Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 FAQ / How To > FAQ Forums
Old 12-03-2006, 08:13 AM   #1 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Trader Rating: (118)
Default 3 Bar map and TIP sensors, Stage 2 Vac lines rewire
Can anyone help me out with this? I recently purchased Stage 2 w/o toys, and I need to know what do I do with the new sensors? I know the Map has to be installed, but the TIP? I have re run my vac lines so the PCM doesnt control boost, and the RED and WHITE lines have also been removed. Do I still replace the stock TIP sensor with the one that came with the Stage 2? What exactly does it do, and with the absence of the white line connected, does it still have a function on the car? Do I still need to clamp it along with the MAP sensor. I have the PTP Map/TIP clamp. ANY feedback would be much appreciated.
4DRVIPER is offline   Reply With Quote
Old 12-09-2006, 11:23 AM   #2 (permalink)
Member Number: 32196
Yes put the white and red lines back to stock stage 2 likes more boost
it runs higher than stock so the new pcm won't freak out like stage 0 does.
A853 Crew (ONLY UNO)
Starting all over from stock
Mods Now04 Silver Wilwood slotted BBK slotted,slotted Rear,Windage tray+crank scraper,Dcr power shift2 clutch,Bwoody Motor mounts+trany,Stock air box mod+K&N drop in,F&F Ported ex.Manifold,3" o2 housing,My catch can+check valve,Safc Neo,Agp waste gate + ptp spring,Agp uhp,lower
^ Coming Maxed Stocker WORLD RECORD 08
Racerxvsspeedracer is offline   Reply With Quote
Old 12-17-2006, 10:01 PM   #3 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Sorry, must be extra tired or something, but did you say to put the red and white vac lines back on the car since I am now stage2? If I hook them back up, what wil be the benefit/gain?
Thank you for taking the time to help me out, you were the only one...
Also if these are the only STOCK vac lines connected to the solenoids, do I have to reconnect ANY of the others? I like the PCM not controlling boost.
Old 12-18-2006, 08:34 AM   #4 (permalink)
Member Number: 28737
Trader Rating: (67)
The only line I have hooked up is the white line. The red one isn't needed and won't help. The white one I thought was never supposed to be taken off.
taco is offline   Reply With Quote
Old 12-18-2006, 06:26 PM   #5 (permalink)
Member Number: 32662
When I put on my stage2, I didnt change any hoses, lines at all. I just put on the new sensors? and left everything the same. Maybe I did something wrong here, the car boost more and is faster?
super20g + portfueler + stage2 + some other stuff
Dusty is offline   Reply With Quote
Old 12-19-2006, 09:43 PM   #6 (permalink)
Bebo's Avatar
Member Number: 46331
I think you may have wasted your money on the Stage 2. The only real gain you got was a WGA & injectors. With the MAP clamp & the vacuum rewire the PCM is almost useless. If your running a MAP clamp then the new MAP sensor is useless & with the vac. rewire the TIP is also useless. You could always put it all back to stock w/ Stage 2 & enjoy the power improvement over stock but, if you're planning on taking an aftermarket approach to more power then stay away from Mopar upgrades.
Bebo is offline   Reply With Quote
Old 12-20-2006, 05:56 PM   #7 (permalink)
4DRVIPER's Avatar
Member Number: 6612
hey, I hear ya, and maybe I could be wrong, but I dont think I wasted my money on stage 2. Alot of people have this set up, with many of them using the Apexi SAFCII instead of a Map clamp, which I am in the midst of getting, and reporting good things about their setup. The stage 2 WGA??? I wouldnt use it anyway, I dont see a benefit of it because I have the Kinetic WGA. I am sure that the stage 2 PCM does have its advantages over a Stage 1 or Stage 0 with the exact same setup as what I have. What do you thik? Anyone else have any opinions? I am sure we would like to hear em all. Besides, I still have the red and white line still connected, and I never clamped my car, I sold my clamp, unused, to another member, cause I am getting the Apexi SAFCII.
Page generated in 0.23879 seconds with 11 queries
