Oil restrictor??? - Page 2 - Dodge SRT Forum
post #16 of 26 (permalink) Old 09-01-2009, 06:30 PM Thread Starter
Chief's Avatar
Quoted: 6 Post(s)
I have brand new PVC valve, 03 vc, i had breather to TB, no check valve, heard about check valve, and also heard alot of guys just took the VC breather off the TB and cap the TB and vent the pvc out to atmosphere. So i have had this like this for a couple weeks seeing if it helped, but seem to not change anything. Sooo why would my crank psi be to high?
'freedom's not free'
11.6@120 Stock head/cams
@3650ft
Head build???
Chief is offline
post #17 of 26 (permalink) Old 09-01-2009, 06:32 PM Thread Starter
Chief's Avatar
Quoted: 6 Post(s)
Only reason crank psi would be high is pvc cloged and the vc cant breathe? correct? Maybe my drain is to small?
@3650ft
Head build???
Chief is offline
post #18 of 26 (permalink) Old 09-01-2009, 06:42 PM Thread Starter
Chief's Avatar
Quoted: 6 Post(s)
I have ccv next to the intake just out to atmosphere as well. Did not like oil in my intake, Not to mention now im just running a filter on the turbo, no intake.
do you need the pvc connected to vacum for correct crank case pressure? When i had it on the TB the turbo still pushed oil into hot side. Seem no chnage.
@3650ft
Head build???
Chief is offline
post #19 of 26 (permalink) Old 09-01-2009, 09:51 PM
Ben@AGP's Avatar
Quoted: 5 Post(s)
Or maybe because you have a hole in your piston(s).
WEBSITE | EMAIL | YOUTUBE | FACEBOOK | 480-983-6083
Ben@AGP is offline
post #20 of 26 (permalink) Old 09-01-2009, 09:53 PM
Ben@AGP's Avatar
Quoted: 5 Post(s)
do you need the pvc connected to vacum for correct crank case pressure? .
Yes, PCV needs to have vacuum pulled on it. There's not other way that you can properly evacuate the crankcase unless vacuum pulls it out.
Ben@AGP is offline
post #21 of 26 (permalink) Old 09-01-2009, 11:13 PM Thread Starter
Chief's Avatar
Quoted: 6 Post(s)
bad rings? cause high psi? Well i did not have a hole till this sunday night, May be just rings, not sure pullin piston out tomorrow.
Ill messure that drain line tomorrow and post the mesurments. Maybe i should go next hose bigger? I dont have a check valve, just had pvc CC TB Do i NEED a check valve or pvc works fine?
@3650ft
Head build???
Chief is offline
post #22 of 26 (permalink) Old 09-02-2009, 12:49 AM
boostedsohc's Avatar
Quoted: 1 Post(s)
oil pressure about 70 psi wot
boostedsohc is offline
post #23 of 26 (permalink) Old 09-02-2009, 09:33 AM Thread Starter
Chief's Avatar
Quoted: 6 Post(s)
WOW really????
Well i went ahead and bored out my brass piece its .600 on top but was only .470 at the tapper Now shes .590 at the end and .600 on top. So its almost .600 all the way through. Im gonna get a larger ID drain tube. I did have to push it over the stock tube out the block and push it over the brass piece So the ends are flared where the center is smaller. Soo gonnna get some tubbing that just slides right over the brass and drain tube. HOPING this will solve my oil push problem. IF it STILL pushes oil, Im gonna go ahead and put a restrictor on there. This is if i get my car back together before my D60 If i get the D60 im asuming i wont need a restrictor. But will have a bigger drain tube over a .100 difference!
@3650ft
Head build???
Chief is offline
post #24 of 26 (permalink) Old 09-02-2009, 12:43 PM
New Member
Jon@AGP's Avatar
Quoted: 0 Post(s)
Yes. Are you sure there wasn't damage already done, and it just got worse on Sunday? I have seen cases where someone has cracked a piston, compression numbers came out ok, but it had severe leakdown in a cylinder. It all depends on how the damage occurs and is contained.
I would not suggest running any kind of restrictor on a journal bearing turbo.
Jon@AGP is offline
post #25 of 26 (permalink) Old 09-03-2009, 07:06 PM
guhfluh's Avatar
Quoted: 0 Post(s)
Fix the excessive blowby from the pistons/rings, get the biggest and best flowing oil drain possible and go from there.
I've always worried about the excessively high oil pressures in the SRT engines wreaking havoc on the turbos and always wanted to test the pressure right at the turbo inlet w/ a gauge just to see what it reads.
guhfluh is offline
post #26 of 26 (permalink) Old 10-18-2015, 09:45 PM
Quoted: 1 Post(s)
Chief, Did you get this fixed????
My ride AKA "DUCES"
Snyphor24 is offline
User Tag List
Linear Mode Linear Mode
