Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 09-12-2006, 09:25 AM   #1 (permalink)
nme
nme's Avatar
Member Number: 42393
Default What is the lowest pre load i should use?
Im trying to turn down my wga's preload so i can use my ebc to control boost. What is the lowest preload i can go with safely on your agp wga?
nme is offline   Reply With Quote
Old 09-13-2006, 09:55 AM   #2 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (84)
The lowest boost you'll be able to run is around 14psi.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 09-13-2006, 10:26 AM   #3 (permalink)
nme
nme's Avatar
So what are the negative effects of loweing the tension to like 10psi?
Old 09-13-2006, 10:30 AM   #4 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (84)
You can't.
Old 09-13-2006, 10:32 AM   #5 (permalink)
nme
nme's Avatar
What do you mean i cant? I loosened it until it was just lighly pulling on the wga. Turned my ebc off. Then i drove it and it hit 10psi in all gears?
Old 09-13-2006, 10:55 AM   #6 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (84)
Is that a question if you can do that? I don't know.
Old 09-14-2006, 07:34 AM   #7 (permalink)
stevesrt4's Avatar
Member Number: 1517
Trader Rating: (37)
I thought the kit came with two wga springs, one 10lbs and one 14lbs?
--00'Camaro z28
--03' Mustang Cobra (470whp 11.98 on street tires sold)
--03' solar yellow srt-4 (R.I.P.)
--03' 400whp solar yellow srt-4 (R.I.P.)
--05' white srt-4 12.78@112.5mph (SOLD)
--Afghanistan (04'-05')
stevesrt4 is offline   Reply With Quote
Old 09-14-2006, 11:01 AM   #8 (permalink)
Nick@AGP's Avatar
Member Number: 11546
He is talking about a WGA for a stock turbo, not a external wastegate for a large turbo kit.
Nick -
Do Not PM me. Email sales@agpturbo.com or call.
http://www.agpturbo.com
Nick@AGP is offline   Reply With Quote
Old 09-14-2006, 11:09 AM   #9 (permalink)
nme
nme's Avatar
yes. As long as im not breaking anything it works great.
Old 09-15-2006, 02:21 PM   #10 (permalink)
stevesrt4's Avatar
Member Number: 1517
Trader Rating: (37)
dah, sorry nick, got big turbo on the brain.
Old 09-15-2006, 06:28 PM   #11 (permalink)
pettyracing's Avatar
Member Number: 29724
If your boosting 10 lbs on the AGP WGA then either your gauge iss off or you have a good boost leak.The lwest I can set my Dtecfcbc is 14 pounds in first gear.The lowest you can run is the spring rate of the spring in the WGA which is a 14 lb spring in the original WGA.I believe the upgraded spring is 18 lbs? Its a give and take between the two springs.Either run the weaker spring for lower boost in lower gears for more traction and hold less boost too redline and have a little turbo surge or flutter or put the 18 lb spring in and have more boost in lower gears and pedal it and hold more boost too redline and have no or less surge?
AGP WGA,Stage 1,Jmb Ult CAI,Greddy RS BOV, E.D.Superbeast-Hardpipes,Maxxfab 3" O2,Needswings Dp,QTP30 Ecutout,B&B catback,Aaroneon's Fuel return kit,bottleneck fix,Walbro 255 ,Ptp checkvalve-CAI splashshield,ES LCA Bushings, AGP Dogbone MM,58% Maddog STS,NGK Irridiums .032.Dtecfcbc,Txs tuner wideband.Snow W/Meth INJ,CTI Full hotside pipe.Stage 3R 49lb min wheel,F&F PNP Exaust Mani,Ext gated.750 inj,Motegi Tracklites,MT'S
pettyracing is offline   Reply With Quote
Old 09-17-2006, 12:36 PM   #12 (permalink)
Member Number: 14452
Trader Rating: (10)
which wga do you have. the billet or the original? i have the original, and i can go as low as 6psi with it.
Quote: Originally Posted by 04inred
Quote: Originally Posted by a707
So... Is it dead?
lol
Um no its just sleeping forever
veilside67r is offline   Reply With Quote
Page generated in 0.32685 seconds with 13 queries
