ADAPTER to the other end of the severed coil wire that goes down into the engine bay. Solder this as well.
Next, wrap everything up in electrical tape + zip ties to make sure nothing shorts or comes loose. At this point you can decide exactly where you'd like to mount your tach adapter (I zip tied mine to the back of the brake fluid reservoir).
Once all your wires are wrapped in wire loom and tape and neatly mounted, you can replace your car battery. Put the battery sleve back on and attach the connector in the back. Now attach your positive battery terminal. Now slide the BLACK WIRE FROM THE TACH ADAPTER (this is GROUND) over the bolt on the NEGATIVE battery terminal connector, then attach the nut and torque it down on the battery. Replace the metal plate mount for the battery and the bolt, tighten it down. Replace your airbox/intake tubing and make sure everything is in place. (NOTE: If you are also installing the AVC-R at this time, leave the battery out of the car and finish these final steps for the MSD TACH DRIVER AFTER you've installed the AVC-R)
That's it for the MSD! The final unconnected wire coming from your tach adapter is the signal output wire.
Quote: Originally Posted by gearkraft
my guess is that veyrons have so many hp because they have a flux capactor that burns hannah montana merchandise
plastick is offline   Reply With Quote
Old 04-18-2005, 04:20 PM   #2 (permalink)
plastick's Avatar
AVC-R Install Step-by-Step:
Take a deep breath. I know it's intimidating, but with some time, patience and good listening skills you should have this done pretty quickly (if you consider 4 hours quick).
==BEGIN INSTALL==
If your battery and airbox + tubing is already removed, you're basically done with the first step.
First, we're going to start with vacuum line routing and mounting points under the hood. Wiring will come later.
(If you're running a stock SRT-4)
The very first thing you need to do is remove the GREEN vacuum tube that is attached to the turbo compressor housing (it's attached behind the inlet on the turbo, you have to reach back there and yank it off). Also remove the other end of the GREEN tubing from your solenoid (the thing that sits on top of the airbox). Cap the solenoid off with a vacuum cap (you can get an assortment of them under VACU-TITE at Pepboys, etc).
Now remove the black line coming off of your Wastegate Actuator. Disconnect it from the solenoid as well, then cap off the solenoid port where it was connected. Thus far you have two capped solenoid ports. Once that's done, you can begin with the AVC-R equipment.
Locate the Pressure Sensor that comes with the AVC-R. It's a round thing with a brass connection nipple in the middle. It's VERY IMPORTANT that you mount this as close as possible to the solenoid/vacuum source on the manifold, and it MUST be mounted with the brass nipple facing the ground.
Locate the black vacuum line which is connected to the nipple on the end of the throttle body, between the throttle body and manifold. Unplug it AT THE SOLENOID and connect it to one of the white 'T' connectors which came with your AVC-R. Make sure you connect it to the left side of the 'T', letting the right side run back to the solenoid and the top of the 'T' going to the AVC-R air cleaner, which runs to the pressure sensor. In the pictures you can see exactly where I mounted mine. I also wrapped it in some plastic bagging in order to safeguard against moisture.
Now you need to mount and hook up the solenoid valve from the AVC-R. It's the large rectangular thing. (VERY IMPORTANT NOTE: The AVC-R's remote solenoid valve comes with TWO BRASS HOSE NIPPLES already threaded into two ports on the valve: "COM" and "NO". If you are running an aftermarket turbo setup with an external wastegate, you'll need to remove the brass nipple on the "NO" port (leaving it as open atmosphere) and threading it into the port labeled "NC".) It's the large rectangular thing. Find a place to mount it that requires the SHORTEST amount of tubing, but also keeps it safely away from turbo heat.
Next, you need to use some of the thicker included vacuum hose from your turbo's compressor housing (where the green line was originally connected) to the "NO" port on the AVC-R's solenoid valve. Then run another piece of vacuum tubing from the "COM" port to your Wastegate Actuator. (BIG TURBO USERS: Run a vacuum line from the "NC" port instead of the "NO" port to your external wastegate). Use the included hose clamps and zip ties to secure everything nice and neatly.
NOW FOR THE WIRING HARNESS AND INTERIOR STUFF
In the very back of the engine bay (driver side, behind the clutch fluid and brake fluid reservoirs) you will see a hole with a rubber gromet where your boost gauge's vacuum tube runs through. You need to pull the rubber gromet out with your hands or some sort of pliers. This will open the hole up a lot more.
Next, run the HARNESS SIDE (the side that connects to the AVC-R's harness) through the hole in the firewall by wrapping the wires around the connector and inserting it horizontally so it fits through the hole. Feed all 3 sets of wires connected to this harness THROUGH the hole until you can't push them any farther.
Open both front doors (driver and passenger) on your car. You will notice two scews on both sides of the dashboard (on the driverside, the screw is above the fusebox cover). Unscrew both on each side with a philips head screwdriver and set them asside. Don't worry about knowing which is which since, except for the screws on TOP of the dash, they're mostly universal.
Next, remove your apillars on both sides by prying at them. They should unclip with a slight amount of force.
Now use a smaller philips head to remove the two screws on each end of the vent on top of your dash (closest to the engine bay). The screws are on the very left and right of the vent, underneith the plastic grill. Set those asside in a safe place.
Now you can remove your dashboard. Lift upwards and pull towards you. You may have to jiggle it around a bit, but it'll come out. DON'T remove it completely yet, as you need to put a screwdriver or something to hold the dash up in order to remove the boost gauge.
Remove boost gauge:
Get a screwdriver into the boostgauge from under the gauge housing. There are two philips head screws. MAKE SURE YOU CATCH THEM WHEN THEY FALL OUT! THEY CAN BECOME FOREVER LOST WITHIN THE DASH/STEERING COLUMN IF YOU DON'T CATCH THEM!
Once the screws are removed, pull the boost gauge directly downward to pull the alignment pins out of the dash. Now reach inside the housing, twist the bulb housing to the right to unclip it. Also remove the vacuum tube. Set the boost gauge asside. Now remove the dash completely. Set it down outside on a towel or something.
Now remove the plastic trim that unclips from around your instrument panel and set it asside.
Now you need to unscrew all 4 screws at each corner of your instrument pannel. They're black screws on white tabs connected to the gauge display. Remove those and pull the entire gauge face out and set it down somewhere.
Removed:
You will now have a clear view of the plastic vent tube that routes air to the air vent closest to the driver side door. By moving your left hand into the fuse box space on the left, and your right hand on the other side, push the vent tube backwards away from the vent. It will disconnect and you should be able to pull the other end off of the large vent tube that's directly behind the steering column.
Here's the tricky part. Reach into the area that was blocked by this vent tube and try to blindly find your AVC-R harness you pushed through the firewall. You should be able to reach it quite easily. Once you do, feed it back through the dash towards you. Pull it down near the OBDIII connector next to the clutch, then replace all your dash components in reverse order.
Now we get to do the wiring.
Go back to your engine bay and remove two of the three wiring harnesses connected to your car's PCM (it's below the driver's side headlight). You will remove the one closest to the ground, and the middle one.
Remove all tape and wireloom from both connectors. Now you're ready to cut away at the insulation on specific wires to tap into from the AVC-R harness. Here's how to do it (props to DJKOMPLEX for this!):
These following wires go to bottom connector that connects to bottom of pcm
C1 module
AVC-R----------Harness
Red wire--------DarkBlue/ red stripe PIN 11
White Wire------White/ Orange stripe PIN 13
Green Wire------Black/ tan stripe PIN 18 - closer to ecu
Black Wire-------Black/ tan strip PIN 18
(make sure black wire solder to different spot as green wire)
C2 Module (middle connector)
AVC-R-----------Harness
Gray Wire--------Orange/ dark blue stripe PIN 21
Off of coil (top of valve cover)
AVC-R------------Coil
Purple Wire--------Black/ Gray stripe
(u getter better signal with tach driver)
w/o tach driver set cyclinders on avc-r to 2
To clarify the different locations of the green and black wires from the AVC-R harness, these are both ground wires. You need to attach the green wire CLOSER to the connector. Remove insulation a few inches away (farther from the connector) and attach the black wire to the same wire as well.
If you're using the MSD Tach adapter, attach the purple wire from the AVC-R harness to your grey wire coming off the tach adapter. Once you're done, solder all connections up, reloom the wire harnesses and wrap thoroughly in electrical tape.
C1 wired up:
C2 (middle connector) with Grey AVC-R harness wire spliced in:
If you havn't done so already, you can now connect the white and red connectors from the AVC-R solenoid and pressure sensor to the AVC-R harness plugs in the engine bay. Zip tie them neatly to certain points inside the engine bay so they don't rattle/become damaged.
All finished:
That's it folks! Replace everything within the engine bay and clean up. Now all that's left to do is connect the AVC-R to the harness plug which is now in your interior and find a place to mount the AVC-R. If you want to put it somewhere away from the steering colum, you may want to leave the dashboard off during the entire install to route the harness wire to where you want to mount the unit.
Final step: Enjoy your AVC-R!
Old 04-18-2005, 04:32 PM   #3 (permalink)
Member Number: 12670
make this a sticky
I have mods...but then again my warranty is 12.8@107
JimmyWag is offline   Reply With Quote
Old 04-30-2005, 01:04 AM   #4 (permalink)
racedude1984's Avatar
Member Number: 25856
Trader Rating: (15)
ok question. So do I have to have a dsd think tach driver on my stock car well kinda stock. I ordered a bunch of parts all together intake BOV AGP acuator. and of course boost controller. I'm running it off my stock coil so I hope I don't need a tach driver but if it gets a better performance then I will do it..
Also any pics of it installed I need some ideas on where to put it in my car.
racedude1984 is offline   Reply With Quote
Old 05-04-2005, 02:02 PM   #5 (permalink)
Member Number: 25256
All is installed... Any advice on the programming of the controller?
Duty cycle, Feedback, Start Duty.
Thx!
drews77 is offline   Reply With Quote
Old 05-04-2005, 02:15 PM   #6 (permalink)
plastick's Avatar
Thx!
Sadly I'm still trying to figure it out myself
From what I've learned you'll want to leave the feedback rate alone...the AVC-R learns this by itself.
And for racedude: If you don't have the tach adapter, the AVC-R simply can't use gear-dependant boost features. Plus you'll have to set your # of cylinders to 2.
Old 05-05-2005, 12:33 AM   #7 (permalink)
Trader Rating: (15)
hmmmm so I guess I had better invest in the msd think where can I get the best price.
Old 05-05-2005, 09:55 AM   #8 (permalink)
What WGA are you using and what spring does it have?
I believe DUTY CYCLE has to do with the setup on the WGA. I have a 5lbs spring and my duty is turned up to 90%
Old 05-08-2005, 10:37 AM   #9 (permalink)
Ok, got mine running well...
I started by replacing my 5lbs (green) WGA spring with a 10lbs (yellow). Impotrant to have a stiffer psi spring. The spring directly affects the duty cycle. That made all the difference
These setting should work with a FORGE MOTORSPORT WGA and Yellow Spring... Other WGA will require different settings.
BOOST & DUTY SETTING
RPM BOOST DUTY
2500 .65 45%
3000 .80 58%
3500 1.10 67%
4000 1.20 72%
4500 1.20 72%
5000 1.15 72%
5500 1.15 67%
6000 1.10 65%
START DUTY
1ST GEAR -10% (Helps with the traction problem)
2ND GEAR 4% (1.26 BOOST)
3RD GEAR 0% (1.26 BOOST)
4TH GEAR 0% (1.27 BOOST)
5TH GEAR 0% (1.22 BOOST)
Old 05-10-2005, 11:53 AM   #10 (permalink)
Trader Rating: (15)
well I got the AGP wastegate so I'm waiting for all my parts to get here they should be here in an hour..... tick tock waiting for my parts. waiting by the door..... anyways I think I'm going to have to do some major researching about the boost contoller cause I thought they said it was good for new people geeez .
Old 05-17-2005, 03:03 AM   #11 (permalink)
Overcome's Avatar
Member Number: 24451
Thanks for the How-To. You've just made my life that much easier!
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 07-04-2005, 04:13 AM   #12 (permalink)
Member Number: 20481
Anybody have tuned settings for this with the AGP Wastegate Actuator?
Samuel346 is offline   Reply With Quote
Old 09-24-2005, 02:41 AM   #13 (permalink)
Member Number: 32236
Angry
my revs are bouncing around and its making my boost bounce with it. i dont have the tach adapter so i wired the purple wire into the black/grey on the coil. what do i do!?
hckyrob19 is offline   Reply With Quote
Old 10-09-2005, 03:09 PM   #14 (permalink)
plastick's Avatar
When using this method, be sure to set the # of cylinders in the AVC-R settings to "2"
Old 01-01-2006, 02:19 AM   #15 (permalink)
Member Number: 36937
Hey man i just want to thank you. You definetly made this a mad easy install the only thing different i did was i reached under the dash and got the same hole instead of removing the whole dash, then just took the lower column panel off and ran the wire behind it. But yet once again thanks.
SRT-4 OWNER 2005 is offline   Reply With Quote
