Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 09-06-2009, 01:22 PM   #1 (permalink)
ST3PH3N'S SRT-4's Avatar
Member Number: 57024
Trader Rating: (41)
Default Water Cooled standard bearing turbos.
Is there any break in process for these or just make sure its not leaking and let it rip?
Stephen.
JJ&b Built, Corn Fed SRT-4
Powered by GT35r
ST3PH3N'S SRT-4 is offline   Reply With Quote
Old 09-06-2009, 03:24 PM   #2 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
we suggest with any turbo
Before attempting to start the engine, crank the engine with the fuel/ignition shut off for ten to 15 seconds (three separate times) or until the instruments show an oil pressure buildup. Start the engine and allow running at idle speed for 15 to 20 minutes without accelerating or until engine has reached full operating temperature. Check for oil/water leaks around turbocharger and related installed components. After it has been determined that there are no leaks in the oiling system of the turbo, allow approximately 100 miles driven under normal conditions without going into "boost". This is done to properly wash out all of the assembly lube used when assembling the turbocharger, and to allow carbon to build up along the piston ring areas of the turbine shaft. Immediately running the turbocharger to its full potential without proper break-in procedures will cause premature turbocharger failure.
NHRA Pro Stock Motorcycle - Kenny Van Buren
Come see AGP Turbo at NHRA Full Throttle events.
Ben@AGP is offline   Reply With Quote
Old 09-06-2009, 03:44 PM   #3 (permalink)
Trader Rating: (41)
Awesome. Did the first couple steps just didn't know how long to baby it. Thanks ben.
Old 09-07-2009, 01:43 PM   #4 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
Make sure you ditched that Turbonetics oil feed fitting.
Old 09-07-2009, 02:48 PM   #5 (permalink)
Trader Rating: (41)
i did hahahaha
Old 09-08-2009, 07:45 PM   #6 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
just out of curiosity why ditch the oil feed fitting??
Crane 14's
Ragin_SRT is offline   Reply With Quote
Old 09-09-2009, 12:07 AM   #7 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
Because our turbos are not designed to run the Turbonetics fitting.
Page generated in 0.18063 seconds with 13 queries
