Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 05-14-2008, 09:47 AM   #1 (permalink)
95neonman's Avatar
Member Number: 37749
Default SCT flash w/3 bar tip sensor quetions
I'm going to be using a 3 bar tip sensor instead of the tip jumper. Do i have to have all the vaccum lines hooked up like stock that go to the tip sensor? Or can i just leave the lines disconected and open to the atmosphere?
Agp DBB 50trim
Old setup- K&N cai, agp wastegate, MPx 3" tbe, MPx FMIC, JMB upp w/turbo xs rfl, Maddog sts, bfg dr's on kosei k1's- 13.1@108 2.0 60'
95neonman is online now   Reply With Quote
Old 05-14-2008, 01:03 PM   #2 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
Either or. The important part is that the sensor reads how a 3-bar tip should. You need the tip sensor hooked up for PCM based boost control, which we do not set up at this time for you. If it is vented to atmosphere, the stock jumpered tip sensor should read the same as a 3-bar tip.
Jon@AGP is offline   Reply With Quote
Page generated in 0.11528 seconds with 11 queries
