Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 06-30-2008, 04:24 PM   #1 (permalink)
Member Number: 9221
Trader Rating: (18)
Default S3D in but have a question
When i get into about -5 vac and let off i hear a howl, is that normal? Also the clutch pedal vibrates
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 07-01-2008, 03:28 PM   #2 (permalink)
Member Number: 9221
Trader Rating: (18)
nothing? come on
Old 07-01-2008, 10:03 PM   #3 (permalink)
Double J's Avatar
Member Number: 25570
Trader Rating: (19)
I should have my kit in tomorrow. I'll see if mine does the same thing.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab/borla exhaust w/cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-MM Inserts- PTP Check Valve- PTP 55mm TB- CCA FMIC- Slowboy crashbar- Megan Racing CO's- Hotchkis Swaybars- ACT Clutch/Flywheel
Double J is offline   Reply With Quote
Old 07-02-2008, 08:44 AM   #4 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
Where is the noise coming from. And I don't know what to tell you about your clutch pedal.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 07-03-2008, 03:19 PM   #5 (permalink)
Member Number: 9221
Trader Rating: (18)
the nosie is coming from the turbo it sounds like. WHen ever i shit i get the turbo flutter through the intake but that howl is there with it.
Old 07-03-2008, 03:48 PM   #6 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
It would be part of the partial flutter, partial blow off that you're getting. What BOV are you running?
Old 07-03-2008, 05:00 PM   #7 (permalink)
MadTyteSrt4Yo's Avatar
Member Number: 25465
Check your intake air temp sensor...I have that on my car right now..i just installed a front mount and it does it. Make sure its tight in the gromet or it will howl
2005 Black Srt-4 ( TheBlackPearl )
Mods: Mopar Stage 1,JMB UHP with the HKS SSQV BOV,MPx BFMIC,MaxxFab Single Exit 3" Exhaust, DCR Oil Modifier,MPx 62mm TB, $20 catch can w/CHK valve
MadTyteSrt4Yo is offline   Reply With Quote
Old 07-03-2008, 09:56 PM   #8 (permalink)
Double J's Avatar
Trader Rating: (19)
I just got my kit installed. My clutch pedal still feels the same.
Old 07-04-2008, 05:37 AM   #9 (permalink)
winker2112's Avatar
Member Number: 14625
We had a howl on one of the s3d kits we installed. Don't know if it was the comp size, or the position of the engine, but one of the bolt humps on the comp housing was just barely touching the fire wall and it would make a howling sound that was more pronounced during spool down. Tried clocking it to avoid it, but just couldn't get it lined up correctly without having something else not line up, so I shifted the engine foward a few mm, and also dented in the firewall a lil at that one spot. Problem gone. Not sure if this is related, but that was the one experience i had. Probably just a casting defect or something. Never had a problem with agp products before or after.
PS... s3d is one bad ass setup... makes me wanna ditch my dbb50 trim.
winker2112 is offline   Reply With Quote
Old 07-06-2008, 03:38 PM   #10 (permalink)
Member Number: 9221
Trader Rating: (18)
HKS ssq
Old 07-06-2008, 03:39 PM   #11 (permalink)
Member Number: 9221
Trader Rating: (18)
that cant be i i have the AGP screw in, and i havent touched it since i put that in
Old 07-07-2008, 11:39 AM   #12 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
that's a new one.
Old 07-07-2008, 11:39 AM   #13 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
Quote: Originally Posted by AnotherNeon View Post
HKS ssq
bingo
Old 07-07-2008, 01:26 PM   #14 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
Spelling error gone very very wrong
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 07-07-2008, 03:08 PM   #15 (permalink)
Member Number: 9221
Trader Rating: (18)
The compressor housing is hitting the firewall. But i dont see how that will cause the howling nosie
