Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 06-19-2008, 09:01 AM   #1 (permalink)
DAN_3KVR4_SRT4's Avatar
Member Number: 28874
Default Max WHP from 50 trim on pump.........
Id like to know what others have recieved from thier turbos on pump gas. I just finished my tuning, and have to say i was shocked. I was expecting no more than around 420ish, and thats respectable. I was floored when we tuned pull after pull and it just kept going up! We peaked at 451whp, 410tq @21-22 psi with 11.5 AFRs! Astounding i say.
Race gas wasnt what I was hopeing for, but it wasnt bad either, just over 480whp on C16 @ 24 psi with 11.5 AFRs. Think this 50 can go play with the 10 second cars yet? I was hopeing, and we shall see.
Thank you for putting together some realy awesome products guys. This turbo has been through the ringer, and it just keeps putting out great results.
11.7 Drag Pass CARDOMAIN DRIVING THE "RING" IN 09!
DAN_3KVR4_SRT4 is offline   Reply With Quote
Old 06-19-2008, 10:21 AM   #2 (permalink)
stageII's Avatar
Member Number: 32588
Trader Rating: (34)
excellent numbers bro what are you tuning with? Is your motor built? head built? All i know is i am some what street tuned and i am stayin about 2 lengths behind a 600 whp mustang and he ran 10.74 in the 1/4 so 10's they are there just hard to do with a 5 speed front wheel drive. i am on 23 psi on pump. Question why did you not up the boost to 28-29 psi and open that turbo up. Hit me up threw a pm if you can because i will forget to go back to this thread more then likely. Thanks bro
All DCR:motor,Head,oil system,intake mani,throttle body/spacer,Water injection,Battery kit,Greddy boost control,Crower stage 2 cams,fidenza cam gears
Turbonetics DBB 50trim, lots more
New Best1/411.52 at 123.00 mph TUNED BY TURBOTUNE MARK
NEW Best1/8 7.45 at 100.25 mph TUNED by MARK(TURBOTUNE) 26psi
stageII is offline   Reply With Quote
Old 06-19-2008, 12:00 PM   #3 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (62)
damn, that's pretty good. I'd be interested in knowing your setup.
I made 393 on 91 pump at 20 psi. I haven't dyno'd on race gas yet.
eVilcreations sold me a POS unfixable turbo.
Old 06-19-2008, 12:06 PM   #4 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
Sounds like you are right on track.
You need to run a little more boost and you should be right at 500hp, and will max the turbo out. 480hp at 24psi is impressive any way you look at it though.
Jon@AGP is offline   Reply With Quote
Old 06-19-2008, 12:12 PM   #5 (permalink)
Jagok1's Avatar
Member Number: 14366
Damn, pretty nice #'s. Like mentioned, what's your setup
AGP GT40 ~ 460HP/430TQ by DSMLights
WTT: GT40 for S3Delta 47lb
Jagok1 is offline   Reply With Quote
Old 06-19-2008, 12:59 PM   #6 (permalink)
Member Number: 30158
nice numbers why did you not run 26 psi on race and was your pump gas 93 octane
OrangeKyle is offline   Reply With Quote
Old 06-19-2008, 01:40 PM   #7 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (62)
If he's in SC, his pump gas is 93
Old 06-19-2008, 06:02 PM   #8 (permalink)
Look to the setup list in TKMotorsports section:Mods listing, for those that are going to ask.....
I dont know why but the tuner said the turbo was at its limit, and he didnt want to get detonation.....???????? If you look at they dyno you can see it fall off the top end. Realy, you think he was just being extra cautious? My mods listing should have realy put me into the 500s. I have ran 28psi b4 motor/head build so I dont know why he said it was maxed at 24........ Check it out and let me know what you think. I am realy a dud at knowing about tuneing except when a car is ritch and lean by AFRs. I can send my maps to anyone willing to check them out to see where I can gain the power if you want to take a look.
Old 06-20-2008, 08:42 AM   #9 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (62)
for a dbb, your spool-up seems kind of slow to me.
Here's a rough overlay of my standard-bearing 50-trim.
Old 06-20-2008, 08:44 AM   #10 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
As you increase airflow through your engine, it doesn't take the same amount of "boost" to create the same horsepower. You're probably pretty close to the limit of the turbo and you can't run more boost than that, because your engine flows air better.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 06-21-2008, 10:41 AM   #11 (permalink)
CrEaTrE's Avatar
Member Number: 28234
NICE!
Also, your spool up does seem way off!
Old 06-22-2008, 05:12 PM   #12 (permalink)
thats what i was thinking too Ben.
i dont know about the spool up but it feels realy good in the pucker factor lol.
Old 06-23-2008, 07:46 AM   #13 (permalink)
Member Number: 42667
My DBB 50trim spools about the same as yours, i thought mine was way off.
05plsrt4 is offline   Reply With Quote
Old 06-23-2008, 06:28 PM   #14 (permalink)
Eh, its not off. Its right where it needs to be.
Page generated in 0.19571 seconds with 11 queries
