Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 06-16-2005, 09:26 PM   #1 (permalink)
Tree_Top's Avatar
Member Number: 7286
Default Stage 2 injectors enough to run agp turbo??
I have stage 2 without toys and was wondering if the stage 2 injectors are big enough to run the 50 trim/ .63 ar housing by letting stage 2 control the boost???? I thought about buying the turbo kit and later buy the fuel kit when I wanted more power. Just wondering if I could do this safely by letting stage 2 control the boost. And this is assuming I have the agp front mount intercooler and BOV. Thanks.
Tree_Top is offline   Reply With Quote
Old 06-16-2005, 09:35 PM   #2 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Yes I was running S2 with my 50 trim and had no issues but once you install a turbo kit, the pcm will no longer have control of the boost because you eliminate all of the vacuum lines.
Old 06-16-2005, 09:40 PM   #3 (permalink)
Tree_Top's Avatar
Member Number: 7286
I thought some people were letting the pcm control the boost? I may have read wrong??
Old 06-16-2005, 09:48 PM   #4 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (49)
Ya, my buddie is running a 50trim with S2 injectors...holding like 17-18.
Old 06-16-2005, 09:50 PM   #5 (permalink)
Tree_Top's Avatar
Member Number: 7286
What type of air fuels are you seeing through out the rpm range???
Old 06-16-2005, 10:33 PM   #6 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (69)
You won't be able to max out the 50-trim due to the injectors being too small. Stage 2 will only support around high 300's horsepower.
Jon@AGP is offline   Reply With Quote
Old 06-16-2005, 10:48 PM   #7 (permalink)
JohnL's Avatar
Member Number: 2265
Hmmm, so with stage 2 injectors and a 50-trim, one could achieve 350 hp???
Looks like I'm going to have to drive from Tucson and come talk to you guys......
Had an SRT-4.....now I have nothing
JohnL is offline   Reply With Quote
Old 06-16-2005, 11:59 PM   #8 (permalink)
quicky4's Avatar
Member Number: 28222
what injectors or other fuel mods do you prefer to run if i was to get a 60-1 turbo upgrade?
quicky4 is offline   Reply With Quote
Old 06-17-2005, 05:06 AM   #9 (permalink)
Tree_Top's Avatar
Member Number: 7286
Thanks Jon, I knew you needed more fuel and boost to max out the 50 trim, just trying to make sure I could run it safely with the stage 2 injectors. I'm only looking for 330 to 350hp right now. It is possible to let stage 2 control the boost for now isn't it? I know I read somewhere that a couple people were doing this and were achieving around 330hp? I don't want to run any air fuels higher than 11.5-11.8 if I don't have to. Just wondering if I can do that with the stage 2 injectors running at whatever boost it'll run? Thanks again.
Old 06-17-2005, 06:53 AM   #10 (permalink)
Tater's Avatar
Member Number: 18499
Trader Rating: (10)
Like evo said, when you install the 50-trim, you eliminate the stock vacuum lines that control the boost, so the S2 pcm has no control over the turbo/wastegate. You will be able to control boost with wastegate spring/mbc.
Those people that you saw making around 330 whp probably did have the full Stage 2, but were controling the boost externally. I think the only non-stock turbo kit that still utilizes an integrated wastegate is the Mopar Stage 3, which still allows the pcm to control boost. Someone please correct me if I am wrong.
Tater is offline   Reply With Quote
Old 06-17-2005, 07:11 AM   #11 (permalink)
evo77's Avatar
Member Number: 1346
I remember only one person that was supposedly letting the boost solenoid control boost and that was bigmosrt. He has the 3147 turbo.
Performance Autowerks did the install. Here is what Ron had to say:
Quote: Originally Posted by TRAXMAN199
He was creeping lean past 17psi on the S2 injectors. So we didn't push the issue. With a return fuel set up he should be able to get a little more out if it. When we dynod the car it was fairly cold outside. We acutally have his WGA running off of the S2 controlled factory silonoid. Worked good! Just add a bit more fuel Mo and you can have a little more fun. Remember not having that watter cooled shaft bearing really meens you have to keep up with your oil changes now!
IMO hooking up that solenoid is pointless. Tree Top, just have the wg control boost and you'll be fine. Consistent 17 psi every time.
Old 06-17-2005, 08:20 AM   #12 (permalink)
skipdogg's Avatar
Member Number: 18045
I'm pretty sure 350 on stage 2 injectors is pushing it on pump gas. 330 is very doable.
skipdogg is offline   Reply With Quote
Old 06-17-2005, 08:44 AM   #13 (permalink)
Nick@AGP's Avatar
Member Number: 11546
Stock injectors are doable. Hell, you could downgrade injectors if you wanted to honda ones or something and still run a t67. Just limits you on max power and boost.
Nick@AGP is offline   Reply With Quote
Old 06-17-2005, 12:47 PM   #14 (permalink)
Colt4g63's Avatar
Member Number: 22988
I did 370whp on S2 injectors, but the fuel pressure was CRANKED and the injectors were DONE. Not a safe way to make power thats for sure. Get some 750s and call it a day.
O5 Black SRT
Stage1, AGP FMIC, MPx 3" turboback, AGP 50 trim-7.6@97mph in the 1/8th at 25psi
458whp 503TQ @26.5psi
91 Talon AWD fully built but daily driven
Shakedown low boost pass on the stock ECU 7.23@103.66mph on a 1.78 60ft in the 8th. 15 more psi and nitrous to come....
01 Turbo GSX-R1000 240WHP on 7psi. High boost WHP unknown..
Colt4g63 is offline   Reply With Quote
Old 06-17-2005, 05:40 PM   #15 (permalink)
Tree_Top's Avatar
Member Number: 7286
What kind of air fuels are you guys seeing running off the stage 2 injectors at around 16-17psi? Is it consistent throughout? Anyone have a dyno graph with stage 2 running a 50trim turbo??? Thanks guys. Thanks evo77 and nick@AGP.
» Sponsor Links
»Garage Storage and Cabinets
