Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 09-10-2007, 01:11 PM   #1 (permalink)
sideshosk8's Avatar
Member Number: 48387
Default Torque steer......i think?
my car sucks to drive on the freeway.around 60mph and up if I accelerate even a little to pass or just get up to speed as soon as boost comes on the car pulls pretty hard to the left. I have to correct the steering wheel to the right about an inch and hold it there.once I let off the throttle the car comes back to the right.its not to bad at 60mph,but at a buck twenty its scary as hell! I did have a front end dinger where the uni body frame got bent.but all the damage was fixed.I have a torque damper.so will solid motor and tranny mount along with h brace and traction bars and poly suspension bushings fix my problem.or do I need to go another route.
sideshosk8 is offline   Reply With Quote
Old 09-16-2007, 01:07 PM   #2 (permalink)
DrmCtchr's Avatar
Member Number: 38971
have you readjusted your tractionbars?
DrmCtchr is offline   Reply With Quote
Old 09-16-2007, 04:34 PM   #3 (permalink)
sideshosk8's Avatar
I don't have the traction bars yet.I was refering to all those mods as a possible solution to the problem.what do you think? would traction bars help me?
Old 09-17-2007, 09:15 AM   #4 (permalink)
DrmCtchr's Avatar
oh im sorry I mis read that. have you checked preasures in the tires?.. made sure both shocks are at the same setting ( if its an ACR).. got it aligned?
Old 09-17-2007, 11:57 AM   #5 (permalink)
sideshosk8's Avatar
I just got it lowered and they supposidly re aligned it. but I am taking it back to have them check it out.tire pressure was a little low but not a whole lot.thanks for your input.
Old 09-17-2007, 01:03 PM   #6 (permalink)
DrmCtchr's Avatar
grab the tire at the top and give a tug outwards and then use your knee to press inwards on the top of the tire. im betting you have a sh1ttycrap@ss LCA bushing the above test is usually used to check wheel bearings ( listen for the click clack ) but this should work to see if the rear LCA is shot too .. you have to be fairly forceful to see if it moves unordinarily.
David
Old 09-17-2007, 02:17 PM   #7 (permalink)
sideshosk8's Avatar
do I jack it up and put it on stands first or just flat on level ground.I've had the car for over three years and I just surpassed 14k miles I hope that's not my problem.I'm going to put poly urathane bushings all the way around soon anyway though.
Old 09-17-2007, 03:28 PM   #8 (permalink)
DrmCtchr's Avatar
start on the ground =]
look at this to see if it fits
Tore up right side fr control arm rear bushing
Old 09-17-2007, 06:09 PM   #9 (permalink)
sideshosk8's Avatar
I don't hear any abnormal noises at all.that's not to say its not the problem maybe it just hasn't gotten to that point yet.this is a really annoying habit of this car and I've had split second thoughts of selling it just because the majority of my driving is on the highway/freeway and it just might cause me to wreck one of these days.but I am in love with my srt4 and want to try everything to fix the problem before getting rid of it.
Page generated in 0.15348 seconds with 13 queries
