Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 10-09-2009, 02:55 PM   #1 (permalink)
srtras's Avatar
Member Number: 52121
Default SCT question
i have the SCT tune from AGP and only have a wideband to read air/fuel. i do not have a datalogger they also highly recommend having. right now i am running 18psi, would it be safe to turn up boost to 22-24 psi without a datalogger?
gt30r, AGP SCT tune and supporting mods
srtras is offline   Reply With Quote
Old 10-09-2009, 03:53 PM   #2 (permalink)
walterbrannman's Avatar
Member Number: 35864
idk how safe it is but ive been doin it for a couple months on the flash,but then again I dont DD my car....its still running tho lol
walterbrannman is offline   Reply With Quote
Old 10-09-2009, 07:31 PM   #3 (permalink)
Louisvilleguy's Avatar
Member Number: 17118
I wouldn't push it without a scangauge or means to watch Knock. Especially if you are running strictly pump gas. A/F can be in an acceptable range while still seeing KR.
04 SRT-4
- FP Green model
- 344whp/375wtq (AGP flash 93 octane)
Louisvilleguy is offline   Reply With Quote
Old 10-12-2009, 09:43 AM   #4 (permalink)
srtras's Avatar
on 18 psi yes i have been using only 91 oct. but if i put in race gas and turned up the boost to 22-24 would i still need to worry about knock?
btw how much is a scan gauge?
Old 10-12-2009, 12:12 PM   #5 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
Generally from 23psi and above, Kevin adds additional timing in his maps for race fuel. The most we generally suggest on pump gas is 20-21psi.
There are a number of datalogging devices available out there. Many of our customers use the Aeroforce scan gauges, although I do not believe they allow you to actually save logs. Air/fuel and knock/timing retard are the most important things you want to keep an eye on.
Jon@AGP is offline   Reply With Quote
Old 10-12-2009, 03:23 PM   #6 (permalink)
srtras's Avatar
great thanks!
Jon you mention generally from 23psi and up timing is added for race gas. is there a way for me to find out if my map has that?
Old 10-12-2009, 04:31 PM   #7 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
Kevin does that with all of our maps, so I am pretty sure yours would be like that as well.
Old 10-13-2009, 10:43 AM   #8 (permalink)
srtras's Avatar
great, thanks again!
Page generated in 0.15794 seconds with 13 queries
