Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 04-15-2005, 10:11 AM   #1 (permalink)
Boosted-srt's Avatar
Member Number: 21562
Default What else do I need with the T3/T04 kit?
I am looking into the T3/T04 kit for my car and was wondering what else I would need to buy. I have S2/toys and other misc. bolt on's.
What other components will I need to buy or modifications will I need to do?
GET REAL....GET MOPAR
'03 Black, S2/Toys, AGP 3" CAI, 3"DP/No CAT, 3" side exit, ATP cold side/Greddy TypeS, Lorenzo 60mm TB & Spacer, FBM P&P Intake Mani., MAD-DOG 50% STS, Booger Bushings, 18" TenzoR Mean6 w/245/40/18 Toyo T1R tires, Willwood Big Brake Kit/Red calipers/Cross drilled and slotted, Mopar Performance 4-Puck clutch/Fidanza Aluminum Flywheel, AIS BFMIC/black coating.
Boosted-srt is offline   Reply With Quote
Old 04-15-2005, 10:15 AM   #2 (permalink)
skipdogg's Avatar
Member Number: 18045
Only thing you absolutely have to have is a BOV, the rest are just mods to help you make more power.
skipdogg is offline   Reply With Quote
Old 04-15-2005, 10:30 AM   #3 (permalink)
SRToc Member
srt4_riceater's Avatar
Member Number: 22900
Trader Rating: (28)
dude.. you need the AGP race FMIC to complete your machine! group buy is pending on the badass intercooler. check out the general discussion are for the group buy interest.
this will def. give you more power especially if you running larger turbo.
s2 w/out toys, E1, Realtune mani w/ Turbonetics external gate/dump. DCR 500WHP bottom-end with oil pump and big filter kit. AGP Race FMIC, JMB PP's, DTEC FC, Greddy TT, JMB CC, Port/Polish Intake and TB, Dog Bones, MaxFab full 3" side exit, CoolingMist water/meth injc, IPP coilovers, AEM UEGO, Autometer Pyrometer EGT, Mopar STS w/ boogers, Greddy Type RS BOV, K&N Gen II Air Intake Kit, Turbo XS dual HPBC, Walbro pump & stock drive axles.
srt4_riceater is offline   Reply With Quote
Old 04-15-2005, 10:54 AM   #4 (permalink)
I have allready installed everything I need with my S2.
I was reffering to like needing a new WGA, SAFC, BC, or will my S2 still be able to manage the air/fuel and boost if I only want to hold 20 psi.?
I know I will need a different WGA, I was planning on getting a Tial one.
Will this kit bolt up to my exhaust? I have a cat-less 3" down pipe, it looks like it will bolt up to where my exhaust allready goes.
Old 04-15-2005, 11:05 AM   #5 (permalink)
SRToc Member
Trader Rating: (28)
bump??
you have aftermarket intercooler?
Old 04-15-2005, 11:40 AM   #6 (permalink)
skipdogg's Avatar
New wastegate is included with turbo kit. Tial 38mm by default
Yes kit will bolt to your current exhaust...
I would highly recommend getting a boost controller
Stage 2 will handle the A/F but only to the point.. Get the most out of your system by going with an AGP Fuel kit as well.
I think 20psi will be ok on stage 2 fuel, but check with AGP...
Old 04-15-2005, 11:40 AM   #7 (permalink)
SRToc Member
oksrt's Avatar
Member Number: 8144
yes it will bolt up, what you need is an safc, bc if you wish to play with boost, big race fmic, if you want 400+ either get a return line or get the agp fuel kit with 750 injectos. the turbo comes with a wg
oksrt is offline   Reply With Quote
Old 04-15-2005, 02:37 PM   #8 (permalink)
Quote: Originally Posted by srt4_riceater
bump??
No, the stock one will do for now. I personally know of an SRT-4 with 500 whp with the stock FMIC.
Old 04-15-2005, 02:41 PM   #9 (permalink)
skipdogg's Avatar
How much is he spraying?
Old 04-15-2005, 02:44 PM   #10 (permalink)
My main question is: Will my S2 PCM still control the air/fuel as if I was still using my stock turbo? I use my WGA to adjust my boost levels, will the Tial WGA do the same thing?
I don't want only 15 psi from the stock computer setup. I want to be able to hold 20psi to redline.
Old 04-15-2005, 02:59 PM   #11 (permalink)
50, but he's getting 100whp out of it.
Old 04-15-2005, 03:11 PM   #12 (permalink)
SRToc Member
oksrt's Avatar
Member Number: 8144
i think to hold 20 to red line with the stage 2 injectors you are gonna need a return line, or just get the 750's, but i highly doubt that the stage 2 pcm will keep your a/f ratio in check with that much boost from a much bigger turbo, get the safc and play it safe.
Old 04-15-2005, 03:19 PM   #13 (permalink)
skipdogg's Avatar
The tial will kinda - sorta work the same way. Basically you'll put the 2 springs in there and it should hold 15 or so by itself. Thats where the boost controller comes in.
Old 04-15-2005, 03:25 PM   #14 (permalink)
I dyno'd 287whp and 322wtq spiking at 17psi and droping down to 14 at redline with what I have now. At redline my A/F ratio was 10.5 between about 4500 and 6500 rpm was in the 10's and 11's. I have thought about putting the S1 injectors in to lean it out a little. I have no problem using the SAFC or a BC. I am just wondering if I need to buy those when I do my turbo swap.
I keep having people tell me to play it safe and get S3 but I don't want to spend allmost $3k for it.
Old 04-15-2005, 03:26 PM   #15 (permalink)
So is AGP going to put their 2 cents in on this?
