Old 10-22-2008, 06:22 PM   #1 (permalink)
Scammer
Member Number: 67046
Default Catch Can HELP!
I just bought a greddy catch can and im not 100% percent sure how to plumb it. I found the how to thread on here, but it really does not help me out very much at all. I have an injen cold air intake and i bought a breather filter too just incase i needed it. If someone could please assist me that would be awesome because i have had it mounted under the hood for over a week now and not plumbed. LOL! Thanks everyone!
Chad
Germano03srt4 is offline   Reply With Quote
Old 10-22-2008, 06:31 PM   #2 (permalink)
Bl00dR3D's Avatar
Member Number: 61288
if you put the breather on you can go PCV>catch can>TB
Rule #76. No excuses, play like a Champion!
Bl00dR3D is offline   Reply With Quote
Old 10-23-2008, 07:30 PM   #3 (permalink)
Member Number: 59422
Trader Rating: (35)
Here is how you hook it up. Run a line or use the factory line and add some to it from the pcv valve to one of the ports on the catch can. Then run a line from the other port on the catch can to the big nipple on the throttle body(the one behind the butterfly/throttle blade). You will also want to get a check valve in line on the one that goes to the throttle body so you don't bleed off boost.
Then for your intake nipple. This is how I route mine as it works well. DO NOT put a breather on it as it has been proved by dcr to have bad effects on the engine over time. Run a hose from the intake to a fuel filter for a carb car. Then run a line from the other side of the filter to the valve cover. That way it will catch all the oil from your crankcase and not put it back into your intake track. The filters are about 4 bucks so whenever they get dirty just get a new one. Here is a pic of my setup for reference. Hope that helps you out.
04Eblue is offline   Reply With Quote
Page generated in 0.13462 seconds with 13 queries
