Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 09-17-2009, 06:22 PM   #1 (permalink)
srt88's Avatar
Member Number: 52056
Trader Rating: (10)
Default Need sum help...
Ok I posted in discussion and no help...maybe I'll get sumthing from u guys...I installed the delta 44 previously I had no problems with the car...nowim getting a p0172 code...fuel trim rich or wutever...I'm on stage 2 injectors and all other fuel is the stock...mods are bc 272 cams, bc springs n retainers, arm intake agp coldside with tial bov, potted intake manifold, 3 inch turboback and a big fmic...wut could be causing this problem...at idle it runs rich as a pig like 10-11 afr I had to pull 40% fuel out for it to idle fine but still getting the code, keep in mind I'm only on stage 2 injectors...and when I go to slow down to a stop the car will die unless I rev it and then it starts running rich again and then settles down to normalcy...also I have the bigger spring in my agp external wga with a mbc tapped between the turbo to wga I have the compressor line going to the side of the mbc then the bottom of the mbc goes to the wga...for sum reason if I get on it the boost goes all the way up n past 30 psi...wuts goin on with that? All help is greatly appriciates thanks
R.I.P. Kevin Roman 8-25-06
Do work son
srt88 is offline   Reply With Quote
Old 09-21-2009, 11:45 AM   #2 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
What are you using for fuel control?
Jon@AGP is offline   Reply With Quote
Old 10-05-2009, 08:05 PM   #3 (permalink)
srt88's Avatar
Trader Rating: (10)
i have been sent about 4 different maps from performance autowerks on an sct xcal, a few here and there tweaking it, still no luck on it, dave tried pulling fuel and sadly the car just runs worse...i also have a afc controller, which is doing nothing for me it is zero'd out but i tried pulling fuel from that, and no luck, it still runs pig rich at idle, and when i get on it...with 750cc injectors, walbro fuel pump...the car runs lean as heck, so i added fuel with the afc controler to try and adjust a little and it ended up me maxing out the afc at 50% and the car still runs lean...idk wuts going on
Old 10-06-2009, 12:46 PM   #4 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Sounds like youre not scaled for the right map and tip sensors. Do you have stock sensors or 3 bar?
*NE 400 Club*
Old 10-06-2009, 12:51 PM   #5 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
needs rescale i bet you mgh sucks
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 10-15-2009, 06:07 PM   #6 (permalink)
srt88's Avatar
Trader Rating: (10)
I had the stock map sensor and pwerks gave me a map with that...then I was getting a map sensor to high code so I got a 3 bar map...I put that on and drove with the stock map tune and it ran a little better then the next day I got the 3 bar tune and it runs even worse then it has before...idk if that helps at all?
Old 10-15-2009, 06:48 PM   #7 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
Click here to purchase now.
NHRA Pro Stock Motorcycle - Kenny Van Buren
Come see AGP Turbo at NHRA Full Throttle events.
Ben@AGP is offline   Reply With Quote
Page generated in 0.16654 seconds with 13 queries
