Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 09-15-2004, 03:35 PM   #106 (permalink)
LucyBop's Avatar
Member Number: 9095
you get a new manifold....
637hp/596tq!!
LucyBop is offline   Reply With Quote
Old 10-20-2004, 06:45 AM   #107 (permalink)
AWDnot2's Avatar
Member Number: 8379
Quote: Originally Posted by IOWNYOU
Agp what do you think the top speed of a car running a 60 trim .63 Housing Compared to a 50 trim with .63 with all accomdating mods is? Any Idea?
The top speed would not change. Top speed is determined by the gear ratios in your transmission. What would change is the amount of time it takes to get to top speed.
Your happiness is intertwined with your outlook on life. The only normal people are the people you don't know.
AWDnot2 is offline   Reply With Quote
Old 10-29-2004, 05:09 PM   #108 (permalink)
Member Number: 3865
do you have dynos graphs or anything showing an awd dsm makin 520 all wheel hp on pump gas? this seems hard to believe for a 50 trim
blue176 is offline   Reply With Quote
Old 10-30-2004, 02:04 PM   #109 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
even dyno graphs could be manipulated to show whatever it is that you like....even AGP said making 500+ whp would be very, very difficult with a 50 trim...
RoostBoost is offline   Reply With Quote
Old 11-26-2004, 06:31 PM   #110 (permalink)
killervenom's Avatar
Member Number: 14572
The GT40/T350 can hit mid to upper 600's with the .63 a/r right what kind of lag time would the .82 be and when this frieght train hits would you be able to hit 700's? If one were to get this kit kit would the 550hp axles hold off in the 2-5 gears i know i would never hit more then 15-18 psi in first that might even bee dangerous. If not what would you suggest hold this monsterious power??
Current Mods : Psi-Fi CAI, MSD 8.5 MM Wires, Mpx Heat Shield, DC Front & Rear Strut Bars, Mopar STS, Booger Bushings, JLM Motor Mount's, AGP Race FMIC, JBM Hard Pipes, Billet Check Valve, TL retrofit projectors, Mpx UDP, SRT Oil Press., Pyrometer, LFS Fuel Rail, AEM UEGO
***ALL FOR SALE*** PM ME OR EMAIL
killervenom is offline   Reply With Quote
Old 12-07-2004, 07:48 AM   #111 (permalink)
Dark Syde SRT-4's Avatar
Member Number: 18242
Trader Rating: (79)
Sigh you dont recommend the 57trim thats what i got man IS anyone running the 57 and what do you think of it
Dark Syde SRT-4 is offline   Reply With Quote
Old 12-11-2004, 11:42 PM   #112 (permalink)
Member Number: 4762
Trader Rating: (20)
i have a question about turbine a/r. with the gt3147 i think a .48 would be the typical a/r allowing you to spool up as fast as possible? seems to me like i would want to upsize my exhaust housing if i was going to run nitrous to give me a higher topend and not choke the turbo up top. any insight on this? would the .63 be enough or would i even want to run an .82 given i WILL be spraying?
vector4 is offline   Reply With Quote
Old 01-08-2005, 08:00 PM   #113 (permalink)
Brian87gt's Avatar
Member Number: 4097
Default which to get
I'm gonna be getting one of your turbo kits in a few weeks. I like the 60 trim, but don't like the slower spool, could you pair it up with a .48 ar to quicken up the spool, or is that not a good idea. I rarely plan on running race gas, so would the 50 trim be a better idea? I have maxed out my supporting mods, so would that help with quicker spool? What is the max HP you have seen without race gas with the 50 trim? Thanks!
Brian87gt is offline   Reply With Quote
Old 01-16-2005, 11:32 AM   #114 (permalink)
Member Number: 18728
Quote: Originally Posted by Nick@AGP
"If these numbers are big enough for you, then look no further and order a 50 trim. Its a $100 option, but well worth it."
On your site it says the 50 trim is a $300 option?!??
NeonRT99 is offline   Reply With Quote
Old 02-01-2005, 07:25 PM   #115 (permalink)
Member Number: 19344
whats the max power i could get out of the 50 trim wit a .43 a/r on pump gas?
SRT4Maniac is offline   Reply With Quote
Old 02-01-2005, 10:22 PM   #116 (permalink)
Z1500's Avatar
Member Number: 329
I think you mean .48 a/r and it would be about 380whp.
AGPWD alliance member #1
Kevin
www.AGPturbo.com
In theory there is no difference between theory and practice, in practice there is.
Z1500 is offline   Reply With Quote
Old 02-13-2005, 08:55 PM   #117 (permalink)
Member Number: 23105
what need to be changed to put a turbo on non turbo neon
dub1 is offline   Reply With Quote
Old 04-25-2005, 10:06 AM   #118 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Mopar Stages
Stage 0- Works great and is my personal favorite.
Why is this?
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 04-30-2005, 11:50 AM   #119 (permalink)
chewie's Avatar
Member Number: 5027
Trader Rating: (21)
Is there a turbo selection guide for the Ball bearing turbos?
No more SRT-4 for me.
chewie is offline   Reply With Quote
Old 04-30-2005, 04:57 PM   #120 (permalink)
Nick@AGP's Avatar
Member Number: 11546
I like stage 0 because its free.
Ball bearing turbos I suggest calling us. Basically this covers the ball bearings. A general rule of thumb is 10hp per 1psi of boost, so a 55lb gt30 can make ~550hp. 65lb is good for 650hp, etc..
Nick@AGP is offline   Reply With Quote
