Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 06-14-2008, 08:03 PM   #1 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (31)
Default Temp Sensor problem
Well we installed aem ems today and on the break in tune we discovered that the intake air temp was 52 degrees and it was 90 outside.... Could my sensor have gone bad again in my uppipe....?
I just noticed that you have to choose what kind of iat you have... Can you tell me what sensor i choose on the aem for your iat sensor in the uppipe..?
"When the turbo spins, the bullshit ends"
d_fl8ted1 is offline   Reply With Quote
Old 06-15-2008, 08:45 AM   #2 (permalink)
trunks0112000's Avatar
Member Number: 39509
sorry man don't mean to hijack you're page but what color wire do u solder them to cause both the wires are black on the SRT-4 AGP Screw In Temperature Sensor Kit (I know the stock harness has color strips but I just need to know if it matters)
Stg 3R W/Toys,N2MB Wot Box(2step),AGP 3''Cold Air Intake,AGP DogBone MM,AGP Stg 3 WG,AGP FMIC,AGP Catch Can,NeedSwing DP W/Ecut TB (Custom Apexi N1 Evolution) -MAXX Fab 3'' O2 Housings,Centerforce clutch,Tial 50mm BOV,Ultimate Racing Hot and Cold side pipes,MSD Weirs-NGK Plugs,AEM UEGO Wide Band,Mopar STS,Greddy TT,Tein H Tech (Gold),HID 12k
trunks0112000 is offline   Reply With Quote
Old 06-15-2008, 09:48 AM   #3 (permalink)
Member Number: 42667
You need to choose the SRT-4 AIT sensor in the EMS.
05plsrt4 is offline   Reply With Quote
Old 06-15-2008, 12:22 PM   #4 (permalink)
d_fl8ted1's Avatar
Trader Rating: (31)
ok thank you very much... will do that..
Old 06-15-2008, 01:31 PM   #5 (permalink)
$PK$'s Avatar
Member Number: 47676
my agp sensor in my pipe consistently read 25-30 degrees higher than actual temps. Threaded my stock sensor and it is fine now. Just something for thought. I never really liked the whole "it doesnt matter which wire setup", it obviously does for the stock sensor.
$PK$ is offline   Reply With Quote
Old 06-15-2008, 02:44 PM   #6 (permalink)
The sensor is just a resistor, which will give the exact same resistance no matter what way the wires are connected (depending on the temp of course)
Old 06-15-2008, 04:17 PM   #7 (permalink)
d_fl8ted1's Avatar
Trader Rating: (31)
but mine was running 52 degress when it was close to 100 outside.... i am going to say my temp sensor is wrong.... this is the second one i have went through i guess i need to just order another one...
Old 06-15-2008, 09:00 PM   #8 (permalink)
Just make sure you have the correct one selected or the temp vs resistance chart in the EMS will be all outa wack. Causing the temp to read wrong.
Old 06-18-2008, 12:41 PM   #9 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
The thermistor that we use on our sensors reads exactly the same as the stock sensor. You can also check the resistance on that sensor with a voltmeter to verify.
Jon@AGP is offline   Reply With Quote
Old 06-21-2008, 10:36 AM   #10 (permalink)
playboy2k4's Avatar
Member Number: 19466
subscribed
playboy2k4 is offline   Reply With Quote
Old 06-22-2008, 06:54 AM   #11 (permalink)
d_fl8ted1's Avatar
Trader Rating: (31)
Well we tuned yesterday without the temp sensor working so i am going to be ordering a new sensor again...... and install it ...
Page generated in 0.16661 seconds with 11 queries
