Here it is, in all its AGP Turbo glory. Introducing the most complete, easy to install, fastest spooling, killer power, no tuning required, turbo upgrade for your Dodge Neon SRT-4.
Everyone loves to ease of the "Big M's" Stage 3 turbo upgrade but the power, availability, and upgrade-ability has always left a little on the table so to speak. Here is the answer to everyone's wishes, and of course it comes straight from AGP Turbo. For the last year, we have been developing and testing numerous turbo combinations that give you exactly what every SRT-4 owner has always wanted.
The Stage 3 Delta from AGP comes as a complete package, much like the "Big M's" but you get better boost control via a boost controller with an external wastegate. 15-20% more power right out of the box, exact spoolup as the "Big M's" Stage 3, and future upgrade-ability with our larger turbos that we've always offered. Oh, and the best part is not waiting months to receive your kit once it's ordered.
On cars with the basic bolt-on upgrades, we see ~350wtq and ~350whp at 20psi on pump gas. Click the bost up to 24psi and see ~390wtq and ~390whp still on pump gas with the 40lbs/min wheel. The 44 and 48lb wheels will deliver very similar numbers at those boost levels. We have setup the fuel and ignition mapping very conservatively to make sure this setup is perfectly safe to run every day, all day, and hit up the race track every weekend.
We are offering three different compressor wheels rated at 40lbs/min, 44lbs/min, and 48lbs/min. Depending on what your overall power goals are, you can select the Stage 3 Delta combination that suites your needs perfectly.
The AGP S3D Complete includes the following components:
-AGP Turbo kit with customer selected compressor wheel
-RC 750cc injectors
-Walbro 255lph Fuel Pump
-AGP Specific SCT Flash w/ 3bar MAP sensor
Modifications Needed to run this:
-3" intake
-External Blow Off Valve Setup
-3" exhaust (not needed, but highly recommended)
Get your orders in now! Click
here to purchase. $2850
