Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 06-04-2008, 10:10 AM   #1 (permalink)
Member Number: 64540
Default how much to convert a std. 50t to a Cbb
how much is it to convert a standard 50t into a CBB? turbonetics turbo.
i know the turbonetics std. and CBB chra's are rebuildable (per, the t-netics website), and the CBB upgrade is cheaper than garretts to boot (200-250 to upgrade from std vs 500ish for the garrett).
can the ceramic BB just replace the std. bearing, or does a whole new chra need to be put in place (why if its rebuildable).
thanks for any input...might be working out a deal w/ a forum member, but prefer the 50trim to be CBB..
mike
Drasticc is offline   Reply With Quote
Old 06-04-2008, 10:12 AM   #2 (permalink)
MonsterLemon's Avatar
Member Number: 48761
Trader Rating: (42)
Just the price of the chra and lines. (yes the chra needs to be swapped) I think they go for the 900 price range if i remember right. Thats how my turbo came to be. It started out life as a std 50t
MonsterLemon is offline   Reply With Quote
Old 06-04-2008, 10:19 AM   #3 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
New CHRA.
Garrett - $895
Turbonetics - $890
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 06-04-2008, 10:25 AM   #4 (permalink)
ouch. thought you'd be able to upgrade just the bearing in the turbonetics.
is there a + or - to the CBB over the DBB, or vice versa?
Old 06-04-2008, 10:27 AM   #5 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
It all pretty much works the same. The largest advantage by both setups is the increased thrust load.
Old 06-04-2008, 10:36 AM   #6 (permalink)
Trader Rating: (42)
Turbo's with dbb's like the gt35r and the 3076r appear to have a much meaner sound while in boost. Not sure if it has to do with the ported shroud or not but I was told its the bearings.
Old 06-04-2008, 10:41 AM   #7 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
Ported shroud compressors sound different since it's recirculating the backflow of air that would normally cause surge. The sound has nothing to do with the bearings.
Old 06-04-2008, 10:42 AM   #8 (permalink)
Trader Rating: (42)
Thats what I said when it came up. I was like dude u sure it isnt the ported shroud? speaking of when are u guys gonna offer one for your 50trims?
Old 06-04-2008, 10:54 AM   #9 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
Ported shroud on our 50 trims makes the response more flat, and we lost 15whp across the board. It was a very bad thing.
The common misconception is that you can port shroud anything, and it makes it work better.
Old 06-04-2008, 10:59 AM   #10 (permalink)
what do you think about a 50t/.48ar?
would it still hold power at 6500?
considering i have a built head (5angle VJ, +1/+2 valves, full race port), crower s2 cams, 70mm boomba tb, and 70mm IM...so im flowing a ton of air.
sct tuned, and have full bolt ons..
i want to make like 430hp on pump/meth (2 m5nozzles), rev to 6500, and do 122-124mph traps.
am i just out of league on this one, or is it obtainable w/ the head/cams setup?
Old 06-04-2008, 11:06 AM   #11 (permalink)
Trader Rating: (42)
I was thinking of mating it with a ported shroud and a .48 a/r exh housing. I dream about different setups all the time lol. I was just curious if that would help with it surging.
Old 06-04-2008, 11:17 AM   #12 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
It helps with it surging, but it makes the turbo less efficient and less effective in making the power it should.
Old 06-04-2008, 11:26 AM   #13 (permalink)
Trader Rating: (42)
Good to know and another question how can the 3076r benefit from the ported shroud and not the 50trim aren't they pretty identical?
Old 06-04-2008, 11:30 AM   #14 (permalink)
i can haz a quick answer, then back to discussion of ported shrouds?
Old 06-04-2008, 11:31 AM   #15 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
Pretty identical meaning, the only thing they share is exducer diameter.
Different inducer size, different tip height, different radius, different sweep angle, different BCI...
» Search Used Cars
Page gen
