On the passenger side, behind the plastic cover. If you look under the car on the pass side, you should be able to see it fairly easy. If you are doing this without a lift, taking the wheel off will make access a lot easier. A 21 and 15 mm are what is needed if I remember right, I know you need a 21 [ 13/16" in standard] for the big side. I want to say 15 for the small one, but cant recall right off hand.
If you dont know what you are doing...Keep the car stock
11.478@120.58mph on the stock turbo, intercooler, head, cams, intake manifold, intake, throttlebody, exhaust manifold, etc and making 391hp 482lb/ft torque...  :
"Vtec- All the lag, none of the turbo, like waiting for bad sex"
Religion is a bandage created by man to help heal a soul wounded by circumstance.
