Quote: Originally Posted by
1 srt4 U
i have the part..and know about bleeding process..not entirely sure how to do it..can anyone post some instructions for help ?thnx.
Lol,are you SURE you know how to do the bleeding process?Look closely at the whole system,there isn't a bleeder.The way you bleed it is,you take the slave cylinder out of the tranny with the lines still attached and everything.And you slowly apply pressure (pushing the slave cylinder in with your hands) which is going to push the air out of the system (the air bubbles will come out of the top of the reservoir).Im not sure if you broke your old slave cylinder or what,but just install the new one and do what I said just to make sure theres no air in the line.Then if you look on the tranny,theres a little rubber rectangle piece thats right by where the slave cylinder goes,take this piece off (its rubber,you will see the tab,just pull it out towards the side of the car once your slave is out of the tranny) then once you go to put your new slave in,you use that opening to eyeball where the tip of the slave goes.There will be a groove in the TOB fork,you will see what I mean once your down there.Let me know if you have any questions!
Later.
-Frazier
