Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 07-05-2008, 04:21 PM   #1 (permalink)
95neonman's Avatar
Member Number: 37749
Default How much boost with sct flash with race gas?
I have the sct flash, and right now im running 21psi on 93oct with 0 knock. A local track sells 112 leaded race gas, how much boost will i be able to run if i fill up with the race gas?
Agp DBB 50trim
Old setup- K&N cai, agp wastegate, MPx 3" tbe, MPx FMIC, JMB upp w/turbo xs rfl, Maddog sts, bfg dr's on kosei k1's- 13.1@108 2.0 60'
95neonman is offline   Reply With Quote
Old 07-07-2008, 11:44 AM   #2 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
That's more of an answer that only you can determine. Fill up with race gas and monitor knock, and afr. Keep turning up the boost until either you scare the shit out of yourself, or until you see some knock or the AFRs jump into the 12s.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 07-07-2008, 12:04 PM   #3 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (31)
Along the same lines as the previous question, how much boost can you run on 93 alone? I seem to recall hearing 22psi, is anything above 22psi automatically add timing that 93 can't hold without knocking?
Old 07-07-2008, 12:05 PM   #4 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (77)
correct. I dont' recommend any boost over 22psi on pump gas. You can if you dare, but I don't recommend it.
Old 07-07-2008, 12:24 PM   #5 (permalink)
SRTie4k's Avatar
Trader Rating: (31)
Got it, thanks
Page generated in 0.14948 seconds with 11 queries
