Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 04-26-2007, 01:53 PM   #1 (permalink)
Member Number: 53094
Default Just bought an SRT4. Need the *do's-and -don'ts*
I just bought my 2005 srt4 with 11.5K miles, and it actually didn't come with the owners manual
I just need the basic do's-and-donts with this car.
I've never owned a turbo car... Don't really know the basics..
I know there's something about not turning your car off immediately after boost, synthetic oil every 3k miles, BLAH, BLAH...
Go on... I want to hear it all.
As fas as the synthetic oil, does it HAVE TO be MOBIL; can it be Pennzoil?
Angrysnail is offline   Reply With Quote
Old 04-26-2007, 03:57 PM   #2 (permalink)
e_freeman85's Avatar
Member Number: 13554
Trader Rating: (13)
it doesnt have to be mobil and some donts no fuel tuning with out some kind of way to keep track of your AFR
[live]srtfreeman85[/live]
http://www.appalachianperformance.com/
e_freeman85 is offline   Reply With Quote
Old 04-26-2007, 05:51 PM   #3 (permalink)
[vu]juan's Avatar
Member Number: 33153
Trader Rating: (38)
Don't start up the car in the middle of a boost leak test... ask TheGreyGhost why...
"Been in a palace, been in a jail, I just don't want to be reborn a snail
Just want to spend eternity, Right where I am, on the sunnyside of the street"
- The Pogues
Powder Coating FTW!
[vu]juan is offline   Reply With Quote
Old 04-26-2007, 08:57 PM   #4 (permalink)
maxfastest's Avatar
Member Number: 40873
Trader Rating: (55)
Default !
Don't race without Aftermarket motor mounts.
wear your seat belt !
and read all the posts in this forum twice !!
2004 Black SRT4 ,Stg 3 w toys
364.84 HP 375.77 TQ HOM 110 Race
12.014 @ 119.96 , Bandimere Best R/T . .007
Best MPH . 120.90
Colorado's Quickest Stage 3 SRT4 so far.
http://s107.photobucket.com/albums/m...steve12019.flv
SOLD
maxfastest is offline   Reply With Quote
Old 04-27-2007, 09:51 AM   #5 (permalink)
>>bump for info <<
Old 04-27-2007, 06:20 PM   #6 (permalink)
Member Number: 39141
wash car often, check air pressure often 35psi good. Use Premium fuel only, any Premium oil is good, regardless of type or brand, 5w30 only. Use Mopar stage kits, Install motor mount inserts or spend big money on solid mounts. Do not do burn outs..do not over boost car. Do not accelerate hard coming out of a corner or turn, car likes too pull to left or right and can be scary, called ( TORQUE STEER) this is more controlled some by using motor mount inserts,or solid mounts. You bought a great car and fun to drive, and is fast.. just use your head and read this forum alot to learn stuff. Pt Performance on here is a great place to mod and buy.
05 SRT4 'M' Stg 1 kit,Injen CAI,Forge bov, AGP Cc,PTP cv,PTP 180 Stat,MPX coil heatshield, wndw tint 20&35%, Mopar Frnt strut brace,Prothane MM inserts,Maddog 58 STS, Mopar stg 1 sways. NGK plugs, Mopar cat back, Weather-tech ventvisors.Mopar Perf.wires. Mopar 25mm drop springs.sway bar poly bushings. Nexo 17x7 NT5 wheels in Gunmetal, 225-45-17 Falken 452 tires, SS 14" antenna.More..
KEVS SRT4 is offline   Reply With Quote
Old 04-28-2007, 07:08 AM   #7 (permalink)
...Thanks Kev_
Old 04-28-2007, 04:09 PM   #8 (permalink)
clamsjager's Avatar
Member Number: 34911
use the search feature on the forums it comes in handy, when its working.
for example "srt do's and dont's"
New car, but same old clammy
08 DGM WRX, stage 2. big turbo to come soon.
clamsjager is offline   Reply With Quote
Old 04-28-2007, 05:02 PM   #9 (permalink)
xonic's Avatar
Member Number: 21987
zip tie all vacuum lines. If you have a sunroof and like it not leaking or getting stuck then avoid going above 140mph.
Formerly Stage AGP
xonic is offline   Reply With Quote
Old 04-30-2007, 04:35 PM   #10 (permalink)
PlanB's Avatar
Member Number: 53113
nice
PlanB is offline   Reply With Quote
Old 05-01-2007, 03:11 PM   #11 (permalink)
I just had a guy who told me to upgrade my wastegate to an AGP, and get a blow off valve....
What is this wastegate going to do for me, and the BOV is just to eliminate the 'flutter' and get more of a 'swooosh', right?
Old 05-01-2007, 03:20 PM   #12 (permalink)
1SLOWSRT's Avatar
Member Number: 21736
The aftermarket WGA allows you to adjust boost and prevents boost from falling off as rapidly as it does on a stock WGA. The stock WGA has a 4 lb spring in it and our stock turbo is small when compared to our large 2.4L of displacement for a 4 cylinder. This causes boost to fall of towards the redline no matter what. Aftermarket WGA's are adjustable so you can set boost at your desired level and have a much stiffer spring, usually 14 lbs or so which allows boost to hold on longer and not drop off as rapidly as it would otherwise. If you get a WGA don't set it past 16 psi until you get some sort of fuel management, (a stage kit, SAFC, Map clamp, detec, etc.) Some people will say you can go higher, but it's better to be safe than sorry. Once you do that then you can up the boost more. Also make sure to reroute the vaccuum lines after you install the WGA in order for it to run properly. Do a search on vaccuum lines.
A BOV isn't a necessity on a stock turbo unless you're running a good amount of boost. I had the Mopar rice plate, which uses the stock surge valve, running 19 lbs and never had leak issues because I installed it properly. If you plan on upgrading turbos or want that cool sound than get an aftermarket BOV.
1SLOWSRT is offline   Reply With Quote
Old 05-01-2007, 04:23 PM   #13 (permalink)
yorad's Avatar
Member Number: 49047
Do your best to always do some searching and read the stickys in this forum before asking questions. I'm surprised no one has flamed you for that yet, but but that's a good thing. Here is some homework for you, you may want to bookmark these, it helps you get started. Good luck and congrats on the purchase.
Oh, and PM me if you still need an owners manual, I can hook you up. Somone posted a link to download it a while back but I don't have time to find it right now.
New Owners FAQ: New Owners FAQ
Performance Mod Glossary: Performance Mod Glossary
*UPDATED*AGAIN*SRT-4 Basic Upgrade Path & Tuning Guide: SRT-4 Basic Upgrade Path & Tuning Guide
How-to: (Explained upgrade path) HOW TO: (Explained Upgrade path)
My Vehicles
2003 Dodge SRT-4: a little extra boost, a little extra fuel, and some good spark.
2005 Suzuki Hayabusa - driver mod, doesn't need much else!
yorad is offline   Reply With Quote
Old 05-02-2007, 09:49 AM   #14 (permalink)
I see...
Now, does the car drive differently aside from boosting with the AGP WGA?
I mean, as is, I've noticed that either you drive this car really slow or really fast.
I'm going 35mph, and the second I give it a little bit of gas you instantly hear the turbo start spooling and feel the car picking up some pace.
I've research on this site for the AGP WGA, and came across PTB (part-throttle boost) several times. What exactly is this, and is it something I should worried about?
Is this a good thing?
Old 05-03-2007, 12:07 PM   #15 (permalink)
Orangetona's Avatar
Member Number: 53538
Im not sure how true they are on SRT4s but part say you are running your car and you are 3/4 throttle at full boost, your fuel tables are leaner at that throttle opening as compared to WOT when the computer will supply the full amount. Hope this helps.
Mike R.
www.northamericancarclub.com - NACC owner, Admin.
Orangetona is offline   Reply With Quote
Page generated in 0.24378 seconds with 13 queries
