Good job so far on the Turbo guide. This will definitely help the less knowledgeable people like myself.
Maybe an idea to add would be your info/opinion on the combination of using the Mopar Stages 0, 1, or 2 along with your Turbo upgrades. What are the advantages/disadvantages of using one Stage over another in conjunction with the AGP Turbo upgrades? Does one Stage over another create difficulties that the others don't? If there is answers to these kind of questions maybe you can help.
i, too, would also like to know this, i want 400whp with a 50/.63, safcII, fuel pump and 650 inj. do i have to run a s1 or s2 ECU?
All of them work. If you want to waste money on Stage 2, then go ahead, you'll get a higher redline and a 3 bar. Alot of people run fine on stage 0, stage 1, and stage 2. Get whatever floats your boat. Stage 0 seems to make the most power due to the advanced timing. Alot of people have good luck though with stage 2 also.
so to beat a dead horse even further, Nick, i have Stage 2 and would gladly sell it and go back to stage 0 with the turbo kit. what are your thoughts on that?
It's really a toss up. You do get some advantages with stage2, we all know what they are.
Stage 0 gives you the most aggressive timing advance.
Don’t all piggybacks allow X% of adjustment over what the stock ECU is setup for? Thus is why you run 650’s with the stage 1 + piggyback and the 750’s with stage 2 + piggyback.
Please note if this is not correct then it's b/c I don't know crap about crap I just read a lot...
I should be considered the best seller on her as my customer service rivals every vender on here, well except AGP and Hector and I would say I'm as good as them Especially when you consider people come to me for help when Hector terns them away since they did not buy there stuff from them.
Did I mention I don’t even own a srt any more...
i meant in regards to which PCM would yield better results. it sounds like the aggresive timing advance of stage 0 maybe be more benficial for power output with your kit. (thanks Ben) and obviously i'd be happy to sell it because for me it was a waste of money!
thanks for all the important info!! so if stage 1 works well w/650cc, and stage 2 works well with 750cc, then what would stage 0/stock ecu work better with?? I'm debating which ecu (stock or stage 1) will be better for use with the SAFC II and say, 650cc injectors...
SRTboy,
The S2 does have some nice features so I'd say only sell it if you can get most of what you paid for it. Remember, you will be able to sell the S2 injectors ether way so there's a few bucks. When our PnP standalone is out you will be selling all that stuff including the SAFC anyway
SRTboy,
Roost,
For S0 you want 650's.
Kevin
PnP Standalone? Hey wait a second now Kevin thats not fair, need info.
I'm VERY interested in the PnP standalone!! I would like to know details on when, how much and everything else you can tell us about.
The standalone will get rid of the need for our stock/stage 1/2 ecu's??
You'd also need a dyno to properly tune the standalone? or would a wideband be good enough?? thanks for the info as I don't think the SAFC II is going to be good enough for daily driving and 400HP!
