Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 07-03-2008, 10:08 PM   #1 (permalink)
Double J's Avatar
Member Number: 25570
Trader Rating: (18)
Default Question on Stage 3 delta boost.
I got done installing my kit and took it out for a drive. Right now I'm running mine on stage 2 fuel and boost controll. The question I have is, is it normal for the boost to come on a little slow? It doesn't spike, it slowly raises to 15 psi and holds. Could a boost leak cause that? I never had an external waistgate before, so I'm not fully sure on how the boost is suppost to come on.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab/borla exhaust w/cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-MM Inserts- PTP Check Valve- PTP 55mm TB- CCA FMIC- Slowboy crashbar- Megan Racing CO's- Hotchkis Swaybars
Double J is offline   Reply With Quote
Old 07-05-2008, 07:25 AM   #2 (permalink)
xSugarSports's Avatar
Member Number: 36740
Have to keep in mind that this turbo is a lot bigger, so it spools slower then the old stock one.
When in doubt, power out.
05 ACR.
xSugarSports is offline   Reply With Quote
Old 07-05-2008, 10:55 AM   #3 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
What boost controller are you running?
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 07-05-2008, 12:26 PM   #4 (permalink)
Double J's Avatar
Trader Rating: (18)
No boost controller yet. I'm running it off of the stock wga line (black). So right now the pcm has full controll.
Old 07-07-2008, 11:57 AM   #5 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
That would explain why. Adding a quality boost controller will make the turbo spool faster.
Jon@AGP is online now   Reply With Quote
Old 07-07-2008, 03:47 PM   #6 (permalink)
Double J's Avatar
Trader Rating: (18)
I have a blitz dual solenoid electronic boost controller from one of my last cars. Would that be a good one to run with my setup?
Old 07-08-2008, 10:41 AM   #7 (permalink)
Jon@AGP's Avatar
Trader Rating: (64)
The blitz boost controllers are excellent, although a bit more complicated to use. If you know how to operate that boost controller well, that would help your current situation out tremendously.
Old 07-08-2008, 05:41 PM   #8 (permalink)
Double J's Avatar
Trader Rating: (18)
Ok, sweet! I haven't used it in like 6 years. But I think once I hook it up, it will come back to me on how to use it. Thanks for the info.
Old 07-08-2008, 06:03 PM   #9 (permalink)
S2R0T044's Avatar
Member Number: 5620
Subscribed for the update. Curious to see how you work this out and what the results are.
Josh - 2005 Black SRT-4
Drastic.
blazinsrt built.
S2R0T044 is offline   Reply With Quote
Old 07-09-2008, 04:24 PM   #10 (permalink)
Double J's Avatar
Trader Rating: (18)
This weekend I'm going to install a stage 3 pcm, fuel pump, and fuel rail. I'll see how it is with the stage 3 pcm in controll. If it's still slow to build boost wich I think it will, then I'll hook up the boost controller. I'll post up my results.
Old 07-14-2008, 03:41 PM   #11 (permalink)
Double J's Avatar
Trader Rating: (18)
I installed my stage 3 pcm and fuel this past weekend. Boost still builds a little slow but I don't mind it too much. It seems to help with traction. The car absolutly flys now with the stage 3 stuff. DAB 3 hits 20 psi. I think I got to put the stronger spring in the wg, and the boost might go a little higher. Still haven't tried HOM yet. But I'm loving this turbo kit so far.
Old 07-14-2008, 03:48 PM   #12 (permalink)
Member Number: 9221
Trader Rating: (17)
what clutch do you have?
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is online now   Reply With Quote
Old 07-14-2008, 04:07 PM   #13 (permalink)
Double J's Avatar
Trader Rating: (18)
Still on the stocker. But I just picked up and ACT just incase the stock starts to give out.
I got 24,000 miles on the stock one.
Old 07-14-2008, 06:02 PM   #14 (permalink)
Member Number: 9221
Trader Rating: (17)
hmm i might try to up the boost then i got 34k on mine
Old 07-14-2008, 08:53 PM   #15 (permalink)
Double J's Avatar
Trader Rating: (18)
Yeah, mines still holding good. But I'm not sure if it will still hold on HOM. Only one way to find out....
Page generated in 0.31819 seconds with 11 queries
