Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 10-12-2009, 02:14 PM   #1 (permalink)
jessebeachusmc's Avatar
Member Number: 70610
Default oil line connector to turbo leaking
im leaking oil out of the oil line connector that connects to the turbo and was wondering if this has happened to anyone else and if i could put somne rtv on there without voiding the warranty? here a pic.
AGP borg warner s256 powered
jessebeachusmc is offline   Reply With Quote
Old 10-12-2009, 03:07 PM   #2 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
Don't use RTV. Does the fitting seem loose at all, like it can do another 360 degree rotation on the top of the turbo?
Jon@AGP is online now   Reply With Quote
Old 10-12-2009, 03:34 PM   #3 (permalink)
No. But it's leaking oil out of there bad. I can't even get in there to try and tighten the fitting. Why can't I use rtv?
Old 10-12-2009, 03:49 PM   #4 (permalink)
i need to do something by tonight. i have to get to work and this is my only car.
Old 10-12-2009, 04:30 PM   #5 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
RTV will flake off and clog up the oil inlet of the turbo.
It is an NPT fitting, so it will only seal on a few threads. If you are very careful, and need to use a sealant, use the Loctite teflon liquid stuff and put just a little bit on the middle sets of threads on the fitting. It won't take much at all, so make sure you do not overuse it. Don't glob it all over the fitting or you will have problems.
Old 10-12-2009, 04:52 PM   #6 (permalink)
I'm not saying I'm going to put it on the threading. I was going to put it around the fitting so it won't leak because I can't tighten or loosen the fitting because I don't have enough room to get a wrench in.
Old 10-12-2009, 06:19 PM   #7 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
That most likely wouldn't seal it, and I would reccommend doing it that way.
You'll probably need to pull the turbo off in order to get enough room to get a wrench in there.
Old 10-12-2009, 06:21 PM   #8 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
thats what i think too. just to be safe.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 10-12-2009, 06:38 PM   #9 (permalink)
Hey Jon any way you could hook me up with one f your new dsp tunes for cheaper than 250???
Old 10-12-2009, 06:59 PM   #10 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
The tune itself? That's what our tunes go for right now. A bit more than others, but we do not charge for retunes or updates. If you change something let us know and we'll give you an updated tune.
Old 10-12-2009, 07:04 PM   #11 (permalink)
Yea I know I need a rescale for te 3 bar sensors and for injectors.
Old 10-14-2009, 11:57 AM   #12 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
No problem. Just let us know. We can take an order on the website or over the phone.
Old 10-14-2009, 10:06 PM   #13 (permalink)
Hey Jon I somehow stripped the threading on the oil line going to the fitting on the turbo. So I need a new line and a new fitting just to be safe. I was wondering how much that would be. I'm going to be doing some training For 2 weeks and will have no access to any electronics so I'm going to have my wife get in touch with you while I'm gone and hopefully you can ship me the parts before I get back.
Old 10-15-2009, 11:41 AM   #14 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
Oil line kits are $50. I have them in stock, ready to ship.
Old 11-15-2009, 09:23 PM   #15 (permalink)
well i bought the new oil feed line kit, installed it and tightened it as much as i possibly could where i could still connect the line. i wasnt leaking oil for about a week and now its leaking oil out of the fitting. i need a solution asap because this is my dd and im losing oil and its hitting the hot exhaust and smoking horrible...
Page generated in 0.15009 seconds with 13 queries
