Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 10-21-2008, 05:40 PM   #1 (permalink)
Red-Skittle's Avatar
Member Number: 68476
Default What do I do?
I have the option of buying a used Stage 1 ecu for my 05 SRT. I know I have to get my VIN and mileage set on the ecu so how do I go about that and how much would it roughly cost?
Red-Skittle is offline   Reply With Quote
Old 10-21-2008, 05:55 PM   #2 (permalink)
jeremy hall's Avatar
Member Number: 64339
flight systems is here on the forums somewhere, they charge $30 or so. had one done there a while back, good place, no problems.
Daddy likes to play with Double D's
Dump tubes save lives.
jeremy hall is offline   Reply With Quote
Old 10-21-2008, 06:02 PM   #3 (permalink)
where are they located?
Old 10-21-2008, 06:07 PM   #4 (permalink)
i believe in Michigan, i'll try and find them on here and post it.
Old 10-21-2008, 06:32 PM   #5 (permalink)
Flight Systems Stage PCM Reflash
Reflashing Your PCM
I cannot reflash stock units!! I have been helping out and paying for shipping back to you, but if I receive anymore stock then you will have to pay for the shipping back to you without the vin reflash being done. I'm sorry but I dont know how many times I can tell everyone that I CANNOT reflash stock modules.
Hello,
My name is Stephanie and I am from Flight Systems, the company that supplies you with your turbo kits. If you have bought a used stage kit and need your vin number reflashed into it you can send your pcm to me and I can reflash it for you. I can NOT reflash stock pcm's. As you should know, if you do not reflash the module and try to install the pcm in your vehicle without changing the vin, your vehicle will not start. The charge for this will be $30 plus s&h plus the COD charge. I can either ship it back to you overnight air, which is expensive or ground which will only cost $4-5 more on top of the $30 plus the $7 charge for COD. The cost for everything will be around $43, which will come COD (collect on delivery). Everything will be sent back using the carrier UPS, no exceptions. When the driver drops your pcm off you must give him a check or money order made out to Flight Systems, for the exact amount. Once I ship your pcm out, I can send you a pm with your tracking number and total COD amount. The new address is:
Flight Systems
33820 Riviera Dr.
Fraser, MI 48026
Attn: Stephanie/Reprogram
Please make sure to put inside the box your vin number, return address, a telephone number I can reach you at in case of any problems,your name on the forums, and how you would like it sent back to you; ground or overnight. Your mileage is not needed because that is not programmed into the modules. Please make sure the pcm is packaged properly, any damage that happens on delivery to me is not my respondsibility. Let me know when you are sending it out to me by pm so I know when it should arrive. I will ship it back out to you 1-2 days after I receive the kit. If you have any questions, you can pm me as well. Have a great day!!
Stephanie
Flight Systems
Parts Department
like i said, this is who i used, great place!
Old 10-21-2008, 07:07 PM   #6 (permalink)
thanks man
Page generated in 0.15029 seconds with 13 queries
