03-06-2008, 09:07 AM
#16 (permalink )
Member Number: 136
Quote: Originally Posted by
str5010
AGP wants to take all my money. First the ECU flash, now this.
Yeah, seriously.
I'm going to rock the 50 trim for a while, then when I can afford the down time to build up the motor i'll go bigger.
03-06-2008, 01:18 PM
#17 (permalink )
Member Number: 42215
i want to buy just the turbo can somebody pm me the price please..
Thanks....
03-06-2008, 01:19 PM
#18 (permalink )
is the s200 and the s256 the same turbo????
and do you have them in stock, if you dont how long for the wait???
03-06-2008, 01:25 PM
#19 (permalink )
Member Number: 26404
Just like the GT37R being another name for a BB T67, the S256 is another name for the S200.
03-06-2008, 01:34 PM
#20 (permalink )
Member Number: 30158
good turbo will be getting people in orlando to get them.
03-06-2008, 01:40 PM
#21 (permalink )
Jon@AGP
is the s200 bb???
03-06-2008, 02:50 PM
#22 (permalink )
Standard bearing only
03-06-2008, 07:38 PM
#23 (permalink )
Member Number: 30537
Im rockin my AGP 50 (which I love) and my midsummer mod will be the AGP full exhaust (when released) but This looks like a nice upgrade for the fall.
12.0@120 on DRs and 93oct.
03-06-2008, 08:16 PM
#24 (permalink )
Member Number: 46957
whats the modlist for the above dyno numbers??? whats full boost, 3500 RPM???
Riding it till the wheels fall off
03-06-2008, 08:35 PM
#25 (permalink )
Member Number: 39388
20psi seems to be around 3300, 25psi seems to be around 3500. this is impressive because on the streets itll be a tad quicker spool as well.
drastic holdin it down for the deuce whatever the fuck, we ain't dead yet
03-11-2008, 01:07 AM
#26 (permalink )
whos dyno graphs are those? they dont look like goobers.... whats the mod list again for those above graphs
03-11-2008, 08:32 AM
#27 (permalink )
Member Number: 333
mark2249
The car has a built bottom end however a stock head and cams, and everything else a big turbo car needs.
20psi is around 3600rpm.
03-11-2008, 06:45 PM
#28 (permalink )
Member Number: 15028
Is the built bottom end absolutely necessary? considering rj and the dbb50 was holding together on stock block and 450hp? This IS what everyone for the longest just referred to as the "extended tip 50 trim" right?
assuming this is for a street car running around @ about 16-18 psi that only goes to the track 4 or 5 times a year and no more than 22 psi should i even keep the 50 as a consideration?
I thought the bottom end was good till about 500-600 hp and the head was just a huge restriction for even the stock turbo. When should we be concerned about valve float and worse?
I'm just wondering because i doubt i'd ever run over 20 psi on the street and won't be thinking about major engine work for another year and ~25 psi?
Efficiency range on this badboy?
03-11-2008, 09:10 PM
#29 (permalink )
Member Number: 11197
NCNTRL516
what???
are you for real?? well you try that and you will be in here with a thread titled blew my motor now
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
03-11-2008, 09:12 PM
#30 (permalink )
1 guy has done 600+ on stock motor. is that something i think everyone should try and do, no.
i think the sweet spot is around 450-500 depending on tune, tming and knock. there are alot of variables and can cause the motor to go. those 3 things along with oil starvation will cause the motor to go. not to mention if you forget to cut the chain on your bs!!!!
Linear Mode
» Site Navigation
> Other Vehicles
» Search Used Cars
