Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 03-03-2007, 11:09 PM   #1 (permalink)
busarich's Avatar
Member Number: 25901
Trader Rating: (32)
Default turbo manifold stud size??
Could anybody tell me what size to get for the turbo manifold studs (to mount to the head)? M? X ? also to mount the turbo to the manifold and the o2 housing to the turbo??? Thanks
MODS: Mostly stock
DYNO VIDEO - http://www.youtube.com/watch?v=NcQkdzEbry0
busarich is offline   Reply With Quote
Old 03-03-2007, 11:12 PM   #2 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
Should be the same all the way around. 12x1.25mm...cant remember the last number...I wanna say 8
Old 03-03-2007, 11:54 PM   #3 (permalink)
busarich's Avatar
Trader Rating: (32)
Thanks will check it out. I don't have the motor back yet or it would be a lot easier. I would just buy one and check it out.
Old 04-01-2007, 06:12 PM   #4 (permalink)
<|SRT-4|>'s Avatar
Member Number: 30959
Trader Rating: (76)
Bump, need an answer ASAP.
I tried M8x1.25x12 and they don't seem to fit, but one of my bolts that bolt the turbo to the manifold fell out.
Is it possible to get a couple replacements sent to me?
<|SRT-4|> is offline   Reply With Quote
Old 04-01-2007, 08:44 PM   #5 (permalink)
Member Number: 42667
M8 x 1.25 exhaust manifold to head
M8 x 1.25 turbine housing to O2 housing (on my 50 trim)
3/8" course - turbine to exhaust manifold
5/16" course - wastegate to exhaust manifold
05plsrt4 is offline   Reply With Quote
Old 04-01-2007, 09:14 PM   #6 (permalink)
<|SRT-4|>'s Avatar
Trader Rating: (76)
Thanks .
So basically I need a 3/8 coarse to fix my problem. Are there any specs I should look out for? Know the size of the lock washer by chance?
Appreciate the help
Old 04-03-2007, 06:00 PM   #7 (permalink)
<|SRT-4|>'s Avatar
Trader Rating: (76)
Just as a future reference, I called AGP to get the info for the turbo to manifold bolts:
Full spec is 3/8"x1" grade 8 coarse thread
Old 09-30-2007, 05:55 AM   #8 (permalink)
Member Number: 57721
i used 10x1.5 in my agp mani and they worked awesome.......hmmmmm
onthedwnlow2 is offline   Reply With Quote
Old 10-01-2007, 09:44 AM   #9 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
The old welded together log manifolds were M10x1.5 for the turbo bolts, and M8x1.25 for the wastegate bolts.
The cast manifold is 3/8x1 and 5/16x7/8 respectively.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 10-01-2007, 12:36 PM   #10 (permalink)
my new cast mani has 10x1.5's on the turbo
Old 10-01-2007, 01:04 PM   #11 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
No it doesn't. You can certainly jamb an M10 through the 3/8 holes and think it fits, but it doesn't and you will ruin the threads.
Old 10-01-2007, 01:07 PM   #12 (permalink)
im telling you right now whn i got the mani i went thru a bolt bin to find the proper bolts to bolt my turbo down on it and the 10x1.5 was perfect...no american size even came close......i pieced together my whole kit and its a complete agp setup now except the oil feed which was made local
Old 10-01-2007, 01:09 PM   #13 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
That's good to hear. I load the machines and I machine the manifolds here, and I know what taps are in the tool changer. You can believe what you want, but our cast manifolds have ALWAYS been 3/8 and 5/16.
Old 10-01-2007, 01:22 PM   #14 (permalink)
and now that i think about it the wg bolts were 8x1.25 also....the same as the o2/turbo bolts and the dump tube to wg bolts
Page generated in 0.28506 seconds with 11 queries
