I quote from agp...
".....You should only be running a properly sized check valve (like the one above) if and only if
you're removed the factory PCV. You should never, ever never, never, ever run a check valve in conjunction with the factory PCV. You've now added an additional airflow restriction on probably the most important system of your engine...."
I NEVER really saw the point of the "check valve band wagon" If you pvc is working correctly, and your running a SEALED catch can, OR no catch can at all and strait to the TB, whats the problem??? Ive ran with and with out catch can to tb, and never had a issue?
So whats with this "check valve" talk?
Maybe jon can explain why so many are turning to buy these check valves. NOT TO MENTION many of the peps using check valves Also do NOT get rid of there pvc's?
