Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 09-30-2004, 05:35 PM   #1 (permalink)
can't stop spinning's Avatar
Member Number: 9183
Default Stupid noob type question
I have your wga, and it's hooked up from the turbo, where the green line used to be, to the mbc and then to the wga. Now I can't get my car to boost past 15lbs without some sorta studdering, or boost cutout.
I've read that the blue line may solve this problem, so my question is, since I have removed my green line, what lines do I have to put back and where? I live in a small town, so I can't just go and take a look at a stock srt4's lines or anything like that.
On the bright side of things, I love the wga, it makes my mopar bov go off like crazy.
Thanks for any help. And yes, I do feel kinda dumb asking this, but I can't seem to find the answer I need, so I thought I'd ask the pros.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 09-30-2004, 09:12 PM   #2 (permalink)
Z1500's Avatar
Member Number: 329
Sounds like a spark problem. Pull your plugs out and gap them down to .030"
AGPWD alliance member #1
Kevin
www.AGPturbo.com
In theory there is no difference between theory and practice, in practice there is.
Z1500 is offline   Reply With Quote
Old 09-30-2004, 10:08 PM   #3 (permalink)
Member Number: 9183
I have NGK plugs gapped at .040, think gaping down to .030 will help?
Old 09-30-2004, 10:10 PM   #4 (permalink)
SRTTurbo's Avatar
Member Number: 5464
i have the same deal, I can be part throttle and boosting 5-10 lbs and it will jerk the car a bit, like it wants to go but its not. I dont have this problem in WOT, just when i want to casual drive. U think it may be the plug gap also. I have the NGK's gapped at .40
Mike
Best time Street tires stock turbo setup 13.501@103.31
AGP 3147 Stage 3 T3/T04 turbo kit, MaxxFab DP, PTP CV, DC's strut bar,180 degree stat, magnacore wires, ngk V-power plugs, AGP 3" CAI, IP2 filter, AEM UEGO AFR Wideband, Mopar STS, Mopar Stg 1 Springs, Booger Bushings, ebay CC, Deyeme MM's, Turbo XS RFL, Mopar Borla Exaust, IP2 CF Hood, CF kanards, CF Foglight bezles.
SRTTurbo is offline   Reply With Quote
Old 09-30-2004, 11:20 PM   #5 (permalink)
Lord J's Avatar
Member Number: 8810
i have my plugs gapped at .35 boosting at 17psi, dropping to 14 to 15 to redline
2004 MX-5 Mazdaspeed | AEM SRI | Turbo XS RFL w/ Custom Hardpipe | Apexi Custom Exhaust Catless w/ Custom Downpipe | Blitz SBC I-D 3 Boost Controller | Blitz Turbo Timer | Evo Intercooler | H&R Racing Springs | Bride Pro Racing Seat
Lord J is offline   Reply With Quote
Old 10-01-2004, 12:31 AM   #6 (permalink)
Member Number: 9183
My problem is only at WOT, below 3000rpm, and with the boost set higher then 15lbs. Once I lower my boost to 15lbs then I'm fine. Also I'm having problems holding 15 till redline. If I turn up the wga so I hold 15lbs to redline, then I'm hitting 19-20lbs in 3rd and 4th gears, and that's with the mbc set to minumum.
Old 10-01-2004, 02:47 AM   #7 (permalink)
Z1500's Avatar
Member Number: 329
That may be compressor surge. Does the turbo make a noise and you maybe get a slight pulsation in the car?
As for holding level boost that's all in the adjustment of your boost controller and WGA. You have to preload the WGA enough to hold high boost at redline then close up the boost controller untill it doesn't spike. It takes a bit of work to dial it in.
Old 10-01-2004, 09:56 AM   #8 (permalink)
Member Number: 9183
I get a pulsation in the car, but I can't hear any different noises from the turbo. But the pulsing from the car feels more like it's cutting boost. Sometimes you can actually see the boost gauge flutter, this will happen before it even hits 15lbs. Could my boost gauge possibly be out? and I'm putting out more boost then I think I am?
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.17447 seconds with 13 queries
