Twin Scroll Turbo Kit? Pics inside - Page 5 - Dodge SRT Forum
post #61 of 134 (permalink) Old 05-06-2014, 06:20 PM
New Member
boostedsohc's Avatar
Quoted: 1 Post(s)
Originally Posted by Ben@AGP View Post
The turbo is in the same position as our log manifold kits so the exact same "modification" will be needed.
if anything should only need to clock the turbo. I know how to do it on my d44 kit
boostedsohc is offline
post #62 of 134 (permalink) Old 05-15-2014, 06:36 AM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
Originally Posted by Ridin59vette View Post
I didn't know you had a 1.25 For the 256. I would've kept it and went twin scroll
there is no surge whatsoever on the 1 ar.. not even close. If anything im going to put the .75 cover on.
AGP Twinscroll s256
+1 Race head, Race ported IM
BC 2 cams
Built Motor
Meth Injection
11.4@125mph (old times,S3, stock head and cams) 26psi)
Turbolag87 is offline
post #63 of 134 (permalink) Old 05-15-2014, 06:43 AM
Ridin59vette's Avatar
Quoted: 407 Post(s)
Post up the results . How are you liking it so far?
Sent from
04 SRT-4: 9:1 Compression, Built head, Crower s2's
Twin scroll BW366 and Dogbox Coming soon!
2011 Silverado Z71: Daily Driver
"Life is hard, it's harder when you're stupid"
" If you want to win, don't do it by a bumper.... do it by Buses "
Ridin59vette is offline
post #64 of 134 (permalink) Old 05-15-2014, 06:53 AM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
Sent from
car is completly different. No part throttle boost so trying to pass ppl on the hwy means taht i have to floor it . Power wise the car is different as well. Power is smoother and i tend to hit the rev limiter right away as the car just wants too keep pulling and pulling. I have the limiter set to 6600 and i believe it will make power to 7k with no issues. my BW stage 3 would die off around 6100. Im gonna drive the car around more to get used of it and then i might install the .75 ar and take it from there. One odd thing that I did not expect was the spoolup noise My stage 3 sounded like a jet, this 256 barely makes any noise lol. I'll be taking some vids soon then off to the dyno.
I'll keep you guys posted. im also having problems controlling boost.... just some kinks i have to fix
AGP Twinscroll s256
BC 2 cams
Built Motor
Meth Injection
post #65 of 134 (permalink) Old 05-15-2014, 07:31 AM
Quoted: 407 Post(s)
The lack of nois is weird . My 256 was one of the loudest turbos I've had.
Sent from
post #66 of 134 (permalink) Old 05-15-2014, 08:58 AM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
Sent from
Ur telling me. All I heard from ppl is the spoolup noise. But I can barely hear anything. Odd
Sent from
AGP Twinscroll s256
BC 2 cams
Built Motor
Meth Injection
post #67 of 134 (permalink) Old 05-15-2014, 10:53 AM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
well went for a few more runs after adjust my boost box setting too everything i could possible do, and I still cannot for the life of me get boost out of this thing. I currently have a 7psi spring installed with the boost box set at 26psi and im lucky if i can get 16psi. U guys have any idea?
AGP Twinscroll s256
BC 2 cams
Built Motor
Meth Injection
post #68 of 134 (permalink) Old 05-15-2014, 11:19 AM
Quoted: 407 Post(s)
BLT. Check the bolts on the manifold.
post #69 of 134 (permalink) Old 05-15-2014, 03:22 PM
New Member
tkilla's Avatar
Quoted: 0 Post(s)
7 X2= 14psi max on spring.
Looks like you need a 14 lb spring to reach your target goals on the boost box. Also you can try to play solenoid duty cycle to get more boost out of it (not sure if the boost box has that feature).
Norcal Built, Rage-tek and Reed32 tuned
Look up tkilla srt on youtube for my vids..
Old build:23psi dsp
11.4@121 fully built AGP 255 w/.48ar and e85
New build:
6xmm turbo
New set up
stronger build
new times coming soon
tkilla is offline
post #70 of 134 (permalink) Old 05-16-2014, 06:16 AM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
im brining the car back in to change the turbine housing to a .75 too laggy for my tastings. plus ill be installing 2 springs in the wga too see if it changes my boost at all. MAN i cannot wait too get the car running perfect and at 25psi... with my ported top end this car should make some power... then off too the dyno it goes.
AGP Twinscroll s256
BC 2 cams
Built Motor
Meth Injection
post #71 of 134 (permalink) Old 05-17-2014, 12:17 PM
Quoted: 0 Post(s)
i have the smaller spring in my waste gate and getting 24 pounds no problem. must be something with your boost box settings. same set up as you only with the .75 housing
party boy is offline
post #72 of 134 (permalink) Old 05-22-2014, 01:46 PM
New Member
Quoted: 1 Post(s)
any update on this? pics of the install?
post #73 of 134 (permalink) Old 05-28-2014, 11:52 AM
New Member
OH5SRT4's Avatar
Quoted: 0 Post(s)
Ben, any plans to offer a fabbed o2 housing along with this manifold to mate to existing exhaust systems?
AGP Powered - Turbo666 Tuned
Zeta 2.8
OH5SRT4 is offline
post #74 of 134 (permalink) Old 06-03-2014, 06:05 PM
Reao's Avatar
Quoted: 0 Post(s)
I am in for more updates on this setup.
| Hahn Racecraft 20G | E85 | Diablo Tuned By Performance2ning | 330hp 350tq on P2ning's mustang dyno |
Reao is offline
post #75 of 134 (permalink) Old 06-21-2014, 04:25 PM
bryan9097's Avatar
Quoted: 0 Post(s)
Garage
Ben can the delta 46 journal be converted to this setup? Would it be worth it?
Sent from
bryan9097 is offline
User Tag List
Linear Mode Linear Mode
