SCT + Fuel Return Line
I received my SCT tune from you. Thanks a lot.
My setup is 50T, A/R .63, Fuel return Line and S2 injectors.
On the instruction sheet, it says: ...you should have the vacuum line going to your FPR from a boost only source...
I only want to know if the sent tune is intended to be connected as the paper says. At the beginning I thought the fuel pressure has be static and the FPR will be for little "tune" purposes, but seems be the fuel pressure will reach the boost trough the FPR, isn’t it?
Is there an available SCT Tune on static fuel pressure (S2 injectors) due I need it for my NOS setup?
Best Regards.
