Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 03-14-2007, 12:17 AM   #1 (permalink)
cavie187's Avatar
Member Number: 48529
Default How the HKS SSQ bov works! W/PICS
I have been seeing a whole lot of posts/threads asking about "What blow off valve i should buy....why?". I see the same answer time and time again.
ANSWERS in reply to the question (post numbers are sum'ed up on the left):
1) "MOPAR rice plate is FTMFL!"
2-100) Arguing about how the MOPAR "BOV" leaks/does not leak.
-After all the arguing stops, there are a huge list of people that love thier HKS, but when it comes to why they like it so much, they have nothing to say. There is always one smart person that says it has 2 seperate valves that open, but it seems they never show how this happens...hence this thread. Now everybody that can find a search button knows how the HKS works!!
First off, i want to tell you that if you have ever tried to install this bov, you will know that at times it is a little to bulky to fit in those tight spaces....here is a hint: Take off the casing to the valve to get in those tight spaces. (see picture below, if you remove the allen head screws that are marked with red, the cap will come right off, reducing the size by a considerable amount)
Ok, now that i got that off of my chest, on to HOW IT WORKS.
What makes this BOV diferent from others is the basic design. The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idle. There is also 2 valves that work together to keep a tight seal under high boost, but give fast response under lower or PTB. (see pictures below)
Above is a picture of the valve(s) closed [ie. acceleration]
Below is a picture of the large diaphram of the bov being pushed open. [ie. when the clutch is pushed in or you let off of the gas] This valve opens when you have been under high boost, and need to dump all built up pressure, but these larger valves can be slow...that is the reason for the second valve! (one more thing you should note is this is not a PUSH type valve, it is a PULL type...but i will tell you a little more about that later)
The picture below is of the smaller valve being pushed open by a pen.
It is hard to see, but the center part of the diaphram moves away from the outer ring of the valve. What this does, is speeds up the process of releaving the pressure, AND begins the pressure relief faster than if just the large valve were used. (very good for keeping your turbo healthy under higher boost levels. almost completely elimimates pressure that causes pressure surges [fluttering form turbo] caused by slow release of boost from charge pipes )
Another thing worth mentioning is the HKS ssq is a pull type valve. This means that it WILL NOT leak from the valve. The pressure from the boost will hold it tightly in place untill there is a change in pressure, then the valves will work accordingly to the level of boost/pressure that needs to be released.
I hope this has helped someone, and i do not advise you take apart your $200 BOV to see exactly what i have shown you.....this is why i used a cheap knock-off BOV to show how the valves work. If you do this on your own (pushing and pulling, using pens to press the valve down, holding valves open with allen wrenches), you may damage the structure of the diaphram causing you new BOV to be useless.
Oh yeah, sorry about the sad m.s. paint drawing.
Funniest video(s) EVER! Part 1 Part 2
cavie187 is offline   Reply With Quote
Old 03-14-2007, 12:27 AM   #2 (permalink)
cavie187's Avatar
One more thing.....
When installing the BOV to the flange, there were some pics missing in the How To section. To help clear up a little of this confusion, i will try to show you how to place the BOV in the seat of the flange.
First be sure not to forget the o-ring.
Then slide the snap ring (horse shoe looking metal thing) over the fitting on the BOV.
Place the bov in the seat of the flange.
Use snap ring pliars to squeeze the snap ring together so you can set it in the groove of the flange (that's what locks the BOV in place)
The red/orange thing is the o-ring. I marked where the groove for the snap ring is in green, and the snap ring is sitting in the upper left-center side of the pic (kinda hard to see because of the black leather..sorry)
Old 03-17-2007, 02:08 PM   #3 (permalink)
rbenkemeadow's Avatar
Member Number: 36456
Trader Rating: (15)
I need a snap ring, do you know the size and where I can get one?
rbenkemeadow is offline   Reply With Quote
Old 03-17-2007, 04:38 PM   #4 (permalink)
cavie187's Avatar
I know napa has them, but i am not sure if they will have it in stock. They will probably try to sell you a set for $13.
i think the size is 2.5" for all hks/hks type bov's.
Old 03-17-2007, 11:54 PM   #5 (permalink)
Trader Rating: (15)
Thanks. Nice write up too.
Old 03-18-2007, 11:30 AM   #6 (permalink)
uberingram's Avatar
Member Number: 447
Great thread.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 03-18-2007, 02:03 PM   #7 (permalink)
cavie187's Avatar
Thanks guys.
Old 03-18-2007, 02:07 PM   #8 (permalink)
minicuda's Avatar
Member Number: 25331
Trader Rating: (15)
good write up thanks!
minicuda is offline   Reply With Quote
Old 03-18-2007, 02:16 PM   #9 (permalink)
mysticalnyte's Avatar
Member Number: 26363
Trader Rating: (32)
Sticky material?
mysticalnyte is offline   Reply With Quote
Old 03-25-2007, 09:54 AM   #10 (permalink)
E-BlueRocket's Avatar
Member Number: 11437
Trader Rating: (50)
+1 for a sticky... Good write-up, I love my HKS and wouldn't have anything else on my car.
No Boost... It Might Have A Button
E-BlueRocket is offline   Reply With Quote
Old 04-01-2007, 05:02 PM   #11 (permalink)
redhotneon's Avatar
Member Number: 18438
Trader Rating: (10)
i have to remove all the screws to get the cover off. meaning theyre arent any holding the rubber gasket on when the cover is off. is that bad? should i fix it? bought it used from a wrx owner and thats the way it came.
redhotneon is offline   Reply With Quote
Old 04-01-2007, 09:27 PM   #12 (permalink)
cavie187's Avatar
The holes should be diferent sizes, just slightly.
4 should hold on the cover, and the other 4 should hold the casing together. If you started with the wrong 4 allen screws, you would end up having to take them all of (unless you replaced the 4 you had taken out, then removed the opposite 4 screws)
i wouldn't worry about it (as a problem), if it really did take all 8 to take it apart, then just put them back together the correct way. Have you had it on your car yet?
...and is it a real HKS or just a knock off brand like the one i used in the pictures?
Old 04-02-2007, 10:10 AM   #13 (permalink)
redhotneon's Avatar
Trader Rating: (10)
i have it on the car right now. im pretty sure its real. it has the hks painted on it. unless they just switched the covers
Old 04-02-2007, 10:20 PM   #14 (permalink)
cavie187's Avatar
heh. i think if you were going to have problems, you would have noticed by now.
Just make sure you did not take off the wrong 4 screws by assident, then correct the screw order. if you try to put the head of the screw in the hole, you can see which holes should be used to attach the cover, and the .....you can figure out the rest.
in all reality, if it ain't broke don't fix it..you'll be fine.
Old 05-26-2007, 01:17 PM   #15 (permalink)
cavie187's Avatar
..wow this thread moved. lol
