Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 05-19-2006, 09:53 AM   #1 (permalink)
Gemini boi's Avatar
Member Number: 8212
Default Stage 2 Idle question
I did do a search and could not find anything.
The idle for Stage 2 w/o toys is a rougher then stock is this normal. Everything else seems great.
Only mods on car is stage 2, NGK 4306 plugs gap .40
Jerrad
Hyundai Genesis
For sale SRT-4 52040miles (stage2 no toys) 12500. email jdoig@msn.com
Stock Electric Blue w/ sunroof. (224.6 hp & 244.7 tq)
Dream Car: Austin Martin DB9
Gemini boi is offline   Reply With Quote
Old 05-19-2006, 04:11 PM   #2 (permalink)
torque222's Avatar
Member Number: 11609
yes that is normal, mine actually sounds like it's cammed....but yes that idle is normal.... mod on...
agp 50 trim w/ hahn portfueler,mopar stage2 , lorenzo 60mm tb, perrin 3' turboback exhaust, jmb cai, aem uego wideband,mopar sts, prothane motor mount inserts, ptp hardpipe kit with greddy rs bov,cca fmic, ptp stage3 clutch w/ fidanza flywheel and bc stage2 cams.
torque222 is offline   Reply With Quote
Old 05-20-2006, 06:09 PM   #3 (permalink)
SRToc Member
srt4va's Avatar
Member Number: 3167
Trader Rating: (19)
When I had STG II the engine would stumble and I did not like it. Nothing runs better then the stock PCM. But to answer your question, yes STG II idles like dog poop.
03 SRT-4 SOLD!!!
05 GTP CompG
srt4va is offline   Reply With Quote
Old 05-20-2006, 11:17 PM   #4 (permalink)
Gemini boi's Avatar
Member Number: 8212
regapped from .40 to .36 and no more rough idle as of yet.
Old 05-22-2006, 05:07 PM   #5 (permalink)
Member Number: 26913
ya mine idles funky too. The vac gauge goes slightly up and down.. thought it was a vac leak but i dunno..
ZZzzzSRT is offline   Reply With Quote
Old 05-22-2006, 07:16 PM   #6 (permalink)
SRToc Member
boostinhardsrt's Avatar
Member Number: 29130
same here, just had my tps replaced today and it still does it. so, it must be stage 2.
boostinhardsrt is offline   Reply With Quote
Old 02-12-2007, 10:35 AM   #7 (permalink)
SRToc Member
redsoxsrt's Avatar
Member Number: 28768
Trader Rating: (42)
its the injectors i betcha, i have a set of deatch werks injectors and the car idles mint. just like stock
Old 02-12-2007, 10:36 AM   #8 (permalink)
Member Number: 25779
Trader Rating: (10)
Its the injectors,...they are too big
It happens in all cars when you start adding bigger injectors, they dont idle so well.
Mine sounds a lil cammed as well...once the car warms up its better, but still not consistent
iamxero is offline   Reply With Quote
Old 02-13-2007, 02:59 PM   #9 (permalink)
Member Number: 29651
keep an eye on plug gap.
kcbsrt4 is offline   Reply With Quote
Old 02-14-2007, 04:27 AM   #10 (permalink)
Member Number: 8574
Leaky injector... I had the same problem.. found the leaky injector, replaced it.. car idels just like stock. Pull the wire of each injector one at a time, while the car is ideling. You will notice which injector is bad.
04raw is offline   Reply With Quote
Old 02-15-2007, 07:39 AM   #11 (permalink)
04Neonsxt's Avatar
Member Number: 22499
Trader Rating: (18)
mah im glad I saw this and didnt start changin shit to make it idle like stock. thought i had a leak or something.
05-Flame Red- Stage 2 w/toys- Bolt ons
04Neonsxt is offline   Reply With Quote
Old 02-15-2007, 07:49 AM   #12 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
Mine liked a big gap, but everyone heard it pop at idle. They would tell me to change my plugs, no need. I had stock champions in the car, and it loved them. Although it eat them like no tomorrow, but then I switched to 4306's when they became available to me. I used a .045-.048, and the car loved it champions, and .040-045 NGK's.. laters...
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is online now   Reply With Quote
Old 02-17-2007, 07:01 PM   #13 (permalink)
e_freeman85's Avatar
Member Number: 13554
Trader Rating: (13)
what will it do if you do that will it smooth out of somthing? or stumble more and do you mean pull on the wire or unplug the injector
